International calls don't work ....... ??????????????.............?????????
Dear any help for Dial Peer to international Calls i can not do any international calls .... i did these commands:
translation-rule 5
Rule 1 ^001 1
dial-peer voice 5 pots
numbering-type network
destination-pattern 00
progress_ind progress enable 8
progress_ind connect enable 8
translate-outgoing called 5
port 7/0:D
national calls are ok.
any help please to do dial peer for international calls?
thank you
Hall of Fame Super Gold
Re: International calls don't work ....... ??????????????.......
Take "debug isdn q931" with "term mon" and check.
Note you don't need:
Also if you need to translate number please use translation-profile and rules, not the older commands that are obsolete.
ok man,
i attached my debug files for Q931 but i saw many causes for drop calls (no route, unassigned number,...) see them please.
i don't know where the problem exact i moved the calls to other GW it worked fine, but when i use AS5400 as my GW the calls failed.
can advise for using translation-profile and rules i did not work before with these commands.
Just to be in mind i have local destination numbers i used to:
translation-rule 1
Rule 1 ^03 3
Rule 2 ^06 6
Rule 3 ^07 7
Rule 4 ^05 5
Rule 5 ^02 2
Rule 6 ^5050#9622 2
Rule 7 ^5050#9623 3
Rule 8 ^5050#9627 7
Rule 9 ^5050#9625 5
Rule 10 ^5050#9626 6
dial-peer voice 1 pots
destination-pattern .T
translate-outgoing called 1
port 7/0:D
now how i can use translation-profile and rules for those and international calls?
thank you for help.
Tareq
sorry this debug file
Hi, as mentioned above the problem is that you're setting numbering type network and you shouldn't:
Called Party Number i = 0xB1, '0019174687056'
Plan:ISDN, Type:Network specific
Leave "unknow" and it will work fine. See this document to about translation profile and rules. The ones that you have now, can be optimized a lot.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml
As an appreciation to those providing answers, please rate useful posts with the scrollbox below!
Here is a dial pattern that I know works:
destination-pattern 011T
port 0/0/0:23
prefix 011
The port number will be different for you based on your setup, plus if you have to dial a number to get an outside line you have to add that to the dest-patt, for example if you have to dial a 9 for and outside line it would be:
destination-pattern 9011T
Also you may want to talk to your telephone provider, ours (verizon) did not read our forwarded numbers correctly so the call would not go through. They had to make a change to fix it.
Hope this helps you, I had an issue when I set up our international dialing as well.
hi Shawn,
hust use those commands:
port 0/0/0:23
prefix 011
don't have to add translation rule for this dial peer for international calls?
if yes what best solution suggested for this translation rule.
BR.
242
