04-14-2014 11:11 PM
Hello Everybody ,
we want relay fax from as5350xm to the sip server. So,I have configured fax(t38 protocol ) on as5350xm gateway and the Sip server ,
Now the signaling is Properly working , but we couldn't hear or receive fax tone in fax machine, I'm confused that whether gateway must relay a fax tone to fax machine or our sip server ?
the connection establishment is ,first the IVR is played then we click on start button on the fax machine and nothing could be hear and then the gateway send the invite fax(t38 SDP) to our sip server , also it receive 200 OK(t38 sdp) and response as ack .
I don't know why the data (fax) couldn't transfer .
Furthermore , the packet that we receive on our Sip Server , is the same as below , but we couldn't interpret it. all of the packet are 172 bytes and ,the following 3 packets are the first three packet that we receive in one call and also followed by many other same packet.
are these special t30 packet format that based on ITU ?
128 - 8 - 198 - 219 - 10 - 173 - 235 - 34 - 9 - 182 - 20 - 85 - 155 - 20 - 6 - 116 - 135 - 157 - 18 - 7 - 201 - 134 - 148 - 24 - 5 - 227 - 129 - 225 - 4 - 24 - 151 - 134 - 198 - 7 - 18 - 156 - 135 - 112 - 6 - 21 - 154 - 133 - 111 - 6 - 100 - 132 - 158 - 17 - 6 - 93 - 134 - 144 - 31 - 4 - 254 - 129 - 232 - 26 - 26 - 233 - 129 - 249 - 4 - 31 - 144 - 135 - 112 - 7 - 78 - 135 - 226 - 4 - 17 - 152 - 159 - 18 - 5 - 235 - 135 - 120 - 7 - 90 - 135 - 225 - 4 - 23 - 155 - 156 - 29 - 26 - 149 - 132 - 100 - 7 - 87 - 135 - 231 - 4 - 20 - 154 - 156 - 28 - 27 - 151 - 132 - 102 - 7 - 220 - 135 - 251 - 4 - 21 - 133 - 146 - 31 - 24 - 150 - 132 - 99 - 6 - 113 - 135 - 159 - 16 - 6 - 210 - 134 - 150 - 25 - 4 - 228 - 129 - 236 - 5 - 27 - 149 - 134 - 241 - 7 - 28 - 146 - 135 - 67 - 6 - 23 - 152 - 132 - 97 - 6 - 99 - 132 - 152 - 20 - 6 - 72 - 135 - 146 - 29 - 7 - 245 - 134 - 148 - 24 - 5 - 226 - 129 - 230 - 4 - 25 - 150 - 134 - 218
128 - 8 - 198 - 220 - 10 - 173 - 235 - 194 - 9 - 182 - 20 - 85 - 7 - 19 - 156 - 135 - 114 - 6 - 106 - 154 - 133 - 111 - 6 - 101 - 132 - 158 - 17 - 6 - 81 - 134 - 144 - 31 - 4 - 248 - 129 - 233 - 26 - 26 - 232 - 134 - 255 - 4 - 31 - 144 - 134 - 92 - 6 - 17 - 153 - 132 - 100 - 6 - 108 - 133 - 155 - 21 - 6 - 112 - 135 - 156 - 18 - 7 - 193 - 134 - 151 - 25 - 4 - 225 - 129 - 227 - 5 - 24 - 148 - 134 - 206 - 7 - 29 - 157 - 135 - 116 - 6 - 20 - 155 - 133 - 109 - 6 - 102 - 132 - 153 - 22 - 6 - 69 - 134 - 147 - 28 - 7 - 243 - 134 - 234 - 26 - 5 - 239 - 129 - 229 - 4 - 30 - 145 - 134 - 214 - 6 - 16 - 159 - 132 - 120 - 6 - 104 - 133 - 154 - 107 - 7 - 210 - 135 - 242 - 7 - 104 - 133 - 147 - 30 - 25 - 145 - 132 - 108 - 7 - 244 - 134 - 241 - 7 - 111 - 133 - 144 - 25 - 30 - 144 - 133 - 105 - 7 - 243 - 134 - 207 - 7 - 109 - 132 - 145 - 24 - 30 - 146 - 133 - 106 - 7 - 254 - 135 - 218 - 7 - 96 - 132 - 150 - 27 - 31 - 157 - 154 - 21 - 7
04-19-2014 09:35 AM
Hi, can you add a "debug ccsip message" of fax call?
Can you add a "debug fax relay t30 all" and the config of your AS?
Regards.
04-21-2014 06:58 AM
-------------------------------------------------------Config-------------------------------------------------------------------
Cisco#show run
Building configuration...
Current configuration : 4041 bytes
version 12.4
hostname Cisco
boot-start-marker
no boot startup-test
boot-end-marker
enable secret 5 $1$GQvH$/7LADpw5r7YQrsXB3ARyS.
enable password
resource-pool disable
no aaa new-model
resource policy
ip cef
no ip domain lookup
isdn switch-type primary-net5
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
modem passthrough nse codec g711alaw
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
ds0-num
header-passing
registrar server
no call service stop
voice translation-rule 1
rule 1 /^199/ //
voice translation-profile OUT
translate called 1
username pendar secret 5 $1$y/q/$FAhTfd8raw5p4E8N1msKj.
controller E1 3/0
pri-group timeslots 1-31
cablelength medium
controller E1 3/1
framing NO-CRC4
cablelength medium
ip address 172.16.122.38 255.255.255.252
shutdown
duplex full
speed 100
negotiation auto
interface GigabitEthernet0/1
ip address 217.218.20.88 255.255.255.224
duplex full
speed 100
negotiation auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
no fair-queue
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial3/0:15
no ip address
encapsulation hdlc
isdn incoming-voice modem 64
isdn bchan-number-order ascending
no cdp enable
interface Serial3/1:15
no ip address
encapsulation hdlc
isdn supp-service name calling
no cdp enable
interface Group-Async0
physical-layer async
no ip address
encapsulation slip
interface Group-Async1
no ip address
encapsulation slip
interface Group-Async21
no ip address
encapsulation slip
ip default-gateway 172.16.122.37
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip route 0.0.0.0 0.0.0.0 172.16.122.37
no ip http server
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
control-plane
voice-port 3/0:D
disc_pi_off
output attenuation -6
echo-cancel coverage 24
no non-linear
playout-delay mode fixed
no comfort-noise
cptone DE
voice-port 3/1:D
disc_pi_off
no non-linear
no comfort-noise
cptone DE
dial-peer voice 2 pots
translation-profile outgoing OUT
service session
destination-pattern .+
no digit-strip
direct-inward-dial
port 3/1:D
forward-digits all
dial-peer voice 3 pots
service session
no digit-strip
direct-inward-dial
port 3/0:D
forward-digits all
dial-peer voice 12 voip
service session
session protocol sipv2
session target ipv4:217.218.20.86
session transport udp
dtmf-relay rtp-nte
codec g711alaw
fax-relay sg3-to-g3
no vad
dial-peer voice 13 voip
service session
dtmf-relay h245-signal
codec g711alaw
fax-relay sg3-to-g3
no vad
sip-ua
credentials username 1112 password 12495242375C5C550E7A02 realm pendar
credentials username 1111 password 075E701D1F realm pendar
authentication username 1112 password 083149400D1817 realm pendar
no remote-party-id
no redirection
srv version 1
retry bye 1
retry refer 3
retry register 10
timers notify 400
timers refer 567
timers register 100
registrar ipv4:217.218.20.86 expires 60
sip-server ipv4:217.218.20.86
ss7 mtp2-variant Bellcore 0
ss7 mtp2-variant Bellcore 1
ss7 mtp2-variant Bellcore 2
ss7 mtp2-variant Bellcore 3
line con 0
logging synchronous
line aux 0
line vty 0 4
password
login
scheduler allocate 10000 400
end
-----------------------------------------------------debug ccsip message-------------------------------------------
Sent:
INVITE sip:82131000@217.218.20.86:5060 SIP/2.0
Via: SIP/2.0/UDP 217.218.20.88:5060;x-ds0num="ISDN 3/0:D 3/0:DS1 2:DS0";branch=z9hG4bKB450
From: <sip:2188827748@217.218.20.86>;tag=31ECB4-77C
To: <sip:82131000@217.218.20.86>
Date: Mon, 28 Apr 2003 19:09:31 GMT
Call-ID: C644FAB7-78E311D7-8147EB32-2F8E14EF@217.218.20.88
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 1800
Cisco-Guid: 3326328930-2028147159-2148073506-3185268956
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1051556971
Contact: <sip:2188827748@217.218.20.88:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 243
v=0
o=CiscoSystemsSIP-GW-UserAgent 9011 6390 IN IP4 217.218.20.88
s=SIP Call
c=IN IP4 217.218.20.88
t=0 0
m=audio 16920 RTP/AVP 8 100
a=rtpmap:8 PCMA/8000
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=ptime:20
*Apr 28 19:09:31.007: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying -- your call is important to us
Via: SIP/2.0/UDP 217.218.20.88:5060;branch=z9hG4bKB450;rport=5060
CSeq: 101 INVITE
Server: SIP Proxy Server
Content-Length: 0
*Apr 28 19:09:31.071: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:82131000@217.218.20.86>;tag=1710684053
Min-SE: 1800
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 0
Record-Route: <sip:82131000@217.218.20.86;ftag=31ECB4-77C;lr=on>
Received:
SIP/2.0 200 OK
Contact: <sip:217.218.20.86:5060>
CSeq: 101 INVITE
Server: CallCenter
User-Agent: CallCenter
Content-Length: 209
v=0
o=- 3517046709 3517046709 IN IP4 217.218.20.86
s=Pendar Pajouh
c=IN IP4 217.218.20.86
t=0 0
a=direction:active
m=audio 13868 RTP/AVP 8 101
a=rtpmap:101 telephone-event/8000
Sent:
ACK sip:217.218.20.86:5060 SIP/2.0
Via: SIP/2.0/UDP 217.218.20.88:5060;x-ds0num="ISDN 3/0:D 3/0:DS1 2:DS0";branch=z9hG4bKB523D7
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Apr 28 19:09:37.311: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:217.218.20.86:5060 SIP/2.0
Via: SIP/2.0/UDP 217.218.20.88:5060;x-ds0num="ISDN 3/0:D 3/0:DS1 2:DS0";branch=z9hG4bKB6786
Date: Mon, 28 Apr 2003 19:09:37 GMT
Min-SE: 1800
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1051556977
Expires: 180
Content-Length: 399
v=0
o=CiscoSystemsSIP-GW-UserAgent 9011 6391 IN IP4 217.218.20.88
s=SIP Call
t=0 0
m=image 16920 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:14400
a=T38FaxFillBitRemoval:0
a=T38FaxTranscodingMMR:0
a=T38FaxTranscodingJBIG:0
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:72
a=T38FaxUdpEC:t38UDPRedundancy
*Apr 28 19:09:37.315: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 217.218.20.88:5060;branch=z9hG4bKB6786;rport=5060
CSeq: 102 INVITE
Server: CallCenter
Content-Length: 247
v=0
o=- 4858949 4858949 IN IP4 217.218.20.86
s=Pendar Pajouh
m=image 13868 udptl t38
a=T38FaxVersion:0
Sent:
Via: SIP/2.0/UDP 217.218.20.88:5060;x-ds0num="ISDN 3/0:D 3/0:DS1 2:DS0";branch=z9hG4bKB764D
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
-------------------------------------------------------debug fax relay t30 all--------------------------------------------
no message
is it need a special modem for fax?
04-21-2014 06:58 AM
Hi.
1) Please, remove passwords from your config.
2) In the configuration I see
sip
but the config of this interface is
shutdown
SIP and SIP/SDP messages use the G0/1 address.
Try to change the sip bind config to G0/1.
3) Dial-peers 12 and 13 are equal. In DP 13 you have configured dtmf-relay h245-signal but this works only with H.323 signalling. It doesn't work in SIP.
4) The SIP flow seems ok. The Cisco sends an INVITE and gets a response from a "Call Center" to open an RTP flow in G.711. So, the Cisco sends a ReINVITE to switch to T.38.
In the 200 OK response I see
and
a=direction:active
Typically these headers indicate that the "Call Center" is behind NAT.
Is true? Is there a NAT?
Could be a NAT issue.
Regards.
04-22-2014 01:12 AM
Thanks for your reply ,
All of your recommendation are done. (as this issue is a test we do all commands with trial and error ).
we didn't use NAT in our network .
04-22-2014 05:55 AM
Hi, please add a new trace:
debug ccsip message
debug voip rtp (cpu intensive)
Regards.
04-22-2014 09:00 PM
*May 1 18:45:41.182: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 217.218.20.88:5060;x-ds0num="ISDN 3/0:D 3/0:DS1 3:DS0";branch=z9hG4bK3CC321AA
From: <sip:2188827748@217.218.20.86>;tag=F8F156C-117B
To: <sip:82131000@217.218.20.86>;tag=378343733
Date: Thu, 01 May 2003 18:45:41 GMT
Call-ID: ED48D729-7B3B11D7-8F95EB32-2F8E14EF@217.218.20.88
Route: <sip:82131000@217.218.20.86;ftag=F8F156C-117B;lr=on>
Min-SE: 1800
Cisco-Guid: 3979253983-2067468759-2205417506-3185268956
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1051814741
Expires: 180
Content-Length: 399
v=0
o=CiscoSystemsSIP-GW-UserAgent 4971 1666 IN IP4 217.218.20.88
s=SIP Call
t=0 0
m=image 18358 udptl t38
a=T38FaxVersion:0
*May 1 18:45:41.186: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 217.218.20.88:5060;branch=z9hG4bK3CC321AA;rport=5060
Record-Route: <sip:82131000@217.218.20.86;ftag=F8F156C-117B;lr=on>
CSeq: 102 INVITE
Server: CallCenter
Content-Length: 247
v=0
s=Pendar Pajouh
m=image 15422 udptl t38
a=T38FaxVersion:0
Sent:
Via: SIP/2.0/UDP 217.218.20.88:5060;x-ds0num="ISDN 3/0:D 3/0:DS1 3:DS0";branch=z9hG4bK3CC412F4
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
doesn't have any message
-------------------------------------debug voip rtp----------------------------------------
Telconi Terminal 1.01
direct TELNET to 217.218.20.88 [217.218.20.88] from 217.218.20.86
Default to IOS device.
