how i can apply voice class codec at Dial-peer pots .....................??
how i can apply voice class codec 1 at Dial-peer 4 pots ????
dial-peer voice 4 pots
destination-pattern .T
progress_ind progress enable 8
progress_ind connect enable 8
translate-outgoing called 4
port 7/0:D
voice class codec 1
codec preference 1 g729r8
codec preference 2 g723r63
codec preference 3 g723r53
codec preference 4 g723ar53
codec preference 5 g711ulaw
codec preference 6 g711alaw
thank you for any helping.
Re: how i can apply voice class codec at Dial-peer pots ........
preference 1
Silver
Hi, this command is only for "voip" dial peers, it can't be used for "pots" dial peers.
Take a look at the command at:
http://www.cisco.com/en/US/docs/ios/12_3/vvf_r/vrg_v1_ps1839_TSD_Products_Command_Reference_Chapter.html#wp998755
Hope this helps, if so pls rate post
1204
