PGW2200 Signalling Controller ACM optional parameters
We are using PGW as signalling controller(not call controller) with AS5400XMs. We have a strange problem with disconnect cause value(cv) 1 (unallocated number). According to ITU-T q767 for cv 1 when an operator sends a call to your network and if call gets cv1 either you have to send REL to a received IAM or you should send ACM with in-band information indicator. This enables operators anouncement "you have dialed wrong number" etc. But our PGW mappes ISDN to SS7 signals and sends automaticly ACM to call_proc message at ISDN part. But according to the table in the following link
http://www.cisco.com/en/US/products/hw/vcallcon/ps2152/products_tech_note09186a00801ffb5a.shtml
ACM must go after ISDN alerting message. But in our PGW doesnt???
So what can be the congfiguration error or bug for this? I need either inband information indicator in ACM message or not to send ACM for cv 1 calls.
Thanks in advance.
Deniz
1 ACCEPTED SOLUTION
Re: PGW2200 Signalling Controller ACM optional parameters
While not exactly related, I have seen something similar in regards to this. In properties.dat there is a *.FastConnect. It defaults to 0 I believe. A setting of 1 or 2 may help you here. If you change it this way you will need to restart the software. Alternatively you can set it on the individual SigPath.
see this link for several possible solutions: http://www.cisco.com/en/US/products/hw/vcallcon/ps2152/products_tech_note09186a008025fa96.shtml
I hope this helps.
John Spade
webVoIP
I hope this helps.
John Spade
webVoIP
Thanks for your message. Actually i found that page and change the parameter for every naspath in PGW and worked already! Thanks anyway.
Regards.
What value did you change it (1 or 2) to as I have similar problem but I have not made such changes.
Thx
I made it 1, and options are 0 or 1 i think there is not any option 2.
287
