ISDN CALLS NOT CONNECTING
knmezi
I'm trying to troubleshoot a cisco platform for voice calls, using an
ISDN PRI.
This should be a 10 digit local call. It does not complete if I
dial 1+ 10digits. (Seen at bottom)
I am a newbie in Cisco Voice products.
Here is my debug output.
layer3#
*Mar 24 03:16:06.092: ISDN Se1/1:23 EVENT: process_pri_call: call id 0x8007, num
ber 15672520826, Guid 503A29A38008, speed 0, call type VOICE, redial No, CSM cal
l No, pdata Yes
*Mar 24 03:16:06.092: ISDN Se1/1:23 Q931: Applying typeplan for sw-type 0x3 is 0
x2 0x1, Calling num 4047881723
*Mar 24 03:16:06.100: ISDN Se1/1:23 Q931: Applying typeplan for sw-type 0x3 is 0
x2 0x1, Called num 15672520826
*Mar 24 03:16:06.100: ISDN Se1/1:23 Q931: TX -> SETUP p
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x2180, '4047881723'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '15672520826'
Locking Shift to Codeset 6
Codeset 6 IE 0x28
*Mar 24 03:16:06.280: ISDN Se1/1:23 Q931: RX <- SETUP_ACK pd = 8 callref = 0x80
86
*Mar 24 03:16:06.284: ISDN Se1/1:23 EVENT: process_rxstate: ces/callid 1/0x8007
calltype 2 CALL_SETUP_ACK
*Mar 24 03:16:06.340: ISDN Se1/1:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x8
086
Cause i = 0x8090 - Normal call clearing
*Mar 24 03:16:06.348: ISDN Se1/1:23 EVENT: process_rxstate: ces/callid 1/0x8007
calltype 2 CALL_DISC
*Mar 24 03:16:06.352: ISDN Se1/1:23 Q931: TX -> RELEASE pd = 8 callref = 0x0086
*Mar 24 03:16:06.404: ISDN Se1/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0
x8086
*Mar 24 03:16:06.412: ISDN Se1/1:23 EVENT: process_rxstate: ces/callid 1/0x8007
calltype 2 CALL_CLEARED
8 Replies 8
mheusinger
Level 10
Level 10
this looks quite normal. Your router sends the telephone number '15672520826' to the telco switch. It gets it (RX <- SETUP_ACK) and then disconnects (RX <- DISCONNECT) with cause code "Cause i = 0x8090 - Normal call clearing".
So the real question is, why does your telco disconnect you, when you hand off the telephone number above? Is the telephone number dialed existing or what is the 11th digit doing? I am no specialist in numbering plans, but could it be that the leading "1" causes this? What is the telephone number format the telco expects?
Hope this helps
Martin
The following is the cofig my t1's are connect a PBX for calling cards then run thru IP: Ineed your help:
Building configuration...
Current configuration : 3276 bytes
version 12.4
hostname 3640
enable secret 5
enable password
clock timezone GMT 5
voice-card 1
ip subnet-zero
ip tcp path-mtu-discovery
ip cef
ip name-server 64.105.202.138
isdn switch-type primary-5ess
isdn voice-call-failure 0
voice service voip
signaling forward unconditional
cause-code legacy
sip
ds0-num
no call service stop
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g723r63
controller T1 1/0
framing esf
clock source internal
linecode b8zs
cablelength short 133
pri-group timeslots 1-24
controller T1 1/1
framing esf
linecode b8zs
interface FastEthernet0/0
ip address 72.x.x.x.255.255.248
speed auto
half-duplex
interface Serial1/0:23
no ip address
isdn protocol-emulate network
isdn incoming-voice voice
isdn supp-service name calling
interface Serial1/1:23
no ip address
interface Ethernet2/0
no ip address
shutdown
half-duplex
interface Ethernet2/1
no ip address
shutdown
half-duplex
ip default-gateway 72.x.x.137
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 72.214.194.137
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip route 72.x.x.x.255.255.248 72.214.194.137
ip rtcp report interval 100
access-list 100 permit tcp any any eq telnet
access-list 101 permit ip any any
access-list 102 permit udp any any range 16384 32767
access-list 103 permit tcp any eq 1720 any
access-list 103 permit tcp any any eq 1720
snmp-server community RO
control-plane
call filter match-list 1 voice
voice-port 1/0:23
voice-port 1/1:23
dial-peer voice 1 pots
service session
destination-pattern .T
direct-inward-dial
port 1/0:23
dial-peer voice 2 voip
service session
session protocol sipv2
session target ipv4:216.143.130.94
session transport tcp
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 4 pots
service session
direct-inward-dial
port 1/1:23
dial-peer voice 5 voip
service session
session target ipv4:216.143.130.92
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 6 voip
service session
session target dns:sip-server
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 7 voip
service session
session target ipv4:66.98.180.77
dtmf-relay rtp-nte
codec g711ulaw
gateway
timer receive-rtcp 10
timer receive-rtp 500
sip-ua
nat symmetric role active
nat symmetric check-media-src
retry register 10
sip-server dns:sip-server
line con 0
line aux 0
line vty 0 4
password
login
end
thank you for the config, but please also answer the questions above. As I said from your debug the router behaviour looks normal. You need to find out what the telco does not like about the telephone number dialed.
Martin
Can you tell us please why you're configured to emulate the network side of the PRI D channel? Usually this is taken care of by the switch you're connected to, and your side is left at the default, user.
Also, Please check with your provider to make sure the proper switch type is 5ess - you are receiving a setup_ack, which is weird for a circuit in the US. I believe that you would normally want to see a call proceeding follwed by an alerting from the far end, not a setup_ack unless this was PRI over an E1.
is there another callmanager system on the other side of this PRI? Why are you emulating the network side?
-Peter
My 2T1's are connected to a PBX not to a telco switch, I am sending my calls thru IP both in and out bound.
Thx. Knmezi.
Ah, this is news ;-)
Well the setup then depends strongly on the PBX configuration. Without knowing it it is hard to guess the proper settings.
Do you think switch-type 5ess is suitable?
Martin
The PBX switch-type is 5ess and the PBX vendor stated that it's suitable.
Knmezi
then have a look at the telephone number format the PBX expects, can you get information on this? Maybe you have to skip country code, maybe a leading 9 for long distance.
Hope this helps
Martin
