No return ISDN code ?
23F4 : 339132627hs.783352 +-1 +1303 pid:2 Answer 62844795
dur 00:00:00 tx:119/2361 rx:610/12200 10 (normal call clearing.)
Telephony 1:D:783358: tx:7990/799/0ms g729r8 noise:0dBm acom:0dBm
23F4 : 339132627hs.783353 +-1 +1340 pid:964 Originate 19276562841686
dur 00:00:00 tx:0/0 rx:127/2502 0 ()
IP x.x.x.x:16480 rtt:0ms pl:2240/40ms lost:0/1/0 delay:69/69/70ms g729r8
Hi I made a test call and found out there is no isdn return code for the 2nd leg. Can anybody assist plz?
Re: No return ISDN code ?
Hello.
What are you typing ? sh call active voice br or
sh call hist voice br.
I suppose that active voice and so you's second leg
is not disconnected yet.
Look at the duration 00:00:00 so you didn't receive
connect and how I suppose PSTN side give out
disconnect with PI=1.
Hi...Only "sh call hist v bri" can see the isdn code. not "sh call act v bri"
158
