FXO & VoIP
Is it possible to place a call via a FXO port in both way ?
here is the network :
Operator<=>BRI<=>3640A<=>IP Network<=>3640B<=>FXO<=>switch Alcatel E10
Both router 3640 are in version 12.2(7a)..
The calls coming from the switch to the routeur via the FXO work fine.
But when I try a call from the BRI side it doesn't work, I can see the call arriving in the 3640B but no way to go out from the FXO.
Thks for ur help
sorry for my poor English ..
Silver
Re: FXO & VoIP
It should work, the POTS dial peer just needs to match on the number that comes in from the VOIP cloud. Don't forget a POTS dial peer strips off any explicitly matched numbers by default, so you may need to use the prefix command or foward digits commands -
dial-peer voice 1 pots
destination-pattern 5551234
port 1/0/0
prefix 5551234
or
port 1/0/0
forward-digits all
Re: FXO & VoIP
thks but I finally find the solution.
In the way FXO => BRI , the pb was that there was no calling number to match my dial-peer voip. So I've put the command "connection plar xxxxxx" on the FXO voice port to simulate a calling number.
In the other way (BRI => FXO) the pb was that there was no tone sent back by the FXO to the BRI. So I've put the command "voice call send-alert" on the 3640B to simulate a tone.
It seems to work now ....
thks
Re: FXO & VoIP
sorry i've made a mistake.
you should understand "called number" instead of "calling number" ....
Re: FXO & VoIP
Did you ever have any issues with this when the calling party hangs up before the called phone is answered.
I have this problem and can not find a way to terminate the call to the phone when the calling party hangs up before the phone is answered.
156
