Pre-paid IVR Problem
We have one AS5350 conected to the local pstn and I would like to test its prepaid features, I have followed all the instructions of the "Cisco Pre-Paid and OSP Config Guide" but I have some doubts because we always receive the en_invalid_digits.au message ("You have entered an invalid number of digits, please reenter your card number...) after enter a correct card number 3 times and then the call is disconnected, why?
I am using several scripst for test:
debitcard-multi-lang-Cisco.1.1.0.2.tcl
debitcard.1.1.3.tcl
app_debitcard.2.0.0.tcl
I don´t known if I have to configure other issues in radius server like some other attributes in my users file... to test this freeradius configuration I am using "clid_authen_collect" and "app_debitcard.2.0.0.tcl" scripts and the authentication works well with those scripts!!!
PS: config details:
(C5350-IS-M), Version 12.2(2)XB6
no boot startup-test
aaa new-model
aaa authentication login h323 group radius
aaa authentication login NONE none
aaa authorization exec h323 group radius
aaa accounting connection h323 start-stop group radius
aaa session-id common
enable secret xxxxx
username xxx password xxxx
gw-accounting h323
gw-accounting h323 vsa
gw-accounting voip
interface FastEthernet0/0
ip address x.x.x.x 255.255.255.224
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip id GKMain ipaddr y.y.y.y 1719
h323-gateway voip h323-id micpegw01
h323-gateway voip tech-prefix 9
h323-gateway voip tech-prefix 044
h323-gateway voip tech-prefix 074
radius-server host 172.16.2.20 auth-port 1812 acct-port 1813
radius-server retransmit 0
radius-server key xxxx
radius-server vsa send accounting
radius-server vsa send authentication
call rsvp-sync
call application voice debit tftp://172.16.2.20/debitcard/debitcard-multi-lang-Cisco.1.1.0.2.tcl
call application voice debit uid-len 9
call application voice debit pin-len 7
call application voice debit language 1 en
call application voice debit language 2 sp
call application voice debit set-location en 0 tftp://200.110.2.130/debitcard/prompts/en/
call application voice debit set-location sp 0 tftp://200.110.2.130/debitcard/prompts/sp/
call application voice callc tftp://172.16.2.20/TCLware201/app_clid_authen_collect_cli.2.0.0.tcl
call application voice callc language 0 sp
call application voice callc set-location sp 0 tftp://200.110.2.130/TCLware201/prompts/sp/
voice-port 3/0:0
compand-type a-law
mgcp profile default
dial-peer cor custom
dial-peer voice 1000 voip
destination-pattern 660....
session target ras
codec g723r63
dial-peer voice 1 pots
destination-pattern .T
translate-outgoing calling 1
direct-inward-dial
port 3/0:0
dial-peer voice 2 pots
application debit
incoming called-number 6601997
destination-pattern 6601997
port 3/0:0
dial-peer voice 3 pots
application callc
incoming called-number 6605001
destination-pattern 6605001
port 3/0:0
dial-peer voice 1002 voip
description ld->USA
huntstop
destination-pattern 001..........
session target ipv4:65.200.X.Y
tech-prefix 550#
codec g723r63
dial-peer voice 1001 voip
description CALLCENTER
destination-pattern 10.
session target ras
codec g723r63
  • Voice over IP
Silver
Re: Pre-paid IVR Problem
When there is not enough money or no money in an account, the as5300 will still place the call and then immediately disconnect. Is this why you are facing the problem. there is also one related bug on this CSCdp67360. Check out the details.
It expects specified number of digits (i.e UIDLen + pinLen), In your case it expects 16 digits. It won't forward to radius, until it receives all 16 digits.
Santosh
163
