Help configuring VIC-4FXO-M1 on MRP300
I've had a VIC-4FXO-M1 in my MRP300 for years and am finally getting around to needing it. I've upgraded the IOS to 123-7.XR6, but the IOS is not recognizing the FXO ports when I do "show version". No "voice-port" entries appear in the IOS config. When I type "show diag", the VIC is shown so I don't understand why I don't get "voice-port" entries in IOS. Please help! My only guess, based on scattered doc I've found, is that perhaps I need to purchase a PVDM-4 before I can get this working.
"show diag" output:
Packet Voice DSP Module Slot 0:
Not populated
Packet Voice DSP Module Slot 1:
Not populated
WIC Slot 0:
Four port FXO-North America/M1 Voice Interface Card
Daughter card-Version 4 TLV Cookie Format
Hardware Revision : 4.0
Part Number : 73-7119-04
Board Revision : A0
Deviation Number : 0-0
Fab Version : 03
PCB Serial Number : JAD06520SG1
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Top Assy. Part Number : 800-17617-02
Connector Type : 01
Product (FRU) Number :
1 REPLY
Silver
Re: Help configuring VIC-4FXO-M1 on MRP300
You have answered your own question - you need a DSP module to process the voice calls.
The PVDM-4 would only handle 2 ports, so you actually require a PVDM-8 (or 2 PVDM-4 modules) to support the 4 FXO ports.
119