Cisco#
*May 1 18:58:31.089: voip_rtp_create_session: callID=15515, dstCallID=-1 laddr=217.218.20.88, lport=19916,raddr=0.0.0.0, rport=0
, type=2, sig_tos=3, ip_tos=5
*May 1 18:58:31.089: voip_rtp_update_xmit_info
*May 1 18:58:31.089: voip_rtp_update_xmit_info, dstvdbptr: 0, dstCallID -1, gccb: 65FE38C0, xmitFunc 0,context 0
*May 1 18:58:31.089: voip_rtp_update_xmit_info Context is NULL, exit
*May 1 18:58:31.089: voip_rtp_set_non_rtp_call: Non-RTP call end
*May 1 18:58:31.161: voip_rtp_update_callinfo: RTCP enabled
*May 1 18:58:31.161: voip_rtp_update_local_ssrc srtp: 0 CallID: 15515 dstCallID: 15514 new ssrc: 0x23B61458
*May 1 18:58:31.161: voip_rtcp_get_cname: cname=0.0.0@217.218.20.88
*May 1 18:58:31.161: voip_rtp_update_callinfo: RTP address/port changes 0:0->D9DA1456:3824
*May 1 18:58:31.161: voip_rtp_update_callinfo: first_pak=TRUE, new_ssrc=0, type=3
*May 1 18:58:31.161: voip_rtp_update_xmit_info
*May 1 18:58:31.161: voip_rtp_update_xmit_info, dstvdbptr: 65F46924, dstCallID 15514, gccb: 65FE38C0, xmitFunc 6186DC5C,context
*May 1 18:58:31.161: voip_rtp_update_xmit_info Context is NULL, exit
*May 1 18:58:31.161: voip_rtp_set_non_rtp_call: Non-RTP call end
*May 1 18:58:31.161: voip_rtp_exchange_context_info
*May 1 18:58:31.161: voip_rtp_update_xmit_info, dstvdbptr: 66488384, dstCallID 15514, gccb: 65FE38C0, xmitFunc 6186DC5C,context
66FA8FE8
*May 1 18:58:31.161: voip_rtp_update_xmit_info Xmit Info node current values xmit_info->dstvdbptr: 66488384, xmit_info->dstCall
ID 15514, xmit_info->xmitFunc 6186DC5C, xmit_info->context 66FA8FE8
*May 1 18:58:31.161: voip xmit info count: 1
66FA8FE8
*May 1 18:58:31.161: voip_rtp_update_xmit_info Xmit Info node current values xmit_info->dstvdbptr: 65F46924, xmit_info->dstCall
66FA8FE8
*May 1 18:58:31.161: voip_rtcp_start_session:
*May 1 18:58:31.161: voip_rtcp_start_session: start session
*May 1 18:58:31.213: RTP(7964): fs tx d=217.218.20.86(14372), pt=8, ts=B8458C3F, ssrc=23B61458
*May 1 18:58:31.233: RTP(7965): fp tx d=217.218.20.86(14372), pt=8, ts=B8458CDF, ssrc=23B61458
*May 1 18:58:31.253: RTP(7966): fp tx d=217.218.20.86(14372), pt=8, ts=B8458D7F, ssrc=23B61458
*May 1 18:58:31.273: RTP(7967): fp tx d=217.218.20.86(14372), pt=8, ts=B8458E1F, ssrc=23B61458
*May 1 18:58:31.293: RTP(7968): fp tx d=217.218.20.86(14372), pt=8, ts=B8458EBF, ssrc=23B61458
*May 1 18:58:31.313: RTP(7969): fp tx d=217.218.20.86(14372), pt=8, ts=B8458F5F, ssrc=23B61458
*May 1 18:58:31.325: RTP(119): ps rx d=217.218.20.86(14372), pt=8, ts=3EB0894C, ssrc=3BFC663F
*May 1 18:58:31.333: RTP(7970): fp tx d=217.218.20.86(14372), pt=8, ts=B8458FFF, ssrc=23B61458
*May 1 18:58:31.345: RTP(120): fs rx d=217.218.20.86(14372), pt=8, ts=3EB089EC, ssrc=3BFC663F
*May 1 18:58:31.353: RTP(7971): fp tx d=217.218.20.86(14372), pt=8, ts=B845909F, ssrc=23B61458
*May 1 18:58:31.365: RTP(121): fs rx d=217.218.20.86(14372), pt=8, ts=3EB08A8C, ssrc=3BFC663F
*May 1 18:58:31.377: RTP(7972): fp tx d=217.218.20.86(14372), pt=8, ts=B845913F, ssrc=23B61458
*May 1 18:58:31.385: RTP(122): fs rx d=217.218.20.86(14372), pt=8, ts=3EB08B2C, ssrc=3BFC663F
*May 1 18:58:31.397: RTP(7973): fp tx d=217.218.20.86(14372), pt=8, ts=B84591DF, ssrc=23B61458
*May 1 18:58:31.405: RTP(123): fs rx d=217.218.20.86(14372), pt=8, ts=3EB08BCC, ssrc=3BFC663F
*May 1 18:58:31.417: RTP(7974): fp tx d=217.218.20.86(14372), pt=8, ts=B845927F, ssrc=23B61458
*May 1 18:58:31.425: RTP(124): fs rx d=217.218.20.86(14372), pt=8, ts=3EB08C6C, ssrc=3BFC663F
*May 1 18:58:31.437: RTP(7975): fp tx d=217.218.20.86(14372), pt=8, ts=B845931F, ssrc=23B61458
*May 1 18:58:31.445: RTP(125): fs rx d=217.218.20.86(14372), pt=8, ts=3EB08D0C, ssrc=3BFC663F
*May 1 18:58:31.457: RTP(7976): fp tx d=217.218.20.86(14372), pt=8, ts=B84593BF, ssrc=23B61458
*May 1 18:58:31.465: RTP(126): fs rx d=217.218.20.86(14372), pt=8, ts=3EB08DAC, ssrc=3BFC663F
*May 1 18:58:31.477: RTP(7977): fp tx d=217.218.20.86(14372), pt=8, ts=B845945F, ssrc=23B61458
*May 1 18:58:31.485: RTP(127): fs rx d=217.218.20.86(14372), pt=8, ts=3EB08E4C, ssrc=3BFC663F
*May 1 18:58:31.497: RTP(7978): fp tx d=217.218.20.86(14372), pt=8, ts=B84594FF, ssrc=23B61458
*May 1 18:58:31.505: RTP(128): fs rx d=217.218.20.86(14372), pt=8, ts=3EB08EEC, ssrc=3BFC663F
*May 1 18:58:31.517: RTP(7979): fp tx d=217.218.20.86(14372), pt=8, ts=B845959F, ssrc=23B61458
*May 1 18:58:31.525: RTP(129): fs rx d=217.218.20.86(14372), pt=8, ts=3EB08F8C, ssrc=3BFC663F
*May 1 18:58:31.537: RTP(7980): fp tx d=217.218.20.86(14372), pt=8, ts=B845963F, ssrc=23B61458
*May 1 18:58:31.545: RTP(130): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0902C, ssrc=3BFC663F
*May 1 18:58:31.557: RTP(7981): fp tx d=217.218.20.86(14372), pt=8, ts=B84596DF, ssrc=23B61458
*May 1 18:58:31.565: RTP(131): fs rx d=217.218.20.86(14372), pt=8, ts=3EB090CC, ssrc=3BFC663F
*May 1 18:58:31.577: RTP(7982): fp tx d=217.218.20.86(14372), pt=8, ts=B845977F, ssrc=23B61458
*May 1 18:58:31.585: RTP(132): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0916C, ssrc=3BFC663F
*May 1 18:58:31.597: RTP(7983): fp tx d=217.218.20.86(14372), pt=8, ts=B845981F, ssrc=23B61458
*May 1 18:58:31.605: RTP(133): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0920C, ssrc=3BFC663F
*May 1 18:58:31.617: RTP(7984): fp tx d=217.218.20.86(14372), pt=8, ts=B84598BF, ssrc=23B61458
*May 1 18:58:31.625: RTP(134): fs rx d=217.218.20.86(14372), pt=8, ts=3EB092AC, ssrc=3BFC663F
*May 1 18:58:31.637: RTP(7985): fp tx d=217.218.20.86(14372), pt=8, ts=B845995F, ssrc=23B61458
*May 1 18:58:31.645: RTP(135): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0934C, ssrc=3BFC663F
*May 1 18:58:31.657: RTP(7986): fp tx d=217.218.20.86(14372), pt=8, ts=B84599FF, ssrc=23B61458
*May 1 18:58:31.665: RTP(136): fs rx d=217.218.20.86(14372), pt=8, ts=3EB093EC, ssrc=3BFC663F
*May 1 18:58:31.677: RTP(7987): fp tx d=217.218.20.86(14372), pt=8, ts=B8459A9F, ssrc=23B61458
*May 1 18:58:31.685: RTP(137): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0948C, ssrc=3BFC663F
*May 1 18:58:31.697: RTP(7988): fp tx d=217.218.20.86(14372), pt=8, ts=B8459B3F, ssrc=23B61458
*May 1 18:58:31.705: RTP(138): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0952C, ssrc=3BFC663F
*May 1 18:58:31.717: RTP(7989): fp tx d=217.218.20.86(14372), pt=8, ts=B8459BDF, ssrc=23B61458
*May 1 18:58:31.725: RTP(139): fs rx d=217.218.20.86(14372), pt=8, ts=3EB095CC, ssrc=3BFC663F
*May 1 18:58:31.737: RTP(7990): fp tx d=217.218.20.86(14372), pt=8, ts=B8459C7F, ssrc=23B61458
*May 1 18:58:31.745: RTP(140): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0966C, ssrc=3BFC663F
*May 1 18:58:31.757: RTP(7991): fp tx d=217.218.20.86(14372), pt=8, ts=B8459D1F, ssrc=23B61458
*May 1 18:58:31.765: RTP(141): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0970C, ssrc=3BFC663F
*May 1 18:58:31.777: RTP(7992): fp tx d=217.218.20.86(14372), pt=8, ts=B8459DBF, ssrc=23B61458
*May 1 18:58:31.785: RTP(142): fs rx d=217.218.20.86(14372), pt=8, ts=3EB097AC, ssrc=3BFC663F
*May 1 18:58:31.797: RTP(7993): fp tx d=217.218.20.86(14372), pt=8, ts=B8459E5F, ssrc=23B61458
*May 1 18:58:31.805: RTP(143): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0984C, ssrc=3BFC663F
*May 1 18:58:31.817: RTP(7994): fp tx d=217.218.20.86(14372), pt=8, ts=B8459EFF, ssrc=23B61458
*May 1 18:58:31.825: RTP(144): fs rx d=217.218.20.86(14372), pt=8, ts=3EB098EC, ssrc=3BFC663F
*May 1 18:58:31.837: RTP(7995): fp tx d=217.218.20.86(14372), pt=8, ts=B8459F9F, ssrc=23B61458
*May 1 18:58:31.845: RTP(145): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0998C, ssrc=3BFC663F
*May 1 18:58:31.857: RTP(7996): fp tx d=217.218.20.86(14372), pt=8, ts=B845A03F, ssrc=23B61458
*May 1 18:58:31.865: RTP(146): fs rx d=217.218.20.86(14372), pt=8, ts=3EB09A2C, ssrc=3BFC663F
*May 1 18:58:31.877: RTP(7997): fp tx d=217.218.20.86(14372), pt=8, ts=B845A0DF, ssrc=23B61458
*May 1 18:58:31.885: RTP(147): fs rx d=217.218.20.86(14372), pt=8, ts=3EB09ACC, ssrc=3BFC663F
*May 1 18:58:31.897: RTP(7998): fp tx d=217.218.20.86(14372), pt=8, ts=B845A17F, ssrc=23B61458
*May 1 18:58:31.905: RTP(148): fs rx d=217.218.20.86(14372), pt=8, ts=3EB09B6C, ssrc=3BFC663F
*May 1 18:58:31.917: RTP(7999): fp tx d=217.218.20.86(14372), pt=8, ts=B845A21F, ssrc=23B61458
*May 1 18:58:31.925: RTP(149): fs rx d=217.218.20.86(14372), pt=8, ts=3EB09C0C, ssrc=3BFC663F
*May 1 18:58:31.937: RTP(8000): fp tx d=217.218.20.86(14372), pt=8, ts=B845A2BF, ssrc=23B61458
*May 1 18:58:31.945: RTP(150): fs rx d=217.218.20.86(14372), pt=8, ts=3EB09CAC, ssrc=3BFC663F
*May 1 18:58:31.957: RTP(8001): fp tx d=217.218.20.86(14372), pt=8, ts=B845A35F, ssrc=23B61458
*May 1 18:58:31.965: RTP(151): fs rx d=217.218.20.86(14372), pt=8, ts=3EB09D4C, ssrc=3BFC663F
*May 1 18:58:31.977: RTP(8002): fp tx d=217.218.20.86(14372), pt=8, ts=B845A3FF, ssrc=23B61458
*May 1 18:58:31.985: RTP(152): fs rx d=217.218.20.86(14372), pt=8, ts=3EB09DEC, ssrc=3BFC663F
*May 1 18:58:31.997: RTP(8003): fp tx d=217.218.20.86(14372), pt=8, ts=B845A49F, ssrc=23B61458
*May 1 18:58:32.005: RTP(153): fs rx d=217.218.20.86(14372), pt=8, ts=3EB09E8C, ssrc=3BFC663F
*May 1 18:58:32.017: RTP(8004): fp tx d=217.218.20.86(14372), pt=8, ts=B845A53F, ssrc=23B61458
*May 1 18:58:32.025: RTP(154): fs rx d=217.218.20.86(14372), pt=8, ts=3EB09F2C, ssrc=3BFC663F
*May 1 18:58:32.037: RTP(8005): fp tx d=217.218.20.86(14372), pt=8, ts=B845A5DF, ssrc=23B61458
*May 1 18:58:32.045: RTP(155): fs rx d=217.218.20.86(14372), pt=8, ts=3EB09FCC, ssrc=3BFC663F
*May 1 18:58:32.057: RTP(8006): fp tx d=217.218.20.86(14372), pt=8, ts=B845A67F, ssrc=23B61458
*May 1 18:58:32.065: RTP(156): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0A06C, ssrc=3BFC663F
*May 1 18:58:32.077: RTP(8007): fp tx d=217.218.20.86(14372), pt=8, ts=B845A71F, ssrc=23B61458
*May 1 18:58:32.085: RTP(157): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0A10C, ssrc=3BFC663F
*May 1 18:58:32.097: RTP(8008): fp tx d=217.218.20.86(14372), pt=8, ts=B845A7BF, ssrc=23B61458
*May 1 18:58:32.105: RTP(158): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0A1AC, ssrc=3BFC663F
*May 1 18:58:32.117: RTP(8009): fp tx d=217.218.20.86(14372), pt=8, ts=B845A85F, ssrc=23B61458
*May 1 18:58:32.125: RTP(159): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0A24C, ssrc=3BFC663F
*May 1 18:58:32.137: RTP(8010): fp tx d=217.218.20.86(14372), pt=8, ts=B845A8FF, ssrc=23B61458
*May 1 18:58:32.145: RTP(160): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0A2EC, ssrc=3BFC663F
*May 1 18:58:32.157: RTP(8011): fp tx d=217.218.20.86(14372), pt=8, ts=B845A99F, ssrc=23B61458
*May 1 18:58:32.165: RTP(161): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0A38C, ssrc=3BFC663F
*May 1 18:58:32.177: RTP(8012): fp tx d=217.218.20.86(14372), pt=8, ts=B845AA3F, ssrc=23B61458
*May 1 18:58:32.185: RTP(162): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0A42C, ssrc=3BFC663F
*May 1 18:58:32.197: RTP(8013): fp tx d=217.218.20.86(14372), pt=8, ts=B845AADF, ssrc=23B61458
*May 1 18:58:32.205: RTP(163): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0A4CC, ssrc=3BFC663F
*May 1 18:58:32.217: RTP(8014): fp tx d=217.218.20.86(14372), pt=8, ts=B845AB7F, ssrc=23B61458
*May 1 18:58:32.225: RTP(164): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0A56C, ssrc=3BFC663F
*May 1 18:58:32.237: RTP(8015): fp tx d=217.218.20.86(14372), pt=8, ts=B845AC1F, ssrc=23B61458
*May 1 18:58:32.245: RTP(165): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0A60C, ssrc=3BFC663F
*May 1 18:58:32.257: RTP(8016): fp tx d=217.218.20.86(14372), pt=8, ts=B845ACBF, ssrc=23B61458
*May 1 18:58:32.265: RTP(166): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0A6AC, ssrc=3BFC663F
*May 1 18:58:32.277: RTP(8017): fp tx d=217.218.20.86(14372), pt=8, ts=B845AD5F, ssrc=23B61458
*May 1 18:58:32.285: RTP(167): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0A74C, ssrc=3BFC663F
*May 1 18:58:32.297: RTP(8018): fp tx d=217.218.20.86(14372), pt=8, ts=B845ADFF, ssrc=23B61458
