08-28-2003 10:06 AM
I have VXC-2TE1+ port adapter in 7206 (NPE200) router. The Line is experiencing a lot of frameslips which seems to be a clocking problem.
Experienced the same problem in another 7206VXR (NPE G1) router. Issued the 'frame-clock-select' global command to resolve the problem on VXR router but the command is not supported on its not working on 7206 (NPE200).
Regs.,
Prasad.
Need to know an equivalent command to run on 7206 (NPE200). Any help?
09-03-2003 08:19 AM
It is supposed to be there on all 7200 series routers. Are you missing something. Which IOS image are you using?
09-14-2003 05:26 AM
Thanks for the reply.
Iam running 12.2(16a) on this router.
File: c7200-js-mz.122-16a.bin
Regs.,
Prasad.
