Multiple IP interfaces for voice on AS5350 ?
HI ALL!
Our equipment: AS5350 IOS 12.2(2) XB10
We are try the following config
interface Loopback0
ip address 192.168.6.18 255.255.255.248
h323-gateway voip bind srcaddr 192.168.6.18
interface FastEthernet0/0
ip address 1.1.1.1 255.255.255.252
ip access-group VoIP-RTP in
ip route-cache flow
duplex full
speed 100
h323-gateway voip interface
h323-gateway voip h323-id 5350
But Cisco not allowed to use
h323-gateway voip bind srcaddr for fa0/0
simultaneously with lo0
OR
h323-gateway voip interface for lo0
simultaneously with fa0/0
Plz help for our subj ?
Re: Multiple IP interfaces for voice on AS5350 ?
Help, plz!!!!!!!!!!!!
The simple answer is that you will have to pick one interface to use to define your h323 inteface. Your router cannot present itself as two differnt devices. Let me take one the following configuration and explain it further.
What this command is instructing the router to do is to source all h323 traffic from the interface it is configured under (in this case the loopback) The reason for this is that you want to guarantee that rtp packets from a voice flow are always sent and received through the same interface. This alleviates the problem of one way audio where you have rtp traffic destined for an interface that the remote side may not be able to route to.
In either case, if the router allowed you to bind h323 traffic to multiple interfaces, you would in essence be creating the same scenario that the command was designed to fix.
The bottom line is that the gateway can only have a single h323 id as well as only a single interface to bind h323 traffic to.
148