*May 1 18:58:32.305: RTP(168): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0A7EC, ssrc=3BFC663F
*May 1 18:58:32.317: RTP(8019): fp tx d=217.218.20.86(14372), pt=8, ts=B845AE9F, ssrc=23B61458
*May 1 18:58:32.325: RTP(169): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0A88C, ssrc=3BFC663F
*May 1 18:58:32.337: RTP(8020): fp tx d=217.218.20.86(14372), pt=8, ts=B845AF3F, ssrc=23B61458
*May 1 18:58:32.345: RTP(170): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0A92C, ssrc=3BFC663F
*May 1 18:58:32.357: RTP(8021): fp tx d=217.218.20.86(14372), pt=8, ts=B845AFDF, ssrc=23B61458
*May 1 18:58:32.365: RTP(171): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0A9CC, ssrc=3BFC663F
*May 1 18:58:32.377: RTP(8022): fp tx d=217.218.20.86(14372), pt=8, ts=B845B07F, ssrc=23B61458
*May 1 18:58:32.385: RTP(172): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0AA6C, ssrc=3BFC663F
*May 1 18:58:32.397: RTP(8023): fp tx d=217.218.20.86(14372), pt=8, ts=B845B11F, ssrc=23B61458
*May 1 18:58:32.405: RTP(173): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0AB0C, ssrc=3BFC663F
*May 1 18:58:32.417: RTP(8024): fp tx d=217.218.20.86(14372), pt=8, ts=B845B1BF, ssrc=23B61458
*May 1 18:58:32.425: RTP(174): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0ABAC, ssrc=3BFC663F
*May 1 18:58:32.437: RTP(8025): fp tx d=217.218.20.86(14372), pt=8, ts=B845B25F, ssrc=23B61458
*May 1 18:58:32.445: RTP(175): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0AC4C, ssrc=3BFC663F
*May 1 18:58:32.457: RTP(8026): fp tx d=217.218.20.86(14372), pt=8, ts=B845B2FF, ssrc=23B61458
*May 1 18:58:32.465: RTP(176): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0ACEC, ssrc=3BFC663F
*May 1 18:58:32.477: RTP(8027): fp tx d=217.218.20.86(14372), pt=8, ts=B845B39F, ssrc=23B61458
*May 1 18:58:32.485: RTP(177): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0AD8C, ssrc=3BFC663F
*May 1 18:58:32.497: RTP(8028): fp tx d=217.218.20.86(14372), pt=8, ts=B845B43F, ssrc=23B61458
*May 1 18:58:32.505: RTP(178): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0AE2C, ssrc=3BFC663F
*May 1 18:58:32.517: RTP(8029): fp tx d=217.218.20.86(14372), pt=8, ts=B845B4DF, ssrc=23B61458
*May 1 18:58:32.525: RTP(179): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0AECC, ssrc=3BFC663F
*May 1 18:58:32.537: RTP(8030): fp tx d=217.218.20.86(14372), pt=8, ts=B845B57F, ssrc=23B61458
*May 1 18:58:32.545: RTP(180): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0AF6C, ssrc=3BFC663F
*May 1 18:58:32.557: RTP(8031): fp tx d=217.218.20.86(14372), pt=8, ts=B845B61F, ssrc=23B61458
*May 1 18:58:32.565: RTP(181): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0B00C, ssrc=3BFC663F
*May 1 18:58:32.577: RTP(8032): fp tx d=217.218.20.86(14372), pt=8, ts=B845B6BF, ssrc=23B61458
*May 1 18:58:32.585: RTP(182): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0B0AC, ssrc=3BFC663F
*May 1 18:58:32.597: RTP(8033): fp tx d=217.218.20.86(14372), pt=8, ts=B845B75F, ssrc=23B61458
*May 1 18:58:32.605: RTP(183): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0B14C, ssrc=3BFC663F
*May 1 18:58:32.617: RTP(8034): fp tx d=217.218.20.86(14372), pt=8, ts=B845B7FF, ssrc=23B61458
*May 1 18:58:32.625: RTP(184): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0B1EC, ssrc=3BFC663F
*May 1 18:58:32.637: RTP(8035): fp tx d=217.218.20.86(14372), pt=8, ts=B845B89F, ssrc=23B61458
*May 1 18:58:32.645: RTP(185): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0B28C, ssrc=3BFC663F
*May 1 18:58:32.657: RTP(8036): fp tx d=217.218.20.86(14372), pt=8, ts=B845B93F, ssrc=23B61458
*May 1 18:58:32.665: RTP(186): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0B32C, ssrc=3BFC663F
*May 1 18:58:32.677: RTP(8037): fp tx d=217.218.20.86(14372), pt=8, ts=B845B9DF, ssrc=23B61458
*May 1 18:58:32.685: RTP(187): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0B3CC, ssrc=3BFC663F
*May 1 18:58:32.697: RTP(8038): fp tx d=217.218.20.86(14372), pt=8, ts=B845BA7F, ssrc=23B61458
*May 1 18:58:32.705: RTP(188): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0B46C, ssrc=3BFC663F
*May 1 18:58:32.717: RTP(8039): fp tx d=217.218.20.86(14372), pt=8, ts=B845BB1F, ssrc=23B61458
*May 1 18:58:32.725: RTP(189): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0B50C, ssrc=3BFC663F
*May 1 18:58:32.737: RTP(8040): fp tx d=217.218.20.86(14372), pt=8, ts=B845BBBF, ssrc=23B61458
*May 1 18:58:32.745: RTP(190): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0B5AC, ssrc=3BFC663F
*May 1 18:58:32.757: RTP(8041): fp tx d=217.218.20.86(14372), pt=8, ts=B845BC5F, ssrc=23B61458
*May 1 18:58:32.765: RTP(191): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0B64C, ssrc=3BFC663F
*May 1 18:58:32.777: RTP(8042): fp tx d=217.218.20.86(14372), pt=8, ts=B845BCFF, ssrc=23B61458
*May 1 18:58:32.785: RTP(192): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0B6EC, ssrc=3BFC663F
*May 1 18:58:32.793: voip_rtcp_stats_req: Calculated remaining disc time is 0 msec...Media Inactivity Criteria is 0
*May 1 18:58:32.797: RTP(8043): fp tx d=217.218.20.86(14372), pt=8, ts=B845BD9F, ssrc=23B61458
*May 1 18:58:32.805: RTP(193): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0B78C, ssrc=3BFC663F
*May 1 18:58:32.817: RTP(8044): fp tx d=217.218.20.86(14372), pt=8, ts=B845BE3F, ssrc=23B61458
*May 1 18:58:32.825: RTP(194): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0B82C, ssrc=3BFC663F
*May 1 18:58:32.837: RTP(8045): fp tx d=217.218.20.86(14372), pt=8, ts=B845BEDF, ssrc=23B61458
*May 1 18:58:32.845: RTP(195): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0B8CC, ssrc=3BFC663F
*May 1 18:58:32.857: RTP(8046): fp tx d=217.218.20.86(14372), pt=8, ts=B845BF7F, ssrc=23B61458
*May 1 18:58:32.865: RTP(196): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0B96C, ssrc=3BFC663F
*May 1 18:58:32.877: RTP(8047): fp tx d=217.218.20.86(14372), pt=8, ts=B845C01F, ssrc=23B61458
*May 1 18:58:32.885: RTP(197): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0BA0C, ssrc=3BFC663F
*May 1 18:58:32.897: RTP(8048): fp tx d=217.218.20.86(14372), pt=8, ts=B845C0BF, ssrc=23B61458
*May 1 18:58:32.905: RTP(198): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0BAAC, ssrc=3BFC663F
*May 1 18:58:32.917: RTP(8049): fp tx d=217.218.20.86(14372), pt=8, ts=B845C15F, ssrc=23B61458
*May 1 18:58:32.925: RTP(199): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0BB4C, ssrc=3BFC663F
*May 1 18:58:32.937: RTP(8050): fp tx d=217.218.20.86(14372), pt=8, ts=B845C1FF, ssrc=23B61458
*May 1 18:58:32.945: RTP(200): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0BBEC, ssrc=3BFC663F
*May 1 18:58:32.957: RTP(8051): fp tx d=217.218.20.86(14372), pt=8, ts=B845C29F, ssrc=23B61458
*May 1 18:58:32.965: RTP(201): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0BC8C, ssrc=3BFC663F
*May 1 18:58:32.977: RTP(8052): fp tx d=217.218.20.86(14372), pt=8, ts=B845C33F, ssrc=23B61458
*May 1 18:58:32.985: RTP(202): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0BD2C, ssrc=3BFC663F
*May 1 18:58:32.997: RTP(8053): fp tx d=217.218.20.86(14372), pt=8, ts=B845C3DF, ssrc=23B61458
*May 1 18:58:33.005: RTP(203): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0BDCC, ssrc=3BFC663F
*May 1 18:58:33.017: RTP(8054): fp tx d=217.218.20.86(14372), pt=8, ts=B845C47F, ssrc=23B61458
*May 1 18:58:33.025: RTP(204): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0BE6C, ssrc=3BFC663F
*May 1 18:58:33.037: RTP(8055): fp tx d=217.218.20.86(14372), pt=8, ts=B845C51F, ssrc=23B61458
*May 1 18:58:33.045: RTP(205): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0BF0C, ssrc=3BFC663F
*May 1 18:58:33.057: RTP(8056): fp tx d=217.218.20.86(14372), pt=8, ts=B845C5BF, ssrc=23B61458
*May 1 18:58:33.065: RTP(206): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0BFAC, ssrc=3BFC663F
*May 1 18:58:33.077: RTP(8057): fp tx d=217.218.20.86(14372), pt=8, ts=B845C65F, ssrc=23B61458
*May 1 18:58:33.085: RTP(207): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0C04C, ssrc=3BFC663F
*May 1 18:58:33.097: RTP(8058): fp tx d=217.218.20.86(14372), pt=8, ts=B845C6FF, ssrc=23B61458
*May 1 18:58:33.105: RTP(208): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0C0EC, ssrc=3BFC663F
*May 1 18:58:33.117: RTP(8059): fp tx d=217.218.20.86(14372), pt=8, ts=B845C79F, ssrc=23B61458
*May 1 18:58:33.125: RTP(209): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0C18C, ssrc=3BFC663F
*May 1 18:58:33.137: RTP(8060): fp tx d=217.218.20.86(14372), pt=8, ts=B845C83F, ssrc=23B61458
*May 1 18:58:33.145: RTP(210): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0C22C, ssrc=3BFC663F
*May 1 18:58:33.157: RTP(8061): fp tx d=217.218.20.86(14372), pt=8, ts=B845C8DF, ssrc=23B61458
*May 1 18:58:33.165: RTP(211): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0C2CC, ssrc=3BFC663F
*May 1 18:58:33.177: RTP(8062): fp tx d=217.218.20.86(14372), pt=8, ts=B845C97F, ssrc=23B61458
*May 1 18:58:33.185: RTP(212): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0C36C, ssrc=3BFC663F
*May 1 18:58:33.197: RTP(8063): fp tx d=217.218.20.86(14372), pt=8, ts=B845CA1F, ssrc=23B61458
*May 1 18:58:33.205: RTP(213): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0C40C, ssrc=3BFC663F
*May 1 18:58:33.217: RTP(8064): fp tx d=217.218.20.86(14372), pt=8, ts=B845CABF, ssrc=23B61458
*May 1 18:58:33.225: RTP(214): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0C4AC, ssrc=3BFC663F
*May 1 18:58:33.237: RTP(8065): fp tx d=217.218.20.86(14372), pt=8, ts=B845CB5F, ssrc=23B61458
*May 1 18:58:33.245: RTP(215): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0C54C, ssrc=3BFC663F
*May 1 18:58:33.257: RTP(8066): fp tx d=217.218.20.86(14372), pt=8, ts=B845CBFF, ssrc=23B61458
*May 1 18:58:33.265: RTP(216): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0C5EC, ssrc=3BFC663F
*May 1 18:58:33.277: RTP(8067): fp tx d=217.218.20.86(14372), pt=8, ts=B845CC9F, ssrc=23B61458
*May 1 18:58:33.285: RTP(217): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0C68C, ssrc=3BFC663F
*May 1 18:58:33.297: RTP(8068): fp tx d=217.218.20.86(14372), pt=8, ts=B845CD3F, ssrc=23B61458
*May 1 18:58:33.305: RTP(218): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0C72C, ssrc=3BFC663F
*May 1 18:58:33.317: RTP(8069): fp tx d=217.218.20.86(14372), pt=8, ts=B845CDDF, ssrc=23B61458
*May 1 18:58:33.325: RTP(219): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0C7CC, ssrc=3BFC663F
*May 1 18:58:33.337: RTP(8070): fp tx d=217.218.20.86(14372), pt=8, ts=B845CE7F, ssrc=23B61458
*May 1 18:58:33.345: RTP(220): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0C86C, ssrc=3BFC663F
*May 1 18:58:33.357: RTP(8071): fp tx d=217.218.20.86(14372), pt=8, ts=B845CF1F, ssrc=23B61458
*May 1 18:58:33.365: RTP(221): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0C90C, ssrc=3BFC663F
*May 1 18:58:33.377: RTP(8072): fp tx d=217.218.20.86(14372), pt=8, ts=B845CFBF, ssrc=23B61458
*May 1 18:58:33.385: RTP(222): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0C9AC, ssrc=3BFC663F
*May 1 18:58:33.397: RTP(8073): fp tx d=217.218.20.86(14372), pt=8, ts=B845D05F, ssrc=23B61458
*May 1 18:58:33.405: RTP(223): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0CA4C, ssrc=3BFC663F
*May 1 18:58:33.417: RTP(8074): fp tx d=217.218.20.86(14372), pt=8, ts=B845D0FF, ssrc=23B61458
*May 1 18:58:33.425: RTP(224): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0CAEC, ssrc=3BFC663F
*May 1 18:58:33.437: RTP(8075): fp tx d=217.218.20.86(14372), pt=8, ts=B845D19F, ssrc=23B61458
*May 1 18:58:33.445: RTP(225): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0CB8C, ssrc=3BFC663F
*May 1 18:58:33.457: RTP(8076): fp tx d=217.218.20.86(14372), pt=8, ts=B845D23F, ssrc=23B61458
*May 1 18:58:33.465: RTP(226): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0CC2C, ssrc=3BFC663F
*May 1 18:58:33.477: RTP(8077): fp tx d=217.218.20.86(14372), pt=8, ts=B845D2DF, ssrc=23B61458
