Community Member
My FXO port is disconnection
Hi, I have a 1700 (12.2(4)T3) with FXO ports and when I call the extension connected to it, first it gives tone, but after it disconnect. Any help ?
Thank you !
Community Member
Re: My FXO port is disconnection
I am assuming your FXO port is connected to the jack for a line from PSTN? You call that line and the caller hear a tone and disconnects? Can you describe the topology and relevent config?
Community Member
Thanks for your replay.
My FXO ports are connected to PABX directly in extension ports, so when I call these extension's numbers I should give me the tone. In my case, I got this tone, but suddenly, it stops and gives busy
tone.
Cleber
Silver
FXO port is supposed to give dialtone when it is called. You need to configure connection plar under the fxo port :
connection plar 1234
where 1234 is the number you want the call to go to.
Taimoor
178
