Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Preparing for 642-432
Which configuration defines a destination pattern for all of the 1000 and 2000 range of extensions starting with the numbers 555?
A. 555[1-2]
B. 555[1000-2000]
A. or B.???
Re: Preparing for 642-432
If thats on the gateway i would use:
5551...
If thats on the CCM route patterns i would use:
555[1-2]XXX
Hi Saif,
It will be B as you are lookin for destination patterns.
Saif,
I think in option A it should be 555[1-2]...(this will work on ISR CME version) for supporting all the extentions in 1000 and 2000 range
hth,
Dev
why r we adding ... to option A go with question its not there
109