*May 1 18:58:33.485: RTP(227): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0CCCC, ssrc=3BFC663F
*May 1 18:58:33.497: RTP(8078): fp tx d=217.218.20.86(14372), pt=8, ts=B845D37F, ssrc=23B61458
*May 1 18:58:33.505: RTP(228): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0CD6C, ssrc=3BFC663F
*May 1 18:58:33.517: RTP(8079): fp tx d=217.218.20.86(14372), pt=8, ts=B845D41F, ssrc=23B61458
*May 1 18:58:33.525: RTP(229): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0CE0C, ssrc=3BFC663F
*May 1 18:58:33.537: RTP(8080): fp tx d=217.218.20.86(14372), pt=8, ts=B845D4BF, ssrc=23B61458
*May 1 18:58:33.545: RTP(230): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0CEAC, ssrc=3BFC663F
*May 1 18:58:33.557: RTP(8081): fp tx d=217.218.20.86(14372), pt=8, ts=B845D55F, ssrc=23B61458
*May 1 18:58:33.565: RTP(231): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0CF4C, ssrc=3BFC663F
*May 1 18:58:33.577: RTP(8082): fp tx d=217.218.20.86(14372), pt=8, ts=B845D5FF, ssrc=23B61458
*May 1 18:58:33.585: RTP(232): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0CFEC, ssrc=3BFC663F
*May 1 18:58:33.597: RTP(8083): fp tx d=217.218.20.86(14372), pt=8, ts=B845D69F, ssrc=23B61458
*May 1 18:58:33.605: RTP(233): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0D08C, ssrc=3BFC663F
*May 1 18:58:33.617: RTP(8084): fp tx d=217.218.20.86(14372), pt=8, ts=B845D73F, ssrc=23B61458
*May 1 18:58:33.625: RTP(234): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0D12C, ssrc=3BFC663F
*May 1 18:58:33.637: RTP(8085): fp tx d=217.218.20.86(14372), pt=8, ts=B845D7DF, ssrc=23B61458
*May 1 18:58:33.645: RTP(235): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0D1CC, ssrc=3BFC663F
*May 1 18:58:33.657: RTP(8086): fp tx d=217.218.20.86(14372), pt=8, ts=B845D87F, ssrc=23B61458
*May 1 18:58:33.665: RTP(236): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0D26C, ssrc=3BFC663F
*May 1 18:58:33.677: RTP(8087): fp tx d=217.218.20.86(14372), pt=8, ts=B845D91F, ssrc=23B61458
*May 1 18:58:33.685: RTP(237): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0D30C, ssrc=3BFC663F
*May 1 18:58:33.697: RTP(8088): fp tx d=217.218.20.86(14372), pt=8, ts=B845D9BF, ssrc=23B61458
*May 1 18:58:33.705: RTP(238): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0D3AC, ssrc=3BFC663F
*May 1 18:58:33.717: RTP(8089): fp tx d=217.218.20.86(14372), pt=8, ts=B845DA5F, ssrc=23B61458
*May 1 18:58:33.725: RTP(239): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0D44C, ssrc=3BFC663F
*May 1 18:58:33.737: RTP(8090): fp tx d=217.218.20.86(14372), pt=8, ts=B845DAFF, ssrc=23B61458
*May 1 18:58:33.745: RTP(240): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0D4EC, ssrc=3BFC663F
*May 1 18:58:33.757: RTP(8091): fp tx d=217.218.20.86(14372), pt=8, ts=B845DB9F, ssrc=23B61458
*May 1 18:58:33.765: RTP(241): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0D58C, ssrc=3BFC663F
*May 1 18:58:33.777: RTP(8092): fp tx d=217.218.20.86(14372), pt=8, ts=B845DC3F, ssrc=23B61458
*May 1 18:58:33.785: RTP(242): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0D62C, ssrc=3BFC663F
*May 1 18:58:33.797: RTP(8093): fp tx d=217.218.20.86(14372), pt=8, ts=B845DCDF, ssrc=23B61458
*May 1 18:58:33.805: RTP(243): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0D6CC, ssrc=3BFC663F
*May 1 18:58:33.817: RTP(8094): fp tx d=217.218.20.86(14372), pt=8, ts=B845DD7F, ssrc=23B61458
*May 1 18:58:33.825: RTP(244): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0D76C, ssrc=3BFC663F
*May 1 18:58:33.837: RTP(8095): fp tx d=217.218.20.86(14372), pt=8, ts=B845DE1F, ssrc=23B61458
*May 1 18:58:33.845: RTP(245): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0D80C, ssrc=3BFC663F
*May 1 18:58:33.857: RTP(8096): fp tx d=217.218.20.86(14372), pt=8, ts=B845DEBF, ssrc=23B61458
*May 1 18:58:33.865: RTP(246): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0D8AC, ssrc=3BFC663F
*May 1 18:58:33.877: RTP(8097): fp tx d=217.218.20.86(14372), pt=8, ts=B845DF5F, ssrc=23B61458
*May 1 18:58:33.885: RTP(247): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0D94C, ssrc=3BFC663F
*May 1 18:58:33.897: RTP(8098): fp tx d=217.218.20.86(14372), pt=8, ts=B845DFFF, ssrc=23B61458
*May 1 18:58:33.905: RTP(248): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0D9EC, ssrc=3BFC663F
*May 1 18:58:33.917: RTP(8099): fp tx d=217.218.20.86(14372), pt=8, ts=B845E09F, ssrc=23B61458
*May 1 18:58:33.925: RTP(249): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0DA8C, ssrc=3BFC663F
*May 1 18:58:33.937: RTP(8100): fp tx d=217.218.20.86(14372), pt=8, ts=B845E13F, ssrc=23B61458
*May 1 18:58:33.945: RTP(250): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0DB2C, ssrc=3BFC663F
*May 1 18:58:33.957: RTP(8101): fp tx d=217.218.20.86(14372), pt=8, ts=B845E1DF, ssrc=23B61458
*May 1 18:58:33.965: RTP(251): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0DBCC, ssrc=3BFC663F
*May 1 18:58:33.977: RTP(8102): fp tx d=217.218.20.86(14372), pt=8, ts=B845E27F, ssrc=23B61458
*May 1 18:58:33.985: RTP(252): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0DC6C, ssrc=3BFC663F
*May 1 18:58:33.997: RTP(8103): fp tx d=217.218.20.86(14372), pt=8, ts=B845E31F, ssrc=23B61458
*May 1 18:58:34.005: RTP(253): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0DD0C, ssrc=3BFC663F
*May 1 18:58:34.017: RTP(8104): fp tx d=217.218.20.86(14372), pt=8, ts=B845E3BF, ssrc=23B61458
*May 1 18:58:34.025: RTP(254): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0DDAC, ssrc=3BFC663F
*May 1 18:58:34.037: RTP(8105): fp tx d=217.218.20.86(14372), pt=8, ts=B845E45F, ssrc=23B61458
*May 1 18:58:34.045: RTP(255): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0DE4C, ssrc=3BFC663F
*May 1 18:58:34.057: RTP(8106): fp tx d=217.218.20.86(14372), pt=8, ts=B845E4FF, ssrc=23B61458
*May 1 18:58:34.065: RTP(256): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0DEEC, ssrc=3BFC663F
*May 1 18:58:34.077: RTP(8107): fp tx d=217.218.20.86(14372), pt=8, ts=B845E59F, ssrc=23B61458
*May 1 18:58:34.085: RTP(257): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0DF8C, ssrc=3BFC663F
*May 1 18:58:34.097: RTP(8108): fp tx d=217.218.20.86(14372), pt=8, ts=B845E63F, ssrc=23B61458
*May 1 18:58:34.105: RTP(258): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0E02C, ssrc=3BFC663F
*May 1 18:58:34.117: RTP(8109): fp tx d=217.218.20.86(14372), pt=8, ts=B845E6DF, ssrc=23B61458
*May 1 18:58:34.125: RTP(259): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0E0CC, ssrc=3BFC663F
*May 1 18:58:34.137: RTP(8110): fp tx d=217.218.20.86(14372), pt=8, ts=B845E77F, ssrc=23B61458
*May 1 18:58:34.145: RTP(260): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0E16C, ssrc=3BFC663F
*May 1 18:58:34.157: RTP(8111): fp tx d=217.218.20.86(14372), pt=8, ts=B845E81F, ssrc=23B61458
*May 1 18:58:34.165: RTP(261): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0E20C, ssrc=3BFC663F
*May 1 18:58:34.177: RTP(8112): fp tx d=217.218.20.86(14372), pt=8, ts=B845E8BF, ssrc=23B61458
*May 1 18:58:34.185: RTP(262): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0E2AC, ssrc=3BFC663F
*May 1 18:58:34.197: RTP(8113): fp tx d=217.218.20.86(14372), pt=8, ts=B845E95F, ssrc=23B61458
*May 1 18:58:34.205: RTP(263): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0E34C, ssrc=3BFC663F
*May 1 18:58:34.217: RTP(8114): fp tx d=217.218.20.86(14372), pt=8, ts=B845E9FF, ssrc=23B61458
*May 1 18:58:34.225: RTP(264): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0E3EC, ssrc=3BFC663F
*May 1 18:58:34.237: RTP(8115): fp tx d=217.218.20.86(14372), pt=8, ts=B845EA9F, ssrc=23B61458
*May 1 18:58:34.245: RTP(265): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0E48C, ssrc=3BFC663F
*May 1 18:58:34.257: RTP(8116): fp tx d=217.218.20.86(14372), pt=8, ts=B845EB3F, ssrc=23B61458
*May 1 18:58:34.265: RTP(266): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0E52C, ssrc=3BFC663F
*May 1 18:58:34.277: RTP(8117): fp tx d=217.218.20.86(14372), pt=8, ts=B845EBDF, ssrc=23B61458
*May 1 18:58:34.285: RTP(267): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0E5CC, ssrc=3BFC663F
*May 1 18:58:34.297: RTP(8118): fp tx d=217.218.20.86(14372), pt=8, ts=B845EC7F, ssrc=23B61458
*May 1 18:58:34.305: RTP(268): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0E66C, ssrc=3BFC663F
*May 1 18:58:34.317: RTP(8119): fp tx d=217.218.20.86(14372), pt=8, ts=B845ED1F, ssrc=23B61458
*May 1 18:58:34.325: RTP(269): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0E70C, ssrc=3BFC663F
*May 1 18:58:34.337: RTP(8120): fp tx d=217.218.20.86(14372), pt=8, ts=B845EDBF, ssrc=23B61458
*May 1 18:58:34.345: RTP(270): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0E7AC, ssrc=3BFC663F
*May 1 18:58:34.357: RTP(8121): fp tx d=217.218.20.86(14372), pt=8, ts=B845EE5F, ssrc=23B61458
*May 1 18:58:34.365: RTP(271): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0E84C, ssrc=3BFC663F
*May 1 18:58:34.377: RTP(8122): fp tx d=217.218.20.86(14372), pt=8, ts=B845EEFF, ssrc=23B61458
*May 1 18:58:34.385: RTP(272): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0E8EC, ssrc=3BFC663F
*May 1 18:58:34.397: RTP(8123): fp tx d=217.218.20.86(14372), pt=8, ts=B845EF9F, ssrc=23B61458
*May 1 18:58:34.405: RTP(273): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0E98C, ssrc=3BFC663F
*May 1 18:58:34.417: RTP(8124): fp tx d=217.218.20.86(14372), pt=8, ts=B845F03F, ssrc=23B61458
*May 1 18:58:34.425: RTP(274): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0EA2C, ssrc=3BFC663F
*May 1 18:58:34.437: RTP(8125): fp tx d=217.218.20.86(14372), pt=8, ts=B845F0DF, ssrc=23B61458
*May 1 18:58:34.445: RTP(275): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0EACC, ssrc=3BFC663F
*May 1 18:58:34.457: RTP(8126): fp tx d=217.218.20.86(14372), pt=8, ts=B845F17F, ssrc=23B61458
*May 1 18:58:34.465: RTP(276): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0EB6C, ssrc=3BFC663F
*May 1 18:58:34.477: RTP(8127): fp tx d=217.218.20.86(14372), pt=8, ts=B845F21F, ssrc=23B61458
*May 1 18:58:34.485: RTP(277): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0EC0C, ssrc=3BFC663F
*May 1 18:58:34.497: RTP(8128): fp tx d=217.218.20.86(14372), pt=8, ts=B845F2BF, ssrc=23B61458
*May 1 18:58:34.505: RTP(278): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0ECAC, ssrc=3BFC663F
*May 1 18:58:34.517: RTP(8129): fp tx d=217.218.20.86(14372), pt=8, ts=B845F35F, ssrc=23B61458
*May 1 18:58:34.525: RTP(279): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0ED4C, ssrc=3BFC663F
*May 1 18:58:34.537: RTP(8130): fp tx d=217.218.20.86(14372), pt=8, ts=B845F3FF, ssrc=23B61458
*May 1 18:58:34.545: RTP(280): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0EDEC, ssrc=3BFC663F
*May 1 18:58:34.557: RTP(8131): fp tx d=217.218.20.86(14372), pt=8, ts=B845F49F, ssrc=23B61458
*May 1 18:58:34.565: RTP(281): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0EE8C, ssrc=3BFC663F
*May 1 18:58:34.577: RTP(8132): fp tx d=217.218.20.86(14372), pt=8, ts=B845F53F, ssrc=23B61458
*May 1 18:58:34.585: RTP(282): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0EF2C, ssrc=3BFC663F
*May 1 18:58:34.597: RTP(8133): fp tx d=217.218.20.86(14372), pt=8, ts=B845F5DF, ssrc=23B61458
*May 1 18:58:34.605: RTP(283): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0EFCC, ssrc=3BFC663F
*May 1 18:58:34.617: RTP(8134): fp tx d=217.218.20.86(14372), pt=8, ts=B845F67F, ssrc=23B61458
*May 1 18:58:34.625: RTP(284): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0F06C, ssrc=3BFC663F
*May 1 18:58:34.637: RTP(8135): fp tx d=217.218.20.86(14372), pt=8, ts=B845F71F, ssrc=23B61458
*May 1 18:58:34.645: RTP(285): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0F10C, ssrc=3BFC663F
*May 1 18:58:34.657: RTP(8136): fp tx d=217.218.20.86(14372), pt=8, ts=B845F7BF, ssrc=23B61458
*May 1 18:58:34.665: RTP(286): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0F1AC, ssrc=3BFC663F
*May 1 18:58:34.677: RTP(8137): fp tx d=217.218.20.86(14372), pt=8, ts=B845F85F, ssrc=23B61458
