IPT design
Now , there are 2 voice gateways and 1 CCM ,request some phones dial outside from VG1 ,and the other phones dial outside from VG2.How to design ?
1 REPLY
Re: IPT design
Well on what basis you need to route to different voice gateways?
If it is on a dialed prefix basis just configure different route patterns pointing to the VG.
If it is on a preffered gateway basis, you put them in a route group and then in a group list with priority for the preffered gateway, and when it´s exausted calls go to the second.I think you can also choose gateways in a round robin fashion so you can do load balancing if that is what you want.
BR,Teo
182
