frame-relay fragment command missing
Does anyone know why the frame-relay fragment command is not available on 3600 and 2600 routers running 12.2(5d) IOS? I have not been able to find a definite answer.
  • Voice over IP
Re: frame-relay fragment command missing
It is supported.
3660-4#sh ver
IOS (tm) 3600 Software (C3660-IS-M), Version 12.2(5d), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Fri 01-Feb-02 22:38 by kellythw
Image text-base: 0x600089C0, data-base: 0x61200000
ROM: System Bootstrap, Version 12.0(6r)T, RELEASE SOFTWARE (fc1)
3660-4 uptime is 2 minutes
System returned to ROM by reload
System image file is "flash:c3660-is-mz.122-5d"
3660-4(config-map-class)#fra,
3660-4(config-map-class)#fram
3660-4(config-map-class)#frame-relay frag
3660-4(config-map-class)#frame-relay fragment ?
<16-1600> Define fragment size
3660-4(config-map-class)#frame-relay fragment 160
3660-4(config-map-class)#end
3660-4#
map-class frame-relay voiceover
no frame-relay adaptive-shaping
frame-relay fair-queue
Thanks for the reply. In my routers this command is just not available.
IOS (tm) 3600 Software (C3620-I-M), Version 12.2(5d), RELEASE SOFTWARE (fc1)
Compiled Sat 02-Feb-02 01:51 by kellythw
Image text-base: 0x600089A8, data-base: 0x60A54000
SPART36(config)#map-class frame-relay 512k_voice
SPART36(config-map-class)#frame-relay fragment ?
% Unrecognized command
According to Cisco reseller support this command requires ip plus feature set.
140