*May 1 18:58:34.685: RTP(287): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0F24C, ssrc=3BFC663F
*May 1 18:58:34.697: RTP(8138): fp tx d=217.218.20.86(14372), pt=8, ts=B845F8FF, ssrc=23B61458
*May 1 18:58:34.705: RTP(288): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0F2EC, ssrc=3BFC663F
*May 1 18:58:34.717: RTP(8139): fp tx d=217.218.20.86(14372), pt=8, ts=B845F99F, ssrc=23B61458
*May 1 18:58:34.725: RTP(289): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0F38C, ssrc=3BFC663F
*May 1 18:58:34.737: RTP(8140): fp tx d=217.218.20.86(14372), pt=8, ts=B845FA3F, ssrc=23B61458
*May 1 18:58:34.745: RTP(290): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0F42C, ssrc=3BFC663F
*May 1 18:58:34.757: RTP(8141): fp tx d=217.218.20.86(14372), pt=8, ts=B845FADF, ssrc=23B61458
*May 1 18:58:34.765: RTP(291): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0F4CC, ssrc=3BFC663F
*May 1 18:58:34.777: RTP(8142): fp tx d=217.218.20.86(14372), pt=8, ts=B845FB7F, ssrc=23B61458
*May 1 18:58:34.785: RTP(292): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0F56C, ssrc=3BFC663F
*May 1 18:58:34.797: RTP(8143): fp tx d=217.218.20.86(14372), pt=8, ts=B845FC1F, ssrc=23B61458
*May 1 18:58:34.805: RTP(293): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0F60C, ssrc=3BFC663F
*May 1 18:58:34.817: RTP(8144): fp tx d=217.218.20.86(14372), pt=8, ts=B845FCBF, ssrc=23B61458
*May 1 18:58:34.825: RTP(294): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0F6AC, ssrc=3BFC663F
*May 1 18:58:34.837: RTP(8145): fp tx d=217.218.20.86(14372), pt=8, ts=B845FD5F, ssrc=23B61458
*May 1 18:58:34.845: RTP(295): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0F74C, ssrc=3BFC663F
*May 1 18:58:34.857: RTP(8146): fp tx d=217.218.20.86(14372), pt=8, ts=B845FDFF, ssrc=23B61458
*May 1 18:58:34.865: RTP(296): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0F7EC, ssrc=3BFC663F
*May 1 18:58:34.877: RTP(8147): fp tx d=217.218.20.86(14372), pt=8, ts=B845FE9F, ssrc=23B61458
*May 1 18:58:34.885: RTP(297): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0F88C, ssrc=3BFC663F
*May 1 18:58:34.897: RTP(8148): fp tx d=217.218.20.86(14372), pt=8, ts=B845FF3F, ssrc=23B61458
*May 1 18:58:34.905: RTP(298): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0F92C, ssrc=3BFC663F
*May 1 18:58:34.917: RTP(8149): fp tx d=217.218.20.86(14372), pt=8, ts=B845FFDF, ssrc=23B61458
*May 1 18:58:34.925: RTP(299): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0F9CC, ssrc=3BFC663F
*May 1 18:58:34.937: RTP(8150): fp tx d=217.218.20.86(14372), pt=8, ts=B846007F, ssrc=23B61458
*May 1 18:58:34.945: RTP(300): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0FA6C, ssrc=3BFC663F
*May 1 18:58:34.957: RTP(8151): fp tx d=217.218.20.86(14372), pt=8, ts=B846011F, ssrc=23B61458
*May 1 18:58:34.965: RTP(301): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0FB0C, ssrc=3BFC663F
*May 1 18:58:34.977: RTP(8152): fp tx d=217.218.20.86(14372), pt=8, ts=B84601BF, ssrc=23B61458
*May 1 18:58:34.985: RTP(302): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0FBAC, ssrc=3BFC663F
*May 1 18:58:34.997: RTP(8153): fp tx d=217.218.20.86(14372), pt=8, ts=B846025F, ssrc=23B61458
*May 1 18:58:35.005: RTP(303): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0FC4C, ssrc=3BFC663F
*May 1 18:58:35.017: RTP(8154): fp tx d=217.218.20.86(14372), pt=8, ts=B84602FF, ssrc=23B61458
*May 1 18:58:35.025: RTP(304): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0FCEC, ssrc=3BFC663F
*May 1 18:58:35.037: RTP(8155): fp tx d=217.218.20.86(14372), pt=8, ts=B846039F, ssrc=23B61458
*May 1 18:58:35.045: RTP(305): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0FD8C, ssrc=3BFC663F
*May 1 18:58:35.057: RTP(8156): fp tx d=217.218.20.86(14372), pt=8, ts=B846043F, ssrc=23B61458
*May 1 18:58:35.065: RTP(306): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0FE2C, ssrc=3BFC663F
*May 1 18:58:35.077: RTP(8157): fp tx d=217.218.20.86(14372), pt=8, ts=B84604DF, ssrc=23B61458
*May 1 18:58:35.085: RTP(307): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0FECC, ssrc=3BFC663F
*May 1 18:58:35.097: RTP(8158): fp tx d=217.218.20.86(14372), pt=8, ts=B846057F, ssrc=23B61458
*May 1 18:58:35.105: RTP(308): fs rx d=217.218.20.86(14372), pt=8, ts=3EB0FF6C, ssrc=3BFC663F
*May 1 18:58:35.117: RTP(8159): fp tx d=217.218.20.86(14372), pt=8, ts=B846061F, ssrc=23B61458
*May 1 18:58:35.125: RTP(309): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1000C, ssrc=3BFC663F
*May 1 18:58:35.137: RTP(8160): fp tx d=217.218.20.86(14372), pt=8, ts=B84606BF, ssrc=23B61458
*May 1 18:58:35.145: RTP(310): fs rx d=217.218.20.86(14372), pt=8, ts=3EB100AC, ssrc=3BFC663F
*May 1 18:58:35.157: RTP(8161): fp tx d=217.218.20.86(14372), pt=8, ts=B846075F, ssrc=23B61458
*May 1 18:58:35.165: RTP(311): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1014C, ssrc=3BFC663F
*May 1 18:58:35.177: RTP(8162): fp tx d=217.218.20.86(14372), pt=8, ts=B84607FF, ssrc=23B61458
*May 1 18:58:35.185: RTP(312): fs rx d=217.218.20.86(14372), pt=8, ts=3EB101EC, ssrc=3BFC663F
*May 1 18:58:35.197: RTP(8163): fp tx d=217.218.20.86(14372), pt=8, ts=B846089F, ssrc=23B61458
*May 1 18:58:35.205: RTP(313): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1028C, ssrc=3BFC663F
*May 1 18:58:35.217: RTP(8164): fp tx d=217.218.20.86(14372), pt=8, ts=B846093F, ssrc=23B61458
*May 1 18:58:35.225: RTP(314): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1032C, ssrc=3BFC663F
*May 1 18:58:35.237: RTP(8165): fp tx d=217.218.20.86(14372), pt=8, ts=B84609DF, ssrc=23B61458
*May 1 18:58:35.245: RTP(315): fs rx d=217.218.20.86(14372), pt=8, ts=3EB103CC, ssrc=3BFC663F
*May 1 18:58:35.257: RTP(8166): fp tx d=217.218.20.86(14372), pt=8, ts=B8460A7F, ssrc=23B61458
*May 1 18:58:35.265: RTP(316): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1046C, ssrc=3BFC663F
*May 1 18:58:35.277: RTP(8167): fp tx d=217.218.20.86(14372), pt=8, ts=B8460B1F, ssrc=23B61458
*May 1 18:58:35.285: RTP(317): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1050C, ssrc=3BFC663F
*May 1 18:58:35.297: RTP(8168): fp tx d=217.218.20.86(14372), pt=8, ts=B8460BBF, ssrc=23B61458
*May 1 18:58:35.305: RTP(318): fs rx d=217.218.20.86(14372), pt=8, ts=3EB105AC, ssrc=3BFC663F
*May 1 18:58:35.317: RTP(8169): fp tx d=217.218.20.86(14372), pt=8, ts=B8460C5F, ssrc=23B61458
*May 1 18:58:35.325: RTP(319): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1064C, ssrc=3BFC663F
*May 1 18:58:35.337: RTP(8170): fp tx d=217.218.20.86(14372), pt=8, ts=B8460CFF, ssrc=23B61458
*May 1 18:58:35.345: RTP(320): fs rx d=217.218.20.86(14372), pt=8, ts=3EB106EC, ssrc=3BFC663F
*May 1 18:58:35.357: RTP(8171): fp tx d=217.218.20.86(14372), pt=8, ts=B8460D9F, ssrc=23B61458
*May 1 18:58:35.365: RTP(321): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1078C, ssrc=3BFC663F
*May 1 18:58:35.377: RTP(8172): fp tx d=217.218.20.86(14372), pt=8, ts=B8460E3F, ssrc=23B61458
*May 1 18:58:35.385: RTP(322): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1082C, ssrc=3BFC663F
*May 1 18:58:35.397: RTP(8173): fp tx d=217.218.20.86(14372), pt=8, ts=B8460EDF, ssrc=23B61458
*May 1 18:58:35.405: RTP(323): fs rx d=217.218.20.86(14372), pt=8, ts=3EB108CC, ssrc=3BFC663F
*May 1 18:58:35.417: RTP(8174): fp tx d=217.218.20.86(14372), pt=8, ts=B8460F7F, ssrc=23B61458
*May 1 18:58:35.425: RTP(324): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1096C, ssrc=3BFC663F
*May 1 18:58:35.433: RTP(8175): fp tx d=217.218.20.86(14372), pt=8, ts=B846101F, ssrc=23B61458
*May 1 18:58:35.445: RTP(325): fs rx d=217.218.20.86(14372), pt=8, ts=3EB10A0C, ssrc=3BFC663F
*May 1 18:58:35.453: RTP(8176): fp tx d=217.218.20.86(14372), pt=8, ts=B84610BF, ssrc=23B61458
*May 1 18:58:35.465: RTP(326): fs rx d=217.218.20.86(14372), pt=8, ts=3EB10AAC, ssrc=3BFC663F
*May 1 18:58:35.473: RTP(8177): fp tx d=217.218.20.86(14372), pt=8, ts=B846115F, ssrc=23B61458
*May 1 18:58:35.485: RTP(327): fs rx d=217.218.20.86(14372), pt=8, ts=3EB10B4C, ssrc=3BFC663F
*May 1 18:58:35.493: RTP(8178): fp tx d=217.218.20.86(14372), pt=8, ts=B84611FF, ssrc=23B61458
*May 1 18:58:35.505: RTP(328): fs rx d=217.218.20.86(14372), pt=8, ts=3EB10BEC, ssrc=3BFC663F
*May 1 18:58:35.513: RTP(8179): fp tx d=217.218.20.86(14372), pt=8, ts=B846129F, ssrc=23B61458
*May 1 18:58:35.525: RTP(329): fs rx d=217.218.20.86(14372), pt=8, ts=3EB10C8C, ssrc=3BFC663F
*May 1 18:58:35.533: RTP(8180): fp tx d=217.218.20.86(14372), pt=8, ts=B846133F, ssrc=23B61458
*May 1 18:58:35.545: RTP(330): fs rx d=217.218.20.86(14372), pt=8, ts=3EB10D2C, ssrc=3BFC663F
*May 1 18:58:35.553: RTP(8181): fp tx d=217.218.20.86(14372), pt=8, ts=B84613DF, ssrc=23B61458
*May 1 18:58:35.565: RTP(331): fs rx d=217.218.20.86(14372), pt=8, ts=3EB10DCC, ssrc=3BFC663F
*May 1 18:58:35.573: RTP(8182): fp tx d=217.218.20.86(14372), pt=8, ts=B846147F, ssrc=23B61458
*May 1 18:58:35.585: RTP(332): fs rx d=217.218.20.86(14372), pt=8, ts=3EB10E6C, ssrc=3BFC663F
*May 1 18:58:35.593: RTP(8183): fp tx d=217.218.20.86(14372), pt=8, ts=B846151F, ssrc=23B61458
*May 1 18:58:35.605: RTP(333): fs rx d=217.218.20.86(14372), pt=8, ts=3EB10F0C, ssrc=3BFC663F
*May 1 18:58:35.613: RTP(8184): fp tx d=217.218.20.86(14372), pt=8, ts=B84615BF, ssrc=23B61458
*May 1 18:58:35.625: RTP(334): fs rx d=217.218.20.86(14372), pt=8, ts=3EB10FAC, ssrc=3BFC663F
*May 1 18:58:35.633: RTP(8185): fp tx d=217.218.20.86(14372), pt=8, ts=B846165F, ssrc=23B61458
*May 1 18:58:35.645: RTP(335): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1104C, ssrc=3BFC663F
*May 1 18:58:35.653: RTP(8186): fp tx d=217.218.20.86(14372), pt=8, ts=B84616FF, ssrc=23B61458
*May 1 18:58:35.665: RTP(336): fs rx d=217.218.20.86(14372), pt=8, ts=3EB110EC, ssrc=3BFC663F
*May 1 18:58:35.673: RTP(8187): fp tx d=217.218.20.86(14372), pt=8, ts=B846179F, ssrc=23B61458
*May 1 18:58:35.685: RTP(337): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1118C, ssrc=3BFC663F
*May 1 18:58:35.693: RTP(8188): fp tx d=217.218.20.86(14372), pt=8, ts=B846183F, ssrc=23B61458
*May 1 18:58:35.705: RTP(338): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1122C, ssrc=3BFC663F
*May 1 18:58:35.713: RTP(8189): fp tx d=217.218.20.86(14372), pt=8, ts=B84618DF, ssrc=23B61458
*May 1 18:58:35.725: RTP(339): fs rx d=217.218.20.86(14372), pt=8, ts=3EB112CC, ssrc=3BFC663F
*May 1 18:58:35.733: RTP(8190): fp tx d=217.218.20.86(14372), pt=8, ts=B846197F, ssrc=23B61458
*May 1 18:58:35.745: RTP(340): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1136C, ssrc=3BFC663F
*May 1 18:58:35.753: RTP(8191): fp tx d=217.218.20.86(14372), pt=8, ts=B8461A1F, ssrc=23B61458
*May 1 18:58:35.765: RTP(341): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1140C, ssrc=3BFC663F
*May 1 18:58:35.773: RTP(8192): fp tx d=217.218.20.86(14372), pt=8, ts=B8461ABF, ssrc=23B61458
*May 1 18:58:35.785: RTP(342): fs rx d=217.218.20.86(14372), pt=8, ts=3EB114AC, ssrc=3BFC663F
*May 1 18:58:35.793: RTP(8193): fp tx d=217.218.20.86(14372), pt=8, ts=B8461B5F, ssrc=23B61458
*May 1 18:58:35.805: RTP(343): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1154C, ssrc=3BFC663F
*May 1 18:58:35.813: RTP(8194): fp tx d=217.218.20.86(14372), pt=8, ts=B8461BFF, ssrc=23B61458
*May 1 18:58:35.825: RTP(344): fs rx d=217.218.20.86(14372), pt=8, ts=3EB115EC, ssrc=3BFC663F
*May 1 18:58:35.833: RTP(8195): fp tx d=217.218.20.86(14372), pt=8, ts=B8461C9F, ssrc=23B61458
*May 1 18:58:35.845: RTP(345): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1168C, ssrc=3BFC663F
*May 1 18:58:35.853: RTP(8196): fp tx d=217.218.20.86(14372), pt=8, ts=B8461D3F, ssrc=23B61458
*May 1 18:58:35.865: RTP(346): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1172C, ssrc=3BFC663F
*May 1 18:58:35.873: RTP(8197): fp tx d=217.218.20.86(14372), pt=8, ts=B8461DDF, ssrc=23B61458
*May 1 18:58:35.885: RTP(347): fs rx d=217.218.20.86(14372), pt=8, ts=3EB117CC, ssrc=3BFC663F
*May 1 18:58:35.893: RTP(8198): fp tx d=217.218.20.86(14372), pt=8, ts=B8461E7F, ssrc=23B61458
