How to kill a voip call via SNMP
is there anybody knows how to kill a voip call via snmp.And also get the active call number on ip to ip gw.
Re: How to kill a voip call via SNMP
Well you can reload your voice gateway through SNMP.
As this is NOT what you want I am ssuming, please give more details about your scenario, which devices are involved, what is the problem etc.
Martin
Sure i dont wanna reload the rouer:).
I use an iptoip gw and wanna clear call via snmp.I dont remember the exact CLI command but the thing is that to kill a call you need the call ID shown with
show call active voice brief, and i cant find the snmp oid for this.
2316 : 245852 1520129134ms.1 +23890 pid:6 Answer 00492363359433 active
dur 00:26:49 tx:0/0 rx:0/0
IP 0.0.0.0:0 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8
in the output the call ID is 2316.
what you are looking for can hopefully be found in
"Equivalent MIB Objects for VoIP show Commands"
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a008048349c.shtml
Hope this helps
Martin
Hi I know this page.As you can see there is no SNMP OID for Call ID, thats the problem. May be there is another MIB for this but i cant find another usefull one. If you know another method that will also be usefull.
11D9 ?????? : 1102799(D1)hs.1 +1324 pid:2000(D2) Answer(D3) 2000(D4) active(D5)
dur 1d19h(D6) tx:7875641(D7)/157512782(D8) rx:7875955(D9)/157519081(D10)
Tele 2/0/0(D11):1: tx:157515460(D12)/157514630(D13)/0ms g729r8(D14)
noise:-56(D15) acom:5(D16) i/0:-40(D17)/-46(D18) dBm
Regards Deniz
Hi again,
I found the CLI command to clear a active voice call.
( clear call voice causecode 16 id !!! )
I know the oid you sent but its not the right id. It's global call id. So its not useable for this command. Do you know another method ?
if i found the correct oid, ı also have to find snmp euq. of the CLI command.
You can try writting a simple perl script and the Net::Telnet module to accomplish that, sometimes SMNP is not the best option available and you have to resort to other means such like this.
A related thread about Net::Telnet can be found here:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Service%20Providers&topic=Voice%20over%20IP&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dda805d
Regards.
For god's sake tell me what kind of cisco equipement and IOS you are using?
I need a way to clear voip calls and there is no suitable clear command for that on my AS5300 IOS 12.2(15)T14, and:
#clear call vo?
% Unrecognized command
It seems you ios is not supporting this command.My IOS version is 12.4.4T1.Try to upgrade ios.
601
