IOS Upgrade Min. Flash required
I want to make an IOS upgrade to an AS5400.
The GD IOS require 64 Mb Flash, but i have only 32Mb. The IOS that I have now and the one I want to upload are fitting in together. There is a problem if I upload the IOS ? What is with this minumum flash required?
Silver
Re: IOS Upgrade Min. Flash required
When there is some recommendations regarding Flash,it is always advisable to meet the requirements.Flash Required depends on the version of the IOS.Only if the recommended amount of flash is met performance would be good and additional featured would be available.
well - this I want to know - how more flash will improve the performance and will make the new features availlable ?
As I know the flash is only to store the IOS, scripts and other files. More RAM memory is usually improving the performance.
What is the difference if I have 32Mb flash and one IOS image, or 64Mb flash and 3 IOS images on it ?
114
