Not receiving all digits from FXS device
carllougher
I've got a fax machine plugged into an FXS port on a 2800 router.
Inbound fax works fine but when dialling a destination number on an outbound fax call I only receive the first digit.
Qu:
Is the router processing the call before all digits are presented?
Is there a way of delaying the digit collection before sending to the router?
Outbound Call path:
Fax > FXS > router > Sip server > Isdn gateway
If I manually overide the digits with a destination number on a translation rule it works a treat.
Any clues?
6 Replies 6
iostres
Can you show us your dial-peer config?
Ivan
voice call send-alert
no voice call carrier capacity active
voice rtp send-recv
voice class codec 10
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g711alaw
voice-port 0/0/0
bearer-cap Speech
voice-port 0/0/1
bearer-cap Speech
voice-port 0/1/0
bearer-cap Speech
voice-port 0/1/1
bearer-cap Speech
voice-port 0/2/0
description fax fxs port
bearer-cap Speech
station-id number 900
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
dial-peer voice 1 pots
description Inbound PSTN to SIP Server
incoming called-number .T
direct-inward-dial
dial-peer voice 3 voip
description Inbound SIP calls to SIP Server
huntstop
destination-pattern .
voice-class codec 10
session protocol sipv2
session target ipv4:xx.xx.xx.xx:5060
session transport udp
dtmf-relay rtp-nte
no vad
dial-peer voice 102 pots
description Outbound SIP calls to FXS
destination-pattern 900
port 0/2/0
forward-digits all
sip-ua
retry invite 3
retry response 3
retry bye 3
retry cancel 3
timers trying 1000
sip-server ipv4:xx.xx.xx.xx:5060
Number dialled 771xxxxxxxxxx
Collected called number only shows up as 7 and therefore misses the other digits.
rfp-rtr-02#sh call active voice
Telephony call-legs: 1
SIP call-legs: 1
H323 call-legs: 0
MGCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 2
GENERIC:
SetupTime=-1503182656 ms
Index=1
PeerAddress=900
PeerSubAddress=
PeerId=102
PeerIfIndex=26
LogicalIfIndex=16
ConnectTime=0
CallDuration=00:00:00 sec
CallState=3
CallOrigin=2
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
TELE:
ConnectionId=[0x1BA1EF9D 0xD06F11DA 0x8C6A9B72 0x9FBCAEB3]
IncomingConnectionId=[0x1BA1EF9D 0xD06F11DA 0x8C6A9B72 0x9FBCAEB3]
CallID=2838
TxDuration=0 ms
VoiceTxDuration=0 ms
FaxTxDuration=0 ms
CoderTypeRate=None
NoiseLevel=0
ACOMLevel=0
OutSignalLevel=0
InSignalLevel=0
InfoActivity=0
ERLLevel=0
SessionTarget=
ImgPages=0
CallerName=
CallerIDBlocked=False
OriginalCallingNumber=900
OriginalCallingOctet=0x0
OriginalCalledNumber=
OriginalCalledOctet=0x80
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0x0
TranslatedCallingNumber=900
TranslatedCallingOctet=0x0
TranslatedCalledNumber=
TranslatedCalledOctet=0x80
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0x0
GwCollectedCalledNumber=7
GwReceivedCallingNumber=900
GwReceivedCallingOctet3=0x0
GwReceivedCallingOctet3a=0x0
SIP call-legs: 0
H323 call-legs: 0
MGCP call-legs: 0
Total call-legs: 1
Try changing "destination-pattern ." to the "destination-pattern .T" on your voip dial-peer.
Ivan
I have previously tried that but still no go.
Do you think its anything to do with timeouts on the fxs port?
When using .T interdigit timeout should be 10 seconds by default and that seems long enough for any fax machine I've ever seen. I have a feeling that something else is wrong here - can you please get the "debug voice dialpeer all" for a call. I would like to check if we're hitting the right dial-peer.
Ivan