*May 1 18:58:35.905: RTP(348): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1186C, ssrc=3BFC663F
*May 1 18:58:35.913: RTP(8199): fp tx d=217.218.20.86(14372), pt=8, ts=B8461F1F, ssrc=23B61458
*May 1 18:58:35.925: RTP(349): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1190C, ssrc=3BFC663F
*May 1 18:58:35.933: RTP(8200): fp tx d=217.218.20.86(14372), pt=8, ts=B8461FBF, ssrc=23B61458
*May 1 18:58:35.945: RTP(350): fs rx d=217.218.20.86(14372), pt=8, ts=3EB119AC, ssrc=3BFC663F
*May 1 18:58:35.953: RTP(8201): fp tx d=217.218.20.86(14372), pt=8, ts=B846205F, ssrc=23B61458
*May 1 18:58:35.965: RTP(351): fs rx d=217.218.20.86(14372), pt=8, ts=3EB11A4C, ssrc=3BFC663F
*May 1 18:58:35.973: RTP(8202): fp tx d=217.218.20.86(14372), pt=8, ts=B84620FF, ssrc=23B61458
*May 1 18:58:35.985: RTP(352): fs rx d=217.218.20.86(14372), pt=8, ts=3EB11AEC, ssrc=3BFC663F
*May 1 18:58:35.993: RTP(8203): fp tx d=217.218.20.86(14372), pt=8, ts=B846219F, ssrc=23B61458
*May 1 18:58:36.005: RTP(353): fs rx d=217.218.20.86(14372), pt=8, ts=3EB11B8C, ssrc=3BFC663F
*May 1 18:58:36.013: RTP(8204): fp tx d=217.218.20.86(14372), pt=8, ts=B846223F, ssrc=23B61458
*May 1 18:58:36.025: RTP(354): fs rx d=217.218.20.86(14372), pt=8, ts=3EB11C2C, ssrc=3BFC663F
*May 1 18:58:36.033: RTP(8205): fp tx d=217.218.20.86(14372), pt=8, ts=B84622DF, ssrc=23B61458
*May 1 18:58:36.045: RTP(355): fs rx d=217.218.20.86(14372), pt=8, ts=3EB11CCC, ssrc=3BFC663F
*May 1 18:58:36.053: RTP(8206): fp tx d=217.218.20.86(14372), pt=8, ts=B846237F, ssrc=23B61458
*May 1 18:58:36.065: RTP(356): fs rx d=217.218.20.86(14372), pt=8, ts=3EB11D6C, ssrc=3BFC663F
*May 1 18:58:36.073: RTP(8207): fp tx d=217.218.20.86(14372), pt=8, ts=B846241F, ssrc=23B61458
*May 1 18:58:36.085: RTP(357): fs rx d=217.218.20.86(14372), pt=8, ts=3EB11E0C, ssrc=3BFC663F
*May 1 18:58:36.093: RTP(8208): fp tx d=217.218.20.86(14372), pt=8, ts=B84624BF, ssrc=23B61458
*May 1 18:58:36.105: RTP(358): fs rx d=217.218.20.86(14372), pt=8, ts=3EB11EAC, ssrc=3BFC663F
*May 1 18:58:36.113: RTP(8209): fp tx d=217.218.20.86(14372), pt=8, ts=B846255F, ssrc=23B61458
*May 1 18:58:36.125: RTP(359): fs rx d=217.218.20.86(14372), pt=8, ts=3EB11F4C, ssrc=3BFC663F
*May 1 18:58:36.133: RTP(8210): fp tx d=217.218.20.86(14372), pt=8, ts=B84625FF, ssrc=23B61458
*May 1 18:58:36.145: RTP(360): fs rx d=217.218.20.86(14372), pt=8, ts=3EB11FEC, ssrc=3BFC663F
*May 1 18:58:36.153: RTP(8211): fp tx d=217.218.20.86(14372), pt=8, ts=B846269F, ssrc=23B61458
*May 1 18:58:36.165: RTP(361): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1208C, ssrc=3BFC663F
*May 1 18:58:36.173: RTP(8212): fp tx d=217.218.20.86(14372), pt=8, ts=B846273F, ssrc=23B61458
*May 1 18:58:36.185: RTP(362): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1212C, ssrc=3BFC663F
*May 1 18:58:36.193: RTP(8213): fp tx d=217.218.20.86(14372), pt=8, ts=B84627DF, ssrc=23B61458
*May 1 18:58:36.205: RTP(363): fs rx d=217.218.20.86(14372), pt=8, ts=3EB121CC, ssrc=3BFC663F
*May 1 18:58:36.213: RTP(8214): fp tx d=217.218.20.86(14372), pt=8, ts=B846287F, ssrc=23B61458
*May 1 18:58:36.225: RTP(364): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1226C, ssrc=3BFC663F
*May 1 18:58:36.233: RTP(8215): fp tx d=217.218.20.86(14372), pt=8, ts=B846291F, ssrc=23B61458
*May 1 18:58:36.245: RTP(365): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1230C, ssrc=3BFC663F
*May 1 18:58:36.253: RTP(8216): fp tx d=217.218.20.86(14372), pt=8, ts=B84629BF, ssrc=23B61458
*May 1 18:58:36.265: RTP(366): fs rx d=217.218.20.86(14372), pt=8, ts=3EB123AC, ssrc=3BFC663F
*May 1 18:58:36.273: RTP(8217): fp tx d=217.218.20.86(14372), pt=8, ts=B8462A5F, ssrc=23B61458
*May 1 18:58:36.285: RTP(367): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1244C, ssrc=3BFC663F
*May 1 18:58:36.293: RTP(8218): fp tx d=217.218.20.86(14372), pt=8, ts=B8462AFF, ssrc=23B61458
*May 1 18:58:36.305: RTP(368): fs rx d=217.218.20.86(14372), pt=8, ts=3EB124EC, ssrc=3BFC663F
*May 1 18:58:36.313: RTP(8219): fp tx d=217.218.20.86(14372), pt=8, ts=B8462B9F, ssrc=23B61458
*May 1 18:58:36.325: RTP(369): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1258C, ssrc=3BFC663F
*May 1 18:58:36.333: RTP(8220): fp tx d=217.218.20.86(14372), pt=8, ts=B8462C3F, ssrc=23B61458
*May 1 18:58:36.345: RTP(370): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1262C, ssrc=3BFC663F
*May 1 18:58:36.353: RTP(8221): fp tx d=217.218.20.86(14372), pt=8, ts=B8462CDF, ssrc=23B61458
*May 1 18:58:36.365: RTP(371): fs rx d=217.218.20.86(14372), pt=8, ts=3EB126CC, ssrc=3BFC663F
*May 1 18:58:36.373: RTP(8222): fp tx d=217.218.20.86(14372), pt=8, ts=B8462D7F, ssrc=23B61458
*May 1 18:58:36.385: RTP(372): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1276C, ssrc=3BFC663F
*May 1 18:58:36.393: RTP(8223): fp tx d=217.218.20.86(14372), pt=8, ts=B8462E1F, ssrc=23B61458
*May 1 18:58:36.405: RTP(373): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1280C, ssrc=3BFC663F
*May 1 18:58:36.413: RTP(8224): fp tx d=217.218.20.86(14372), pt=8, ts=B8462EBF, ssrc=23B61458
*May 1 18:58:36.425: RTP(374): fs rx d=217.218.20.86(14372), pt=8, ts=3EB128AC, ssrc=3BFC663F
*May 1 18:58:36.433: RTP(8225): fp tx d=217.218.20.86(14372), pt=8, ts=B8462F5F, ssrc=23B61458
*May 1 18:58:36.445: RTP(375): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1294C, ssrc=3BFC663F
*May 1 18:58:36.453: RTP(8226): fp tx d=217.218.20.86(14372), pt=8, ts=B8462FFF, ssrc=23B61458
*May 1 18:58:36.465: RTP(376): fs rx d=217.218.20.86(14372), pt=8, ts=3EB129EC, ssrc=3BFC663F
*May 1 18:58:36.473: RTP(8227): fp tx d=217.218.20.86(14372), pt=8, ts=B846309F, ssrc=23B61458
*May 1 18:58:36.473: voip_rtcp_stats_req: Calculated remaining disc time is 0 msec...Media Inactivity Criteria is 0
*May 1 18:58:36.485: RTP(377): fs rx d=217.218.20.86(14372), pt=8, ts=3EB12A8C, ssrc=3BFC663F
*May 1 18:58:36.493: RTP(8228): fp tx d=217.218.20.86(14372), pt=8, ts=B846313F, ssrc=23B61458
*May 1 18:58:36.505: RTP(378): fs rx d=217.218.20.86(14372), pt=8, ts=3EB12B2C, ssrc=3BFC663F
*May 1 18:58:36.513: RTP(8229): fp tx d=217.218.20.86(14372), pt=8, ts=B84631DF, ssrc=23B61458
*May 1 18:58:36.525: RTP(379): fs rx d=217.218.20.86(14372), pt=8, ts=3EB12BCC, ssrc=3BFC663F
*May 1 18:58:36.533: RTP(8230): fp tx d=217.218.20.86(14372), pt=8, ts=B846327F, ssrc=23B61458
*May 1 18:58:36.545: RTP(380): fs rx d=217.218.20.86(14372), pt=8, ts=3EB12C6C, ssrc=3BFC663F
*May 1 18:58:36.553: RTP(8231): fp tx d=217.218.20.86(14372), pt=8, ts=B846331F, ssrc=23B61458
*May 1 18:58:36.565: RTP(381): fs rx d=217.218.20.86(14372), pt=8, ts=3EB12D0C, ssrc=3BFC663F
*May 1 18:58:36.573: RTP(8232): fp tx d=217.218.20.86(14372), pt=8, ts=B84633BF, ssrc=23B61458
*May 1 18:58:36.585: RTP(382): fs rx d=217.218.20.86(14372), pt=8, ts=3EB12DAC, ssrc=3BFC663F
*May 1 18:58:36.593: RTP(8233): fp tx d=217.218.20.86(14372), pt=8, ts=B846345F, ssrc=23B61458
*May 1 18:58:36.605: RTP(383): fs rx d=217.218.20.86(14372), pt=8, ts=3EB12E4C, ssrc=3BFC663F
*May 1 18:58:36.613: RTP(8234): fp tx d=217.218.20.86(14372), pt=8, ts=B84634FF, ssrc=23B61458
*May 1 18:58:36.625: RTP(384): fs rx d=217.218.20.86(14372), pt=8, ts=3EB12EEC, ssrc=3BFC663F
*May 1 18:58:36.633: RTP(8235): fp tx d=217.218.20.86(14372), pt=8, ts=B846359F, ssrc=23B61458
*May 1 18:58:36.645: RTP(385): fs rx d=217.218.20.86(14372), pt=8, ts=3EB12F8C, ssrc=3BFC663F
*May 1 18:58:36.653: RTP(8236): fp tx d=217.218.20.86(14372), pt=8, ts=B846363F, ssrc=23B61458
*May 1 18:58:36.665: RTP(386): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1302C, ssrc=3BFC663F
*May 1 18:58:36.673: RTP(8237): fp tx d=217.218.20.86(14372), pt=8, ts=B84636DF, ssrc=23B61458
*May 1 18:58:36.685: RTP(387): fs rx d=217.218.20.86(14372), pt=8, ts=3EB130CC, ssrc=3BFC663F
*May 1 18:58:36.693: RTP(8238): fp tx d=217.218.20.86(14372), pt=8, ts=B846377F, ssrc=23B61458
*May 1 18:58:36.705: RTP(388): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1316C, ssrc=3BFC663F
*May 1 18:58:36.713: RTP(8239): fp tx d=217.218.20.86(14372), pt=8, ts=B846381F, ssrc=23B61458
*May 1 18:58:36.725: RTP(389): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1320C, ssrc=3BFC663F
*May 1 18:58:36.733: RTP(8240): fp tx d=217.218.20.86(14372), pt=8, ts=B84638BF, ssrc=23B61458
*May 1 18:58:36.745: RTP(390): fs rx d=217.218.20.86(14372), pt=8, ts=3EB132AC, ssrc=3BFC663F
*May 1 18:58:36.753: RTP(8241): fp tx d=217.218.20.86(14372), pt=8, ts=B846395F, ssrc=23B61458
*May 1 18:58:36.765: RTP(391): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1334C, ssrc=3BFC663F
*May 1 18:58:36.773: RTP(8242): fp tx d=217.218.20.86(14372), pt=8, ts=B84639FF, ssrc=23B61458
*May 1 18:58:36.785: RTP(392): fs rx d=217.218.20.86(14372), pt=8, ts=3EB133EC, ssrc=3BFC663F
*May 1 18:58:36.793: RTP(8243): fp tx d=217.218.20.86(14372), pt=8, ts=B8463A9F, ssrc=23B61458
*May 1 18:58:36.805: RTP(393): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1348C, ssrc=3BFC663F
*May 1 18:58:36.813: RTP(8244): fp tx d=217.218.20.86(14372), pt=8, ts=B8463B3F, ssrc=23B61458
*May 1 18:58:36.825: RTP(394): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1352C, ssrc=3BFC663F
*May 1 18:58:36.833: RTP(8245): fp tx d=217.218.20.86(14372), pt=8, ts=B8463BDF, ssrc=23B61458
*May 1 18:58:36.845: RTP(395): fs rx d=217.218.20.86(14372), pt=8, ts=3EB135CC, ssrc=3BFC663F
*May 1 18:58:36.853: RTP(8246): fp tx d=217.218.20.86(14372), pt=8, ts=B8463C7F, ssrc=23B61458
*May 1 18:58:36.865: RTP(396): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1366C, ssrc=3BFC663F
*May 1 18:58:36.873: RTP(8247): fp tx d=217.218.20.86(14372), pt=8, ts=B8463D1F, ssrc=23B61458
*May 1 18:58:36.885: RTP(397): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1370C, ssrc=3BFC663F
*May 1 18:58:36.893: RTP(8248): fp tx d=217.218.20.86(14372), pt=8, ts=B8463DBF, ssrc=23B61458
*May 1 18:58:36.905: RTP(398): fs rx d=217.218.20.86(14372), pt=8, ts=3EB137AC, ssrc=3BFC663F
*May 1 18:58:36.913: RTP(8249): fp tx d=217.218.20.86(14372), pt=8, ts=B8463E5F, ssrc=23B61458
*May 1 18:58:36.925: RTP(399): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1384C, ssrc=3BFC663F
*May 1 18:58:36.933: RTP(8250): fp tx d=217.218.20.86(14372), pt=8, ts=B8463EFF, ssrc=23B61458
*May 1 18:58:36.945: RTP(400): fs rx d=217.218.20.86(14372), pt=8, ts=3EB138EC, ssrc=3BFC663F
*May 1 18:58:36.953: RTP(8251): fp tx d=217.218.20.86(14372), pt=8, ts=B8463F9F, ssrc=23B61458
*May 1 18:58:36.961: RTP(401): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1398C, ssrc=3BFC663F
*May 1 18:58:36.973: RTP(8252): fp tx d=217.218.20.86(14372), pt=8, ts=B846403F, ssrc=23B61458
*May 1 18:58:36.985: RTP(402): fs rx d=217.218.20.86(14372), pt=8, ts=3EB13A2C, ssrc=3BFC663F
*May 1 18:58:36.993: RTP(8253): fp tx d=217.218.20.86(14372), pt=8, ts=B84640DF, ssrc=23B61458
*May 1 18:58:37.005: RTP(403): fs rx d=217.218.20.86(14372), pt=8, ts=3EB13ACC, ssrc=3BFC663F
*May 1 18:58:37.013: RTP(8254): fp tx d=217.218.20.86(14372), pt=8, ts=B846417F, ssrc=23B61458
*May 1 18:58:37.025: RTP(404): fs rx d=217.218.20.86(14372), pt=8, ts=3EB13B6C, ssrc=3BFC663F
*May 1 18:58:37.033: RTP(8255): fp tx d=217.218.20.86(14372), pt=8, ts=B846421F, ssrc=23B61458
*May 1 18:58:37.045: RTP(405): fs rx d=217.218.20.86(14372), pt=8, ts=3EB13C0C, ssrc=3BFC663F
*May 1 18:58:37.053: RTP(8256): fp tx d=217.218.20.86(14372), pt=8, ts=B84642BF, ssrc=23B61458
*May 1 18:58:37.065: RTP(406): fs rx d=217.218.20.86(14372), pt=8, ts=3EB13CAC, ssrc=3BFC663F
*May 1 18:58:37.073: RTP(8257): fp tx d=217.218.20.86(14372), pt=8, ts=B846435F, ssrc=23B61458
*May 1 18:58:37.085: RTP(407): fs rx d=217.218.20.86(14372), pt=8, ts=3EB13D4C, ssrc=3BFC663F
*May 1 18:58:37.093: RTP(8258): fp tx d=217.218.20.86(14372), pt=8, ts=B84643FF, ssrc=23B61458
*May 1 18:58:37.105: RTP(408): fs rx d=217.218.20.86(14372), pt=8, ts=3EB13DEC, ssrc=3BFC663F
*May 1 18:58:37.113: RTP(8259): fp tx d=217.218.20.86(14372), pt=8, ts=B846449F, ssrc=23B61458
