Problem with DTMF
I am trying to establish link between A and B subscribers calling from
GSM network through the Call Controller installed in IP enviroment.
In below scenario, subscriber A makes the call to number 123456789. After this,
Call Controler sends INVITE requests to the subscriber A and Cisco Gateway ( 188888888 )
to establish voice path between them. Everythig is fine in this step, because A subscriber
is able to hear a specific prompt.
However, Call Controler sends in turn new INVITE requests to the subscriber B and
Cisco Gateway to establish voice path between them. After subscriber B is connected to
the gateway and prompt is played, when B is asked for putting DTMF code to agree to
be charged for connection with subscriber A. Unforunately, something is happening wrong,
because error is being returned during the DTMF attempt. It looks like bad stream would be read then and
the VXML script is stoped after this.
Please let me know what is wrong, if there is a possibility to catch DTMF string
only one way, when the call is originated from GSN network. However when the call is originated
from gateway and the subscriber needs to pick up call and put DTMF code, the vxml script is broken.
Please notice that a specific VoIP dial peer is configured for connecting to mobile network.
Hope, the catched log and basic script will are helpfull to find out the problem.
*Jan 30 01:48:43.746: //3541/3043089791F8/VXML:/vxml_digit_collection_done:
digits ()
name ()
*Jan 30 01:48:43.746: //3541/3043089791F8/VXML:/vxml_bind_lastprompt:
*Jan 30 01:48:43.746: //3541/3043089791F8/VXML:/vxml_digit_collect_process:
vxmlp 66680A90 status 2 async_status 60000
*Jan 30 01:48:43.746: //3541//AFW_:/vapp_session_exit_event_name: Exit Event vxml.session.error
*Jan 30 01:48:43.746: //3541/3043089791F8/VXML:/vxml_vapp_terminate:
vapp_status=2 ref_count 0
CALL_ERROR; http://xxx.yyy.zzz.aaa:10000/incomingCall.do?session.telephone.dnis=188888888&session.telephone.ani=1111
vxml session terminating with code=ERROR
vapp status=VAPP_FAIL vxml async status=VXML_ERROR_VAPP
<?xml version="1.0"?>
<vxml version="1.0">
<property name="bargein" value="true"/>
<form>
<property name="timeout" value="10s"/>
<field name="dtmfString" type="digits?length=1">
<prompt>
<audio src='http://xxx.yyy.zzz.aaa:10000/audio/press1or2_ulaw.wav'/>
</prompt>
<filled>
<submit next="questionPlayed.do;jsessionid=3nkdtmpv57b8r" namelist="dtmfString" />
</filled>
</field>
</form>
</vxml>
My dial-plan is the following:
########### Inband dial peer for the Multi-Party Call Control service #########
dial-peer voice 100 pots
service session
incoming called-number 123456789
direct-inward-dial
port 7/0:D
######## Call is being forwarded towards to Call Controler to manage connection and next redirected to target dial peer #################
dial-peer voice 2000 voip
service session
destination-pattern 123456789
session protocol sipv2
session target ipv4:aaa.bbb.ccc.ddd:5060
dtmf-relay rtp-nte
codec g711ulaw
no vad
######## VoiceXML script is started to handle the call ################
dial-peer voice 1000 voip
service mpcc_test
incoming called-number 188888888
dtmf-relay rtp-nte
codec g711ulaw
no vad
########### Outband dial peer for Multi-Party Call Control service #########
dial-peer voice 101 pots
service session
destination-pattern 1........
no digit-strip
port 7/0:D
Thanks in advance,
1 REPLY
Silver
Re: Problem with DTMF
DTMF tones it sends an skiny packet to the ip phone or an h323 packet to the gw and the tones are generated locally. Because voice is streamed between the ip phones and gw directly if there would be a inbound dtmf ccm would not know about it as it is not involved in the stream.
379
