Incoming Modem call through CallManager based VoIP?
Is there a way to take a modem call on a CallManager based VoIP system? I have a T1 coming into a 6608 blade in a 6000 series switch. This blade is the gateway for my callmanager to the pstn. I'm wondering if there is a way to for the system to route a given DN to an FXO port that would have a modem attached. Currently all of my RAS lines are routed through our legacy pbx which drastically degrades the dial-in speeds.
1 REPLY
Re: Incoming Modem call through CallManager based VoIP?
I believe you will need one of these to allow the modem call. http://www.cisco.com/univercd/cc/td/doc/pcat/vg248.htm
196
