per call bandwith requirement for VoIP call
Hi, I am working in IP Telephony service sector in bangladesh. I need know per call bandwith requirement(kbps) for Ip voice call. what is its max & min value? pls discribe.
here is a great doc which
here is a great doc which explains the bandwidth per call
http://www.cisco.com/c/dam/en/us/support/docs/voice/voice-quality/7934-bwidth-consume.pdf
Depends on which codec you
Depends on which codec you are using:
G.711 uses 80kbps per call
g.729 uses 23kbps per call (i think)....
Bandwidth usage is a function
Bandwidth usage is a function of the codec used. I am also using it for my business purpose. If you want you can go here and find more about it.
157
