One way voice issue,Problem detected but still no solution
I'm using cisco3825 as a voice gateway with concerto dialer software for outbound dialing for a call center.Agents are facing voice problems :like they can hear the customer but customer can't hear them.But it's not for all the agents at a time.
I tried out and found some logic.Dsp resources which are using g711ulaw tx is 0, so voice no transmit.However no issue with g729r8 codecs
Attaching my voice cofig and output.
Is there any way only g729 codec use no g711 ???I'v tried several options but still not found any solution.
Sourav
  • Voice over IP
1 REPLY
Anonymous
N/A
Re: One way voice issue,Problem detected but still no solution
what version of IOS are you using?.
111
