Community Member
IP Communicator will not use HP Soundcard for ring
I just migrated to a new HP DC7700 PC and installed my IP Communicator Software 2.0.2.0. Everthing works with one exception: I cannot choose the HP Realtek audio source for the ringer. The soundcard works fine and I can choose the realtek HD sound device inside the IP Communicator config screen but the audio tuning wizard will not see it as a choice for the ringer.
1 REPLY
Hall of Fame Super Red
Re: IP Communicator will not use HP Soundcard for ring
Hi Todd,
I think you are probably hitting this Bug;
CSCsb02511 Bug Details
Headline Add support for High Definition Audio devices
Product communicator
Feature Audio
Status Assigned
Symptom:
Cannot configure high Definition audio devices in Audio Tuning Wizard.
Conditions:
PC with High Definition sound card.
Workaround:
Manually tune audio devices from Volume Control in Windows OS.
This was nicely outlined by Ginger in the following thread;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dddbca2/0#selected_message
Hope this helps!
Rob
509
