Community Member
MGCP using modem passthrough
I have a VG224 that a customer has and has troubles connecting with modems. Below is the config using MGCP, any ideas why users have to try to reconnect multiple times? Thanks.
mgcp
mgcp call-agent "IP" 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse <--passthrough right?
mgcp voice-quality-stats
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/
1 REPLY
Bronze
Re: MGCP using modem passthrough
If you need to configure fax pass-through to work with Cisco CallManager (CCM), you must use the modem passthrough nse command. The fax protocol pass-through command does not work with CCM, which relies on NSE information. Refer URL
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t11/faxapp/pt.htm#wp1088980
328
