Community Member
Problem with Extension Mobility Error 3
Hi @all.
I have a problem with the EM-service for CCM 3.3(2) SPC
It already worked fine. After creating some Device Profiles it is not possible to log-in on the phone.
The phone shows Error [3]. Internal calls work fine.
Does anybody have an idea?
Thanks a lot
Thomas
Bronze
Re: Problem with Extension Mobility Error 3
Hi Thomas
I had the problem that the profile has not been loaded on the phone anymore. Do you have the same problem?
What happens when you do a manual reset? (**#**)
Does it work then?
Roger
Community Member
Hi Roger,
sorry for the late answer...
I reseted all phones. It did not help.
I think the authentication works. When I type in a wrong password for a profile, the access is denied. With the correct password, the profile is not loaded and the error [3] occurs. Any idea?
Thomas
Bronze
Hi Thomas
Well i thought that you are confronted with
a bug which i recently had with Extension Mobility which is not the case.
So what is ecaxtly is the error message? only error [3]?
I guess there should be somthing on the cisco page about error codes.
Roger
Community Member
Hi Roger...
I solved the problem... After tracing the login process, I found out that the CCMSysUser could not be authenticated. I don't know why, but the CCMSysUser Profile was disabled. I reactivated it and now it works fine. I any case, thanks a lot!
Thomas
Community Member
Thomas,
I'm having this same error and haven't found where to enable the CCMSysUser Profile. Can you help me with this?
Tom
240
