By the way:
sh ver
IOS (tm) 5300 Software (C5300-IS-M), Version 12.3(19), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Thu 11-May-06 23:15 by evmiller
Image text-base: 0x60008AEC, data-base: 0x6162A000
ROM: System Bootstrap, Version 12.0(2)XD1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc
1)
BOOTLDR: 5300 Software (C5300-BOOT-M), Version 12.0(4)T1, RELEASE SOFTWARE (fc1
DAL-VoIP-TDM-1 uptime is 11 weeks, 4 days, 1 hour, 45 minutes
System returned to ROM by reload at 14:08:55 CDT Wed Jun 14 2006
System restarted at 15:41:04 CDT Fri Sep 15 2006
System image file is "flash:c5300-is-mz.123-19.bin"
cisco AS5300 (R4K) processor (revision A.32) with 131072K/16384K bytes of memory
Processor board ID 25487304
R4700 CPU at 150MHz, Implementation 33, Rev 1.0, 512KB L2 Cache
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
Backplane revision 2
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x30,
Board Hardware Version 3.2, Item Number 800-2544-04,
Board Revision B0, Serial Number 25487304,
PLD/ISP Version 0.0, Manufacture Date 12-Apr-2001.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
32 Serial network interface(s)
4 Channelized T1/PRI port(s)
48 DSP(s), 96 Voice resource(s)
128K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
8192K bytes of processor board Boot flash (Read/Write)
