Community Member
Mutliservice gateway for SIP configuration
Can someone help me out in giving SIP configuration in the 7200 Router when used as Multiservice gateway.
Connectivity is as follows
Remote SIP gateway(IP1)--->7200 router(multiservice gateway)(IP2)-->SIP Gateway(IP3)
There will be two RTP Sessions
IP1 to IP2
IP2 to IP3
Srikant
1 REPLY
Silver
Re: Mutliservice gateway for SIP configuration
Configuring SIP is same in all type of routers , It only depends upon which kind interface you have to configure for
Some sample configurations are available in the following link:
http://www.cisco.com/univercd/cc/td/doc/product/voice/sipsols/
177
