Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
How do we get the correct Serial Number for AS5300/5400 ?
Does anybody know how we can get the correct serial numbers for AS5300/5400 devices using a CLI command?
The Serial Number or the Processor Board ID listed in the "show version" doesn't seem to be the right one.
Thanks in advance,
SR
noc
Re: How do we get the correct Serial Number for AS5300/5400 ?
LA_gateway_2#sh chassis slot ?
<1-7> Slot number
detail Detailed slot information
| Output modifiers
You can do also a
5300#sh inventory
in this case it gives you all slots and you don't need to specify a slot.
You cn also try
Router#show diag
436
