FXO and disconnect problem
When I connect FXO i Cisco 2611XM (12.3) to PSTN and used "supervisory disconnect anytone" is impossible to make the call from FXS to PSTN.
Why?
Any body know?
I need this command because this solve problem with no call disconnection when call goes from PSTN with no answer from my side (Phone still ringing). I found that "supervisory disconnect anytone" work correctly but any other "supervisory disconnect ..." commands not.
Any suggestions?
1 REPLY
Re: FXO and disconnect problem
Hello.
You must turn on debugs and look does FXO try made a
call or not, next you must connect analog telephone
tube between cisco and PSTN and hear on what stage you
receive disconnect ( I suppose when PSTN generate
ringback tone )
And only after that possible give you recomend.
323
