11-29-2007 06:06 PM
Hi all,
I have a solution that connect 2 pgw's with one as5400, the TDM switch that have ss7 are connected to the as5400, and they use the TS 1 for signaling, I have configured my as5400 e1 as follow:
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31 nfas_d primary nfas_int 0 nfas_group 0 rlm-group 0 !
interface Serial1/0
no ip address
interface Dchannel1/0
no ip address
encapsulation hdlc
isdn incoming-voice modem
no isdn send-status-enquiry
isdn negotiate-bchan resend-setup
no cdp enable
My questions are 2:
1.- how to change the ts 1 to be used for signaling mode instead of use 16?
2.- I'm using nailed mode, so, do I have to create all trunks in my pgw? and also have to create my d channels in the pgw?
Hope that you can help me
12-03-2007 11:35 AM
You will need to create a channel group for TS1 since this is considered and integrated SLT setup:
http://cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a00800b6ab9.html
Hope this helps
12-08-2007 04:32 AM
The reply of Crieman was obviously useful, so I vote for it instead of the guy who asked the qusetion.