*May 1 18:58:37.125: RTP(409): fs rx d=217.218.20.86(14372), pt=8, ts=3EB13E8C, ssrc=3BFC663F
*May 1 18:58:37.133: RTP(8260): fp tx d=217.218.20.86(14372), pt=8, ts=B846453F, ssrc=23B61458
*May 1 18:58:37.145: RTP(410): fs rx d=217.218.20.86(14372), pt=8, ts=3EB13F2C, ssrc=3BFC663F
*May 1 18:58:37.153: RTP(8261): fp tx d=217.218.20.86(14372), pt=8, ts=B84645DF, ssrc=23B61458
*May 1 18:58:37.165: RTP(411): fs rx d=217.218.20.86(14372), pt=8, ts=3EB13FCC, ssrc=3BFC663F
*May 1 18:58:37.173: RTP(8262): fp tx d=217.218.20.86(14372), pt=8, ts=B846467F, ssrc=23B61458
*May 1 18:58:37.185: RTP(412): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1406C, ssrc=3BFC663F
*May 1 18:58:37.193: RTP(8263): fp tx d=217.218.20.86(14372), pt=8, ts=B846471F, ssrc=23B61458
*May 1 18:58:37.205: RTP(413): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1410C, ssrc=3BFC663F
*May 1 18:58:37.213: RTP(8264): fp tx d=217.218.20.86(14372), pt=8, ts=B84647BF, ssrc=23B61458
*May 1 18:58:37.225: RTP(414): fs rx d=217.218.20.86(14372), pt=8, ts=3EB141AC, ssrc=3BFC663F
*May 1 18:58:37.233: RTP(8265): fp tx d=217.218.20.86(14372), pt=8, ts=B846485F, ssrc=23B61458
*May 1 18:58:37.245: RTP(415): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1424C, ssrc=3BFC663F
*May 1 18:58:37.253: RTP(8266): fp tx d=217.218.20.86(14372), pt=8, ts=B84648FF, ssrc=23B61458
*May 1 18:58:37.265: RTP(416): fs rx d=217.218.20.86(14372), pt=8, ts=3EB142EC, ssrc=3BFC663F
*May 1 18:58:37.273: RTP(8267): fp tx d=217.218.20.86(14372), pt=8, ts=B846499F, ssrc=23B61458
*May 1 18:58:37.285: RTP(417): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1438C, ssrc=3BFC663F
*May 1 18:58:37.293: RTP(8268): fp tx d=217.218.20.86(14372), pt=8, ts=B8464A3F, ssrc=23B61458
*May 1 18:58:37.305: RTP(418): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1442C, ssrc=3BFC663F
*May 1 18:58:37.313: RTP(8269): fp tx d=217.218.20.86(14372), pt=8, ts=B8464ADF, ssrc=23B61458
*May 1 18:58:37.325: RTP(419): fs rx d=217.218.20.86(14372), pt=8, ts=3EB144CC, ssrc=3BFC663F
*May 1 18:58:37.333: RTP(8270): fp tx d=217.218.20.86(14372), pt=8, ts=B8464B7F, ssrc=23B61458
*May 1 18:58:37.345: RTP(420): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1456C, ssrc=3BFC663F
*May 1 18:58:37.353: RTP(8271): fp tx d=217.218.20.86(14372), pt=8, ts=B8464C1F, ssrc=23B61458
*May 1 18:58:37.365: RTP(421): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1460C, ssrc=3BFC663F
*May 1 18:58:37.373: RTP(8272): fp tx d=217.218.20.86(14372), pt=8, ts=B8464CBF, ssrc=23B61458
*May 1 18:58:37.385: RTP(422): fs rx d=217.218.20.86(14372), pt=8, ts=3EB146AC, ssrc=3BFC663F
*May 1 18:58:37.393: RTP(8273): fp tx d=217.218.20.86(14372), pt=8, ts=B8464D5F, ssrc=23B61458
*May 1 18:58:37.405: RTP(423): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1474C, ssrc=3BFC663F
*May 1 18:58:37.413: RTP(8274): fp tx d=217.218.20.86(14372), pt=8, ts=B8464DFF, ssrc=23B61458
*May 1 18:58:37.425: RTP(424): fs rx d=217.218.20.86(14372), pt=8, ts=3EB147EC, ssrc=3BFC663F
*May 1 18:58:37.433: RTP(8275): fp tx d=217.218.20.86(14372), pt=8, ts=B8464E9F, ssrc=23B61458
*May 1 18:58:37.445: RTP(425): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1488C, ssrc=3BFC663F
*May 1 18:58:37.453: RTP(8276): fp tx d=217.218.20.86(14372), pt=8, ts=B8464F3F, ssrc=23B61458
*May 1 18:58:37.465: RTP(426): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1492C, ssrc=3BFC663F
*May 1 18:58:37.473: RTP(8277): fp tx d=217.218.20.86(14372), pt=8, ts=B8464FDF, ssrc=23B61458
*May 1 18:58:37.485: RTP(427): fs rx d=217.218.20.86(14372), pt=8, ts=3EB149CC, ssrc=3BFC663F
*May 1 18:58:37.493: RTP(8278): fp tx d=217.218.20.86(14372), pt=8, ts=B846507F, ssrc=23B61458
*May 1 18:58:37.505: RTP(428): fs rx d=217.218.20.86(14372), pt=8, ts=3EB14A6C, ssrc=3BFC663F
*May 1 18:58:37.513: RTP(8279): fp tx d=217.218.20.86(14372), pt=8, ts=B846511F, ssrc=23B61458
*May 1 18:58:37.525: RTP(429): fs rx d=217.218.20.86(14372), pt=8, ts=3EB14B0C, ssrc=3BFC663F
*May 1 18:58:37.533: RTP(8280): fp tx d=217.218.20.86(14372), pt=8, ts=B84651BF, ssrc=23B61458
*May 1 18:58:37.545: RTP(430): fs rx d=217.218.20.86(14372), pt=8, ts=3EB14BAC, ssrc=3BFC663F
*May 1 18:58:37.553: RTP(8281): fp tx d=217.218.20.86(14372), pt=8, ts=B846525F, ssrc=23B61458
*May 1 18:58:37.565: RTP(431): fs rx d=217.218.20.86(14372), pt=8, ts=3EB14C4C, ssrc=3BFC663F
*May 1 18:58:37.573: RTP(8282): fp tx d=217.218.20.86(14372), pt=8, ts=B84652FF, ssrc=23B61458
*May 1 18:58:37.585: RTP(432): fs rx d=217.218.20.86(14372), pt=8, ts=3EB14CEC, ssrc=3BFC663F
*May 1 18:58:37.593: RTP(8283): fp tx d=217.218.20.86(14372), pt=8, ts=B846539F, ssrc=23B61458
*May 1 18:58:37.605: RTP(433): fs rx d=217.218.20.86(14372), pt=8, ts=3EB14D8C, ssrc=3BFC663F
*May 1 18:58:37.613: RTP(8284): fp tx d=217.218.20.86(14372), pt=8, ts=B846543F, ssrc=23B61458
*May 1 18:58:37.625: RTP(434): fs rx d=217.218.20.86(14372), pt=8, ts=3EB14E2C, ssrc=3BFC663F
*May 1 18:58:37.633: RTP(8285): fp tx d=217.218.20.86(14372), pt=8, ts=B84654DF, ssrc=23B61458
*May 1 18:58:37.645: RTP(435): fs rx d=217.218.20.86(14372), pt=8, ts=3EB14ECC, ssrc=3BFC663F
*May 1 18:58:37.653: RTP(8286): fp tx d=217.218.20.86(14372), pt=8, ts=B846557F, ssrc=23B61458
*May 1 18:58:37.665: RTP(436): fs rx d=217.218.20.86(14372), pt=8, ts=3EB14F6C, ssrc=3BFC663F
*May 1 18:58:37.673: RTP(8287): fp tx d=217.218.20.86(14372), pt=8, ts=B846561F, ssrc=23B61458
*May 1 18:58:37.685: RTP(437): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1500C, ssrc=3BFC663F
*May 1 18:58:37.693: RTP(8288): fp tx d=217.218.20.86(14372), pt=8, ts=B84656BF, ssrc=23B61458
*May 1 18:58:37.705: RTP(438): fs rx d=217.218.20.86(14372), pt=8, ts=3EB150AC, ssrc=3BFC663F
*May 1 18:58:37.717: RTP(8289): fp tx d=217.218.20.86(14372), pt=8, ts=B846575F, ssrc=23B61458
*May 1 18:58:37.725: RTP(439): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1514C, ssrc=3BFC663F
*May 1 18:58:37.737: RTP(8290): fp tx d=217.218.20.86(14372), pt=8, ts=B84657FF, ssrc=23B61458
*May 1 18:58:37.745: RTP(440): fs rx d=217.218.20.86(14372), pt=8, ts=3EB151EC, ssrc=3BFC663F
*May 1 18:58:37.757: RTP(8291): fp tx d=217.218.20.86(14372), pt=8, ts=B846589F, ssrc=23B61458
*May 1 18:58:37.765: RTP(441): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1528C, ssrc=3BFC663F
*May 1 18:58:37.777: RTP(8292): fp tx d=217.218.20.86(14372), pt=8, ts=B846593F, ssrc=23B61458
*May 1 18:58:37.785: RTP(442): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1532C, ssrc=3BFC663F
*May 1 18:58:37.797: RTP(8293): fp tx d=217.218.20.86(14372), pt=8, ts=B84659DF, ssrc=23B61458
*May 1 18:58:37.805: RTP(443): fs rx d=217.218.20.86(14372), pt=8, ts=3EB153CC, ssrc=3BFC663F
*May 1 18:58:37.817: RTP(8294): fp tx d=217.218.20.86(14372), pt=8, ts=B8465A7F, ssrc=23B61458
*May 1 18:58:37.825: RTP(444): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1546C, ssrc=3BFC663F
*May 1 18:58:37.837: RTP(8295): fp tx d=217.218.20.86(14372), pt=8, ts=B8465B1F, ssrc=23B61458
*May 1 18:58:37.845: RTP(445): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1550C, ssrc=3BFC663F
*May 1 18:58:37.857: RTP(8296): fp tx d=217.218.20.86(14372), pt=8, ts=B8465BBF, ssrc=23B61458
*May 1 18:58:37.865: RTP(446): fs rx d=217.218.20.86(14372), pt=8, ts=3EB155AC, ssrc=3BFC663F
*May 1 18:58:37.877: RTP(8297): fp tx d=217.218.20.86(14372), pt=8, ts=B8465C5F, ssrc=23B61458
*May 1 18:58:37.885: RTP(447): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1564C, ssrc=3BFC663F
*May 1 18:58:37.897: RTP(8298): fp tx d=217.218.20.86(14372), pt=8, ts=B8465CFF, ssrc=23B61458
*May 1 18:58:37.905: RTP(448): fs rx d=217.218.20.86(14372), pt=8, ts=3EB156EC, ssrc=3BFC663F
*May 1 18:58:37.917: RTP(8299): fp tx d=217.218.20.86(14372), pt=8, ts=B8465D9F, ssrc=23B61458
*May 1 18:58:37.925: RTP(449): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1578C, ssrc=3BFC663F
*May 1 18:58:37.937: RTP(8300): fp tx d=217.218.20.86(14372), pt=8, ts=B8465E3F, ssrc=23B61458
*May 1 18:58:37.945: RTP(450): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1582C, ssrc=3BFC663F
*May 1 18:58:37.957: RTP(8301): fp tx d=217.218.20.86(14372), pt=8, ts=B8465EDF, ssrc=23B61458
*May 1 18:58:37.965: RTP(451): fs rx d=217.218.20.86(14372), pt=8, ts=3EB158CC, ssrc=3BFC663F
*May 1 18:58:37.977: RTP(8302): fp tx d=217.218.20.86(14372), pt=8, ts=B8465F7F, ssrc=23B61458
*May 1 18:58:37.985: RTP(452): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1596C, ssrc=3BFC663F
*May 1 18:58:37.997: RTP(8303): fp tx d=217.218.20.86(14372), pt=8, ts=B846601F, ssrc=23B61458
*May 1 18:58:38.005: RTP(453): fs rx d=217.218.20.86(14372), pt=8, ts=3EB15A0C, ssrc=3BFC663F
*May 1 18:58:38.017: RTP(8304): fp tx d=217.218.20.86(14372), pt=8, ts=B84660BF, ssrc=23B61458
*May 1 18:58:38.025: RTP(454): fs rx d=217.218.20.86(14372), pt=8, ts=3EB15AAC, ssrc=3BFC663F
*May 1 18:58:38.037: RTP(8305): fp tx d=217.218.20.86(14372), pt=8, ts=B846615F, ssrc=23B61458
*May 1 18:58:38.045: RTP(455): fs rx d=217.218.20.86(14372), pt=8, ts=3EB15B4C, ssrc=3BFC663F
*May 1 18:58:38.057: RTP(8306): fp tx d=217.218.20.86(14372), pt=8, ts=B84661FF, ssrc=23B61458
*May 1 18:58:38.065: RTP(456): fs rx d=217.218.20.86(14372), pt=8, ts=3EB15BEC, ssrc=3BFC663F
*May 1 18:58:38.077: RTP(8307): fp tx d=217.218.20.86(14372), pt=8, ts=B846629F, ssrc=23B61458
*May 1 18:58:38.085: RTP(457): fs rx d=217.218.20.86(14372), pt=8, ts=3EB15C8C, ssrc=3BFC663F
*May 1 18:58:38.097: RTP(8308): fp tx d=217.218.20.86(14372), pt=8, ts=B846633F, ssrc=23B61458
*May 1 18:58:38.105: RTP(458): fs rx d=217.218.20.86(14372), pt=8, ts=3EB15D2C, ssrc=3BFC663F
*May 1 18:58:38.117: RTP(8309): fp tx d=217.218.20.86(14372), pt=8, ts=B84663DF, ssrc=23B61458
*May 1 18:58:38.125: RTP(459): fs rx d=217.218.20.86(14372), pt=8, ts=3EB15DCC, ssrc=3BFC663F
*May 1 18:58:38.137: RTP(8310): fp tx d=217.218.20.86(14372), pt=8, ts=B846647F, ssrc=23B61458
*May 1 18:58:38.145: RTP(460): fs rx d=217.218.20.86(14372), pt=8, ts=3EB15E6C, ssrc=3BFC663F
*May 1 18:58:38.157: RTP(8311): fp tx d=217.218.20.86(14372), pt=8, ts=B846651F, ssrc=23B61458
*May 1 18:58:38.165: RTP(461): fs rx d=217.218.20.86(14372), pt=8, ts=3EB15F0C, ssrc=3BFC663F
*May 1 18:58:38.177: RTP(8312): fp tx d=217.218.20.86(14372), pt=8, ts=B84665BF, ssrc=23B61458
*May 1 18:58:38.185: RTP(462): fs rx d=217.218.20.86(14372), pt=8, ts=3EB15FAC, ssrc=3BFC663F
*May 1 18:58:38.197: RTP(8313): fp tx d=217.218.20.86(14372), pt=8, ts=B846665F, ssrc=23B61458
*May 1 18:58:38.205: RTP(463): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1604C, ssrc=3BFC663F
*May 1 18:58:38.217: RTP(8314): fp tx d=217.218.20.86(14372), pt=8, ts=B84666FF, ssrc=23B61458
*May 1 18:58:38.225: RTP(464): fs rx d=217.218.20.86(14372), pt=8, ts=3EB160EC, ssrc=3BFC663F
*May 1 18:58:38.237: RTP(8315): fp tx d=217.218.20.86(14372), pt=8, ts=B846679F, ssrc=23B61458
*May 1 18:58:38.245: RTP(465): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1618C, ssrc=3BFC663F
*May 1 18:58:38.257: RTP(8316): fp tx d=217.218.20.86(14372), pt=8, ts=B846683F, ssrc=23B61458
*May 1 18:58:38.265: RTP(466): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1622C, ssrc=3BFC663F
*May 1 18:58:38.277: RTP(8317): fp tx d=217.218.20.86(14372), pt=8, ts=B84668DF, ssrc=23B61458
*May 1 18:58:38.285: RTP(467): fs rx d=217.218.20.86(14372), pt=8, ts=3EB162CC, ssrc=3BFC663F
*May 1 18:58:38.297: RTP(8318): fp tx d=217.218.20.86(14372), pt=8, ts=B846697F, ssrc=23B61458
*May 1 18:58:38.305: RTP(468): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1636C, ssrc=3BFC663F
*May 1 18:58:38.317: RTP(8319): fp tx d=217.218.20.86(14372), pt=8, ts=B8466A1F, ssrc=23B61458
*May 1 18:58:38.325: RTP(469): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1640C, ssrc=3BFC663F
*May 1 18:58:38.337: RTP(8320): fp tx d=217.218.20.86(14372), pt=8, ts=B8466ABF, ssrc=23B61458
*May 1 18:58:38.345: RTP(470): fs rx d=217.218.20.86(14372), pt=8, ts=3EB164AC, ssrc=3BFC663F
*May 1 18:58:38.357: RTP(8321): fp tx d=217.218.20.86(14372), pt=8, ts=B8466B5F, ssrc=23B61458
