No-way audio
Hi All,
I am trying to test voice loopback call between Cisco 3725 (with VWIC-1MFT-E1 and AIM-VOICE-30) and Hicom150E. The signalling used is primary-net5. After configuration, the call can be established but no-way audio occurs. Neither does caller hear the ringback tone. I tried installing these 2 modules into Cisco 2620XM, configured the same as 3725 and it worked fine.
Thinking of Cisco 3725 IOS issue, I also tried some other IP Plus versions but the problem still persist.
Any idea, please help.
Thanks.
Re: No-way audio
Do you have configure the AIM-VOICE card to pertcipate within the clock?
You can make calls to all phones = signaling between phones work.
But no ringback or audio in phones = DSP problem!
Check the commands:
network-clock-participate...
network-clock-select...
voice-card 0
dspfarm
Re: No-way audio
Thank you for your help. It works fine now.
Re: No-way audio
Trongduc,
I have the same problem. Could you please let me know how you fixed it?. I have loaded different versions of IOS IP Plus same problem all of them.
Re: No-way audio
It result from one issue b/w Cisco 3725 IOS and WICs on slot 0 only. In order to solve it, the workaround is to issue the command "fair-queue" into the serial interface which is a member of the Multilink.
Hopefully, new IOS releases in the near future will solve it.
Let me know if any.
Duc
Re: No-way audio
My previous email is related to QoS which probably happens to Cisco 3725 router w/ WICs on slot 0.
For your concern, pls add the following commands in global configuration mode:
network-clock-participate wic 0
network-clock-participate aim 0
network-clock-select 1 E1 0/0
Hope it helps.
Duc
558
