I can't hear music bell instead of ring backtone between G/W and CM
Hello all,
There is something wrong with my voip network.
I have callmanager(4.1) and Voice G/W(cisco2600).
When i try to make a call from IP Phone(7940) to Cellular Phone, I can't hear music bell. music bell is seviced by mobile telecommunication company. so if i make a call from PSTN Phone, i can hear music bell instead ring back tone.
anyway, if i try to make a call from PSTN's phone, i can hear music bell but not from IP phone.
PBX is NEC's NEAX made in japan.
heare is the output on voice gateway.
************************ Start call ***************************
g/w#
*Aug 3 11:35:05.399 KST: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0663
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x0081, '79876'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '90111234567'
*Aug 3 11:35:05.511 KST: ISDN Se1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8663
g/w#
*Aug 3 11:35:07.782 KST: ISDN Se1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8663
g/w#
g/w#
******** i can hear ring back tone, actually this is not corrent. i should hear music bell instead ring back tone
g/w#
g/w#
****************************** connect ************************************
*Aug 3 11:35:47.532 KST: ISDN Se1/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x8663
*Aug 3 11:35:47.548 KST: ISDN Se1/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0663
g/w#
************************** disconnect call *************************************
*Aug 3 11:35:55.316 KST: ISDN Se1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0663
Cause i = 0x8290 - Normal call clearing
*Aug 3 11:35:55.380 KST: ISDN Se1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x8663
*Aug 3 11:35:55.388 KST: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0663
g/w#
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31
interface Serial1/0:15
no ip address
no logging event link-status
isdn switch-type primary-net5
isdn protocol-emulate network
isdn incoming-voice voice
no cdp enable
voice-port 1/0:15
bearer-cap Speech
dial-peer voice 1 pots
tone ringback alert-no-PI
destination-pattern .T
no digit-strip
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 100 voip
destination-pattern 7....
session target ipv4:172.16.1.1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Re: I can't hear music bell instead of ring backtone between G/W
Hi all,
I've resloved this issue.
I've configured "progress_ind alert enable 8" command under pots dialpeer.
anybody explain the reason?
regards,
John.
Simply this:
You have 2 different signalling protocols that are communicating: H323 and ISDN and the difficulty with H323 on most Cisco routers is the inability to translate signalling and setup between disparate Telco ISDN switches, as there are many different brands and types of ISDN switches used at the CO, with various types of signalling capabilities. Therefore, the 2 entities (ISDN switch and Cisco H323 gateway) must establish communication by use of "progress tones," which are in-band tones such as busy signal, ring tone, and announcements across the 2 different protocols by the use of, what is called an Information Element or IE for short. This IE stores the Progress message, but some device along the way DOESN'T recognize it, so by using the progress_ind command for various Progress signals, (such as the alert, which is the one you used...) you are bypassing the intermediate devices that may NOT recognize and forward the Progress signal and allowing it to hit the H323 gateway directly....
146
