Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Modem over IP speed
I am testing modem over IP using the modem passthrough feature across 3662 and 2651 gateways. The setup is fxo/fxs. It works fine except that the maximum connection speed is typically 14.4kbps, and very very rarely 19.2kbps.
Is it possble to get a higher dial-up speed over IP on Cisco platforms? Cisco says the modem passthrough feature supports modem speeds up to V90!
cheers!
Re: Modem over IP speed
Modem passthrough will support v.90 modems but you won't get near max speed out of them. You may get better results with the modem relay feature:
http://cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a00800f4c17.html
Hope this helps
Issues here are Codec related.for decent modem performance,Pass through is very bandwidth thirsty. Have you tried remoting your modem ?
i.e your terminal is one side of your wan and simply place the "local" modem at the far end of the link ?
then you only need create an async' link between the two end points. Modems will conect as fast as train sequence permits - and the data exchange is governed by your WAM and business limitations allow. One idea which works. Good Luck !
190
