NM-HDV DSP Problems...
Dear Friends
I have a Cisco 3640 with NM-HDV-2E1-60 module with VWIC-2MFT-E1.
The ios image is c3640-js-mz.123-19.bin and version is 12.3
I have a strange problem with the NM-HDV module.
I make the calls then these calls connect and after 2-3 seconds they drop, and the module doesn't free the channel, the channel stays busy...
All the lights on the nm-hdv dsp light up green.
I've tried to test the dsp's issuing the test dsp 0 command and then querying the dsp resource and status and it shows up the following
Dsp firmware version: 4.1.41
Maximum dsp count: 15
On board dsp count: 15
Jukebox available
Total dsp channels available 60
Total dsp channels allocated 60
Total dsp free channels 0
Querying dsp status......
It doesn't show the dsp status...
test dsp 1 (2, 3) commands say that Card 1 (2, 3) is not present.
How can I be 100% that the problem is because of the DSP's (if it is like that)
I'm saying this because I can buy new DSP's and change them, but I need to be 100% sure...
Any reply is appreciated!
Re: NM-HDV DSP Problems...
The issue could be with the DSPs, but the querying dsp status is not an issue. It is the normal behavior.
Thanks for your reply.
I've done some tests and here's the result.
c3640_gw2# show dialplan number 12345678911
Macro Exp.: 12345678911
VoiceEncapPeer1
peer type = voice, information type = voice,
description = `',
tag = 1, destination-pattern = `111+',
answer-address = `', preference=0,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
source carrier-id = `', target carrier-id = `',
source trunk-group-label = `', target trunk-group-label = `',
numbering Type = `unknown'
group = 1, Admin state is up, Operation state is up,
Outbound state is up,
incoming called-number = `', connections/maximum = 1/unlimited,
DTMF Relay = disabled,
huntstop = disabled,
in bound application associated: 'DEFAULT'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
Translation profile (Incoming):
Translation profile (Outgoing):
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
type = pots, prefix = `11',
forward-digits default
session-target = `', voice-port = `0/0:0',
direct-inward-dial = disabled,
digit_strip = enabled,
register E.164 number with GK = TRUE
fax rate = system, payload size = 20 bytes
supported-language = ''
Time elapsed since last clearing of voice call statistics never
Connect Time = 1876, Charged Units = 0,
Successful Calls = 12, Failed Calls = 5, Incomplete Calls = 0
Accepted Calls = 0, Refused Calls = 0,
Last Disconnect Cause is "AC ",
Last Disconnect Text is "dsp error (172)",
Last Setup Time = 241131.
Matched: 12345678911 Digits: 3
Target:
So it seems that the problem is really in DSPs.....
Have you put DSP resource into Transcode, MTP or Conf usage?
Well the NM-HDV module is connected to a PSTN so my guess, the DSP usage is used for transcoding.
843
