Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
IVR on IP2IP
Are there any special requirements to play voice files (for IVR prompts) in an ip2ip gateway setup ? Since my incoming call uses g729 codec I will have to record prompts in g729? If yes, any particular software recommended ?
Thanks ...
1 REPLY
Silver
Re: IVR on IP2IP
The issue may be due to DTMF relay is broken on IP-IP GW Integrated in 12.3(11)T03 12.3(12.02)T. Long diatance calls do not allow to use DTMF due to this reason. Upgrading the IOS version may solve the problem.
115
