ns
No VoIP forwarding on incomming calls on PRI on AS5350
Hi we have a problem with VoIP calls not being routed. The call is supposed be a GW to GW call and we can't even see the call being registred as a VoIP call. We get a Requested circuit/channel not available error on the ISDN debug. No h323 packet exits the gateway. Incomming calls from Internet works, though.
The IOS version we are using is 12.2(2)XB5, config:
interface FastEthernet0/0
ip address xx.xx.xx.xx 255.255.255.224
no ip redirects
no ip proxy-arp
duplex full
speed 100
no cdp enable
h323-gateway voip interface
h323-gateway voip id GK-1-AraT ipaddr xx.xx.xx.xx
h323-gateway voip h323-id gw-1-madrid
h323-gateway voip bind srcaddr xx.xx.xx.xx
interface Serial3/4:15
no ip address
no snmp trap link-status
isdn switch-type primary-net5
isdn timer t321 40000
isdn protocol-emulate network
isdn incoming-voice modem
isdn T310 60000
isdn send-alerting
isdn sending-complete
no isdn outgoing display-ie
fair-queue 64 256 0
no cdp enable
dial-peer voice 1006 voip
destination-pattern 00%
progress_ind connect enable 2
translate-outgoing called 8100
voice-class codec 3
session target ipv4:xx.xx.xx.xx
We can ping the session target. We are at a loss here and have looked in and searched the CCO and nothing works.
Any help will be much appreciated.
Niels
1 REPLY
Re: No VoIP forwarding on incomming calls on PRI on AS5350
Your problem is in the destination-pattern of the dial-peer.
Percent sign (%), which indicates that the previous digit/pattern occurred zero or multiple times, similar to the wild card usage in the regular expression.
You should have destination-pattern 00T. Also, after you receive the call on the isdn side you should verify with show call history voice brief. You should see two call legs : one listed with pid:X (where X is the dial-peer for pots) and one with pid:1006.
Anyway, your pots dial-peer should look like this
dial-peer voice 1 pots
application your-iwr-appl (or session)
port 3/4:D
so you get the call answered when calling from the pstn side :)
146
