Community Member
Pre-Sales query for Voice product
Hi Team,
We have a customer who wants to go for VOIP. He is currently running an Alcatel PABX
The requirements are
1) Users - 200
2) Free Calls between HQ and Branch
3) Voice Mails to be Delievred in Users Inbox
4) Send Fax from the Users machine.
Can I achieve the above using a CME . If yes then which model and IOS should I opt for? What should the PVDM requirement be?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Yes, you can do that with CME.
For an accurate design, you should get in touch with a reputable consultant, or UC certified Cisco partner.
The alternative is that you read and stufy the avaialble documentation on cisco.com. However doing so you risk to wast much time, and not get good results.
Community Member
Thanks Paolo , Appreciate your timely reply.
I have configured a CME before but only that it wasnt this big a setup.  I will check for resources on Cisco.  In Case of any doubts will get back to you / Team. Thanks mate !!!
Thank you for the nice rating and good luck!
881
