Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
IPIPGW H323-H323 IVR, DTMF, Digits not collected
Hi.
I have 2821 configured as ipipgw h323-h323 with app_debitcard tcl script.
Everything working fine. Voice prompts played, but when script asking for
pin number - digits do not get collected, no response when * or # pressed either.
Script times out 3 times and disconnects.
I have tried different dtmf-relay settings, nothing works.
When application is removed from dial-peer and call sent directly to termination
gateway, dtmf passed through on both legs and working fine when accessing voice mail on termination end.
System image file is "flash:c2800nm-adventerprisek9_ivs-mz.124-11.T.bin"
dial-peer voice 1 voip
service debitcard
incoming called-number .
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 2 voip
destination-pattern .
session target ipv4:10.10.10.10
dtmf-relay rtp-nte
codec g711ulaw
I can not find any solution or similar problem anywhere.
Please help.
Silver
Re: IPIPGW H323-H323 IVR, DTMF, Digits not collected
On the termination voice gateway the first line of the debug voip ccapi inout call trace as shown below will be a cc_api_call_setup_ind message with a peer_tag option that refers to the inbound VoIP dial peer on the termination gateway
I have same case here,
I configured my IVR system at AS5400 with IOS c5400-is-mz.123-10f.bin using tcl app_clid_4digits_npw_3.2.0.0.tc.I need to configure prepaid calling card using cisco pre-defined tcl script.
Tcl can play the prompts enter_account.au it is ok and I put my pin number as generated from my billing it is ok too… but when finished entering the correct generated pin number I heard 4 discontinuous tone not like busy tone and then the call disconnect and give me tone as you finished call or hang the speaker again for other call… the prompt enter_dest.au is not started I don't know why?
I attached my AS5400 configuration and its debug report.
Please any body show me where the error exact.
Thank you for any helping.
243
