IPIPGW and IVR authenticaiton
Has anyone tried IPIPGW with IVR authentication?
The call will come through a VoIP leg and terminated to another VoIP leg. Before completion, an IVR prompt will ask for PIN authentication.
Is this possible with IPIPGW?
thanks
Re: IPIPGW and IVR authenticaiton
yes it is possible: you can use the debit card cisco application, there is an example
INCOMING
dial-peer voice 1 voip
service calling_card
session protocol sipv2
session target sip-server
incoming called-number
dtmf-relay rtp-nte
fax rate 9600
no vad
OUTGOING:
dial-peer voice 1001 voip
destination-pattern [0-9]T
dtmf-relay rtp-nte
fax rate 9600
APPLICATION:
service calling_card flash:app_debitcard.tcl
param uid-len 9
paramspace spanish index 1
paramspace spanish language sp
param pin-len 0
paramspace spanish location tftp://x.x.x.x/prompts/sp/
param welcome-suppression no
paramspace spanish prefix sp
sip-ua
nat symmetric check-media-src
aaa username proxy-auth
sip-server ipv4:205.x.x.102
this example is with SIP protocol, if yiu want to sue with H323 you need disable the SIP PROTOCOL in each dial-peer
Thanks for the reply.
I am using IOS version 12.4(4)T1. Is there a specific version to enable service calling_card ? I don't have this command in the version I have.
Also, I guess I need DSPs to playou the IVR prompt. Right?
yah this is possible..i've been doing this for about 2 years.
218
