ISDN problem
HI all,
i have a problem with ISDN timeout on a VIC-2B-NT/TE and a 1751V.
I'm using the router as a voip / ISDN gateway, with ISDN setup in network mode.
Everithing is working fine except when i try to simulate a problem on NT network.
If i connect my ISDN phone on the router with correct MSN my phone work well (ringing, answer voice hangup etc...) but when i place the wrong one the phone correctly doesn't ring but the cisco router stuck.
The B-Chan where the router place the call is marked as used, with ISDN status i see the B-chan allocated with a CCB:
ISDN BRI1/1 interface
        ******* Network side configuration *******
        dsl 1, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        Layer 2 NOT Activated
    Layer 3 Status:
        0 Active Layer 3 Call(s)
        CCB:callid=8038, sapi=0, ces=1, B-chan=1, calltype=VOICE
    Active dsl 1 CCBs = 1
    The Free Channel Mask:  0x80000002
    Total Allocated ISDN CCBs = 1
this stay pending until i shutdown the bri interface.
On SIP server last message is a SIP 100 Try and no more.
It' seems that router wait forever for an answer on B-CHAN and
no timeout is coming.
This problem generically happen when Layer 1 Status is ACTIVE and there is no ISDN TE equipment that can answer the call.
I try to set up every isdn timers with no results.
This is my configuration:
Current configuration : 4846 bytes
version 12.4
service timestamps debug uptime
service timestamps log uptime
hostname
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
memory-size iomem 20
tdm clock bri-auto
voice-card 1
ip cef
ip name-server
isdn switch-type basic-net3
isdn tei-negotiation first-call
voice hunt user-busy
voice hunt no-answer
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice service voip
 sip
voice class codec 1
 codec preference 1 g729r8
 codec preference 2 g711alaw
voice translation-rule 1
 rule 1 /^0002200111$/ /\0/ type any unknown plan any unknown
 rule 2 /^0002200112$/ /\0/ type any unknown plan any unknown
 rule 15 /^.*/ /0002200111/ type any unknown plan any unknown
voice translation-profile CALLING
 translate calling 1
archive
 log config
  hidekeys
interface FastEthernet0/0
 ip address 10.150.1.4 255.255.0.0
 speed auto
 full-duplex
 hold-queue 100 out
interface BRI1/0
 no ip address
 isdn overlap-receiving T302 5000
 isdn protocol-emulate network
 isdn layer1-emulate network
 isdn incoming-voice voice
 isdn skipsend-idverify
 line-power
interface BRI1/1
 no ip address
 line-power
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.150.255.254
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
control-plane
call fallback active
voice-port 1/0
 translation-profile incoming CALLING
 output attenuation -6
 echo-cancel coverage 32
 compand-type a-law
 playout-delay nominal 100
 playout-delay mode fixed
 cptone IT
 music-threshold -70
 bearer-cap Speech
voice-port 1/1
 compand-type a-law
 cptone IT
 music-threshold -70
 bearer-cap Speech
dial-peer voice 1 pots
 preference 1
 destination-pattern 0002200111
 port 1/0
 prefix 0002200111
 no register e164
dial-peer voice 99 voip
 tone ringback alert-no-PI
 destination-pattern .T
 voice-class codec 1
 session protocol sipv2
 session target ipv4:10.150.1.1
 session transport udp
 dtmf-relay sip-notify
dial-peer voice 2 pots
 preference 2
 port 1/1
 prefix 0002200111
 no register e164
gateway
 timer receive-rtp 1200
sip-ua
 retry invite 4
 retry response 3
 retry bye 2
 retry cancel 2
 retry register 10
 timers trying 1000
 sip-server ipv4:10.150.1.1:5060
 connection-reuse
line con 0
line aux 0
line vty 0 4
end
Help me please
100
