One way voice
Hi All,
We have a VoIP over VPN implemented in Hub&Spoke model. Hub has a 3640 connected directly to ISP provided router(which we do not have control-768Kbps) and one spoke is in NYC and another is in India. We are using Altagen software PBX server & IP phones connected to a basic unmanaged switch at Hub location. Both the BO routers are making DES VPN connection to Hub.
1.Spoke router@india directly connected to Internet through its serial Interface and the cpu is reaching around 45% at peak.
2.Spoke router at NYC has the same kind of connectivity as Hub.
Here are the sample configurations:
HUB:
c3620-jk9s-mz.122-13b.bin
interface Ethernet0/0
Description CONNECTED TO INTERNET ROUTER
ip address <IP Address>
ip nat outside
no ip route-cache
no ip mroute-cache
half-duplex
no mop enabled
fair-queue 512 256 64
ip rsvp bandwidth 1000 1000
crypto map rtp
interface Ethernet0/1
Description CONNECTED TO INTERNAL NETWORK
ip address 192.168.254.1 255.255.255.0
ip nat inside
half-duplex
no mop enabled
INDIA:
interface Tunnel0
no ip address
ip address 192.168.250.1 255.255.255.0
ip nat inside
full-duplex
interface Serial0/0
bandwidth 512000
ip address 203.197.130.77 255.255.255.252
ip nat outside
no ip route-cache
no ip mroute-cache
ip rtp priority <port range> 384
crypto map rtp
The problem here is the voice calls between Hub and NY spoke is good, but the between Hub and another spoke (India) the voice from Hub to spoke ndoesn’t pass properly where as from India to Hub location is good irrespective of the origin of the call.
Thanks in advance
MS
Anonymous
N/A
Re: One way voice
If using Network Address Translation (NAT), the minimum software level requirements must be met. Earlier versions of NAT do not support skinny protocol translation and will lead to one-way voice issues.The following document is good for troubleshooting oneway voice issues.
http://www.cisco.com/warp/public/788/AVVID/fix_1way_voice.html
Re: One way voice
Thanks alot for the reply and sorry for the delayed response. The problem was due to a virus effected PC trying to kill all WAN bandwidth.Everything is working fine now.
Thanks a Mil
Mehboob
770
