You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Need help with Dial-peer, CODEC and PRI configuration
Hello
I have a Cisco 3620 gateway with NM-HDV-2T1-24E module. I also have ISDN PRI/T1 line from ATT Canada.
Now Telco provided the following info:
Our Standard ISDN PRI will be:
Coding: B8ZS
Framing: ESF
Protocole: NI-1
Switch: DMS-100.
Now I can configure the ISDN Switch type and Coding and Framing but what bout the protocol NI-1. How do I configure that?
2nd, My gateway can reach 416, 905 and 647 area code. I have two T1 Controller and TWO ISDN PRI/T1 line. 2nd T1/PRI is not in yet.
If U want to create a dial-peer...for such area code, how do I can configure my Controller T1 interface
Controller t1 1/0
pri-group timeslots 1-24
(it created interface Serial1/0:23, what happen to other channel, or does this refer to all the channel).
Under dial-peer command, using the port should I refer to serial 1/0:23 as a pstn port.
dial-peer voice 416 pots
destination-pattern 416T
port serial 1/0:23 (is this how to do it)
Any help in this would be great.
Faisal
  • Voice over IP
Re: Need help with Dial-peer, CODEC and PRI configuration
The switch type is all you have to worry about. Configure the switch type as dms100 in your D channel interface.
When you create pri-group timeslot 1-24 it creates the D channel interface which will control all your bearer channels as well. You can see that by doing show isdn services.
You dont have to create separate dial-peers for separate area codes but if you do want to then you can point all those to the same controller i.e. assign the same port to all the dial-peers. What you have is almost correct, the correct format would be :
port 1/0:23
Note that 416 wil be stripped unless you put prefix 416.
Hope that helps
Thanks a lot. I really appreciate it.
325