*May 1 18:58:38.365: RTP(471): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1654C, ssrc=3BFC663F
*May 1 18:58:38.377: RTP(8322): fp tx d=217.218.20.86(14372), pt=8, ts=B8466BFF, ssrc=23B61458
*May 1 18:58:38.385: RTP(472): fs rx d=217.218.20.86(14372), pt=8, ts=3EB165EC, ssrc=3BFC663F
*May 1 18:58:38.397: RTP(8323): fp tx d=217.218.20.86(14372), pt=8, ts=B8466C9F, ssrc=23B61458
*May 1 18:58:38.405: RTP(473): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1668C, ssrc=3BFC663F
*May 1 18:58:38.417: RTP(8324): fp tx d=217.218.20.86(14372), pt=8, ts=B8466D3F, ssrc=23B61458
*May 1 18:58:38.425: RTP(474): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1672C, ssrc=3BFC663F
*May 1 18:58:38.437: RTP(8325): fp tx d=217.218.20.86(14372), pt=8, ts=B8466DDF, ssrc=23B61458
*May 1 18:58:38.445: RTP(475): fs rx d=217.218.20.86(14372), pt=8, ts=3EB167CC, ssrc=3BFC663F
*May 1 18:58:38.457: RTP(8326): fp tx d=217.218.20.86(14372), pt=8, ts=B8466E7F, ssrc=23B61458
*May 1 18:58:38.465: RTP(476): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1686C, ssrc=3BFC663F
*May 1 18:58:38.477: RTP(8327): fp tx d=217.218.20.86(14372), pt=8, ts=B8466F1F, ssrc=23B61458
*May 1 18:58:38.485: RTP(477): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1690C, ssrc=3BFC663F
*May 1 18:58:38.497: RTP(8328): fp tx d=217.218.20.86(14372), pt=8, ts=B8466FBF, ssrc=23B61458
*May 1 18:58:38.505: RTP(478): fs rx d=217.218.20.86(14372), pt=8, ts=3EB169AC, ssrc=3BFC663F
*May 1 18:58:38.517: RTP(8329): fp tx d=217.218.20.86(14372), pt=8, ts=B846705F, ssrc=23B61458
*May 1 18:58:38.525: RTP(479): fs rx d=217.218.20.86(14372), pt=8, ts=3EB16A4C, ssrc=3BFC663F
*May 1 18:58:38.537: RTP(8330): fp tx d=217.218.20.86(14372), pt=8, ts=B84670FF, ssrc=23B61458
*May 1 18:58:38.545: RTP(480): fs rx d=217.218.20.86(14372), pt=8, ts=3EB16AEC, ssrc=3BFC663F
*May 1 18:58:38.557: RTP(8331): fp tx d=217.218.20.86(14372), pt=8, ts=B846719F, ssrc=23B61458
*May 1 18:58:38.565: RTP(481): fs rx d=217.218.20.86(14372), pt=8, ts=3EB16B8C, ssrc=3BFC663F
*May 1 18:58:38.577: RTP(8332): fp tx d=217.218.20.86(14372), pt=8, ts=B846723F, ssrc=23B61458
*May 1 18:58:38.585: RTP(482): fs rx d=217.218.20.86(14372), pt=8, ts=3EB16C2C, ssrc=3BFC663F
*May 1 18:58:38.597: RTP(8333): fp tx d=217.218.20.86(14372), pt=8, ts=B84672DF, ssrc=23B61458
*May 1 18:58:38.605: RTP(483): fs rx d=217.218.20.86(14372), pt=8, ts=3EB16CCC, ssrc=3BFC663F
*May 1 18:58:38.617: RTP(8334): fp tx d=217.218.20.86(14372), pt=8, ts=B846737F, ssrc=23B61458
*May 1 18:58:38.625: RTP(484): fs rx d=217.218.20.86(14372), pt=8, ts=3EB16D6C, ssrc=3BFC663F
*May 1 18:58:38.637: RTP(8335): fp tx d=217.218.20.86(14372), pt=8, ts=B846741F, ssrc=23B61458
*May 1 18:58:38.645: RTP(485): fs rx d=217.218.20.86(14372), pt=8, ts=3EB16E0C, ssrc=3BFC663F
*May 1 18:58:38.657: RTP(8336): fp tx d=217.218.20.86(14372), pt=8, ts=B84674BF, ssrc=23B61458
*May 1 18:58:38.665: RTP(486): fs rx d=217.218.20.86(14372), pt=8, ts=3EB16EAC, ssrc=3BFC663F
*May 1 18:58:38.677: RTP(8337): fp tx d=217.218.20.86(14372), pt=8, ts=B846755F, ssrc=23B61458
*May 1 18:58:38.685: RTP(487): fs rx d=217.218.20.86(14372), pt=8, ts=3EB16F4C, ssrc=3BFC663F
*May 1 18:58:38.697: RTP(8338): fp tx d=217.218.20.86(14372), pt=8, ts=B84675FF, ssrc=23B61458
*May 1 18:58:38.705: RTP(488): fs rx d=217.218.20.86(14372), pt=8, ts=3EB16FEC, ssrc=3BFC663F
*May 1 18:58:38.717: RTP(8339): fp tx d=217.218.20.86(14372), pt=8, ts=B846769F, ssrc=23B61458
*May 1 18:58:38.725: RTP(489): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1708C, ssrc=3BFC663F
*May 1 18:58:38.737: RTP(8340): fp tx d=217.218.20.86(14372), pt=8, ts=B846773F, ssrc=23B61458
*May 1 18:58:38.745: RTP(490): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1712C, ssrc=3BFC663F
*May 1 18:58:38.757: RTP(8341): fp tx d=217.218.20.86(14372), pt=8, ts=B84677DF, ssrc=23B61458
*May 1 18:58:38.765: RTP(491): fs rx d=217.218.20.86(14372), pt=8, ts=3EB171CC, ssrc=3BFC663F
*May 1 18:58:38.777: RTP(8342): fp tx d=217.218.20.86(14372), pt=8, ts=B846787F, ssrc=23B61458
*May 1 18:58:38.785: RTP(492): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1726C, ssrc=3BFC663F
*May 1 18:58:38.797: RTP(8343): fp tx d=217.218.20.86(14372), pt=8, ts=B846791F, ssrc=23B61458
*May 1 18:58:38.805: RTP(493): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1730C, ssrc=3BFC663F
*May 1 18:58:38.817: RTP(8344): fp tx d=217.218.20.86(14372), pt=8, ts=B84679BF, ssrc=23B61458
*May 1 18:58:38.825: RTP(494): fs rx d=217.218.20.86(14372), pt=8, ts=3EB173AC, ssrc=3BFC663F
*May 1 18:58:38.837: RTP(8345): fp tx d=217.218.20.86(14372), pt=8, ts=B8467A5F, ssrc=23B61458
*May 1 18:58:38.845: RTP(495): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1744C, ssrc=3BFC663F
*May 1 18:58:38.857: RTP(8346): fp tx d=217.218.20.86(14372), pt=8, ts=B8467AFF, ssrc=23B61458
*May 1 18:58:38.865: RTP(496): fs rx d=217.218.20.86(14372), pt=8, ts=3EB174EC, ssrc=3BFC663F
*May 1 18:58:38.877: RTP(8347): fp tx d=217.218.20.86(14372), pt=8, ts=B8467B9F, ssrc=23B61458
*May 1 18:58:38.885: RTP(497): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1758C, ssrc=3BFC663F
*May 1 18:58:38.897: RTP(8348): fp tx d=217.218.20.86(14372), pt=8, ts=B8467C3F, ssrc=23B61458
*May 1 18:58:38.905: RTP(498): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1762C, ssrc=3BFC663F
*May 1 18:58:38.917: RTP(8349): fp tx d=217.218.20.86(14372), pt=8, ts=B8467CDF, ssrc=23B61458
*May 1 18:58:38.925: RTP(499): fs rx d=217.218.20.86(14372), pt=8, ts=3EB176CC, ssrc=3BFC663F
*May 1 18:58:38.937: RTP(8350): fp tx d=217.218.20.86(14372), pt=8, ts=B8467D7F, ssrc=23B61458
*May 1 18:58:38.945: RTP(500): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1776C, ssrc=3BFC663F
*May 1 18:58:38.957: RTP(8351): fp tx d=217.218.20.86(14372), pt=8, ts=B8467E1F, ssrc=23B61458
*May 1 18:58:38.965: RTP(501): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1780C, ssrc=3BFC663F
*May 1 18:58:38.977: RTP(8352): fp tx d=217.218.20.86(14372), pt=8, ts=B8467EBF, ssrc=23B61458
*May 1 18:58:38.985: RTP(502): fs rx d=217.218.20.86(14372), pt=8, ts=3EB178AC, ssrc=3BFC663F
*May 1 18:58:38.997: RTP(8353): fp tx d=217.218.20.86(14372), pt=8, ts=B8467F5F, ssrc=23B61458
*May 1 18:58:39.005: RTP(503): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1794C, ssrc=3BFC663F
*May 1 18:58:39.017: RTP(8354): fp tx d=217.218.20.86(14372), pt=8, ts=B8467FFF, ssrc=23B61458
*May 1 18:58:39.025: RTP(504): fs rx d=217.218.20.86(14372), pt=8, ts=3EB179EC, ssrc=3BFC663F
*May 1 18:58:39.037: RTP(8355): fp tx d=217.218.20.86(14372), pt=8, ts=B846809F, ssrc=23B61458
*May 1 18:58:39.045: RTP(505): fs rx d=217.218.20.86(14372), pt=8, ts=3EB17A8C, ssrc=3BFC663F
*May 1 18:58:39.057: RTP(8356): fp tx d=217.218.20.86(14372), pt=8, ts=B846813F, ssrc=23B61458
*May 1 18:58:39.065: RTP(506): fs rx d=217.218.20.86(14372), pt=8, ts=3EB17B2C, ssrc=3BFC663F
*May 1 18:58:39.077: RTP(8357): fp tx d=217.218.20.86(14372), pt=8, ts=B84681DF, ssrc=23B61458
*May 1 18:58:39.085: RTP(507): fs rx d=217.218.20.86(14372), pt=8, ts=3EB17BCC, ssrc=3BFC663F
*May 1 18:58:39.097: RTP(8358): fp tx d=217.218.20.86(14372), pt=8, ts=B846827F, ssrc=23B61458
*May 1 18:58:39.105: RTP(508): fs rx d=217.218.20.86(14372), pt=8, ts=3EB17C6C, ssrc=3BFC663F
*May 1 18:58:39.117: RTP(8359): fp tx d=217.218.20.86(14372), pt=8, ts=B846831F, ssrc=23B61458
*May 1 18:58:39.125: RTP(509): fs rx d=217.218.20.86(14372), pt=8, ts=3EB17D0C, ssrc=3BFC663F
*May 1 18:58:39.137: RTP(8360): fp tx d=217.218.20.86(14372), pt=8, ts=B84683BF, ssrc=23B61458
*May 1 18:58:39.145: RTP(510): fs rx d=217.218.20.86(14372), pt=8, ts=3EB17DAC, ssrc=3BFC663F
*May 1 18:58:39.157: RTP(8361): fp tx d=217.218.20.86(14372), pt=8, ts=B846845F, ssrc=23B61458
*May 1 18:58:39.165: RTP(511): fs rx d=217.218.20.86(14372), pt=8, ts=3EB17E4C, ssrc=3BFC663F
*May 1 18:58:39.177: RTP(8362): fp tx d=217.218.20.86(14372), pt=8, ts=B84684FF, ssrc=23B61458
*May 1 18:58:39.185: RTP(512): fs rx d=217.218.20.86(14372), pt=8, ts=3EB17EEC, ssrc=3BFC663F
*May 1 18:58:39.197: RTP(8363): fp tx d=217.218.20.86(14372), pt=8, ts=B846859F, ssrc=23B61458
*May 1 18:58:39.205: RTP(513): fs rx d=217.218.20.86(14372), pt=8, ts=3EB17F8C, ssrc=3BFC663F
*May 1 18:58:39.217: RTP(8364): fp tx d=217.218.20.86(14372), pt=8, ts=B846863F, ssrc=23B61458
*May 1 18:58:39.225: RTP(514): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1802C, ssrc=3BFC663F
*May 1 18:58:39.237: RTP(8365): fp tx d=217.218.20.86(14372), pt=8, ts=B84686DF, ssrc=23B61458
*May 1 18:58:39.245: RTP(515): fs rx d=217.218.20.86(14372), pt=8, ts=3EB180CC, ssrc=3BFC663F
*May 1 18:58:39.257: RTP(8366): fp tx d=217.218.20.86(14372), pt=8, ts=B846877F, ssrc=23B61458
*May 1 18:58:39.265: RTP(516): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1816C, ssrc=3BFC663F
*May 1 18:58:39.277: RTP(8367): fp tx d=217.218.20.86(14372), pt=8, ts=B846881F, ssrc=23B61458
*May 1 18:58:39.285: RTP(517): fs rx d=217.218.20.86(14372), pt=8, ts=3EB1820C, ssrc=3BFC663F
*May 1 18:58:39.297: RTP(8368): fp tx d=217.218.20.86(14372), pt=8, ts=B84688BF, ssrc=23B61458
*May 1 18:58:39.305: RTP(518): fs rx d=217.218.20.86(14372), pt=8, ts=3EB182AC, ssrc=3BFC663F
04-23-2014 10:44 AM
Try to remove service session from dial-peer 12 and 13.
Regards.
04-23-2014 10:07 PM
it doesn't make any difference for fax , i didn't hear any cng or ced , doesn't it because of modem?
*May 2 19:49:52.187: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:82131000@217.218.20.86:5060 SIP/2.0
Via: SIP/2.0/UDP 217.218.20.88:5060;x-ds0num="ISDN 3/0:D 3/0:DS1 1:DS0";branch=z9hG4bK51791CAA
From: <sip:2188827748@217.218.20.86>;tag=14F04E8C-1730
To: <sip:82131000@217.218.20.86>
Date: Fri, 02 May 2003 19:49:52 GMT
Call-ID: 130F5691-7C0E11D7-84E3EB32-2F8E14EF@217.218.20.88
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 1800
Cisco-Guid: 317972471-2081296855-2224226338-3185268956
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1051904992
Contact: <sip:2188827748@217.218.20.88:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 299
v=0
o=CiscoSystemsSIP-GW-UserAgent 9680 6923 IN IP4 217.218.20.88
s=SIP Call
c=IN IP4 217.218.20.88
t=0 0
m=audio 22490 RTP/AVP 8 100 101
a=rtpmap:8 PCMA/8000
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
*May 2 19:49:52.191: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying -- your call is important to us
Via: SIP/2.0/UDP 217.218.20.88:5060;branch=z9hG4bK51791CAA;rport=5060
CSeq: 101 INVITE
Server: SIP Proxy Server
Content-Length: 0
*May 2 19:49:52.243: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:82131000@217.218.20.86>;tag=1793519092
Min-SE: 1800
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 0
Record-Route: <sip:82131000@217.218.20.86;ftag=14F04E8C-1730;lr=on>
*May 2 19:49:52.247: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Contact: <sip:217.218.20.86:5060>
CSeq: 101 INVITE
Server: CallCenter
User-Agent: CallCenter
Content-Length: 209
v=0
o=- 3517046709 3517046709 IN IP4 217.218.20.86
s=Pendar Pajouh
c=IN IP4 217.218.20.86
t=0 0
a=direction:active
m=audio 18911 RTP/AVP 8 101
Sent:
ACK sip:217.218.20.86:5060 SIP/2.0
Via: SIP/2.0/UDP 217.218.20.88:5060;x-ds0num="ISDN 3/0:D 3/0:DS1 1:DS0";branch=z9hG4bK517A9FC
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*May 2 19:49:58.827: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:217.218.20.86:5060 SIP/2.0
Via: SIP/2.0/UDP 217.218.20.88:5060;x-ds0num="ISDN 3/0:D 3/0:DS1 1:DS0";branch=z9hG4bK517B199E
Date: Fri, 02 May 2003 19:49:58 GMT
Min-SE: 1800
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1051904998
Expires: 180
Content-Length: 399
v=0
o=CiscoSystemsSIP-GW-UserAgent 9680 6924 IN IP4 217.218.20.88
s=SIP Call
t=0 0
m=image 22490 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:14400
a=T38FaxFillBitRemoval:0
a=T38FaxTranscodingMMR:0
a=T38FaxTranscodingJBIG:0
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:72
a=T38FaxUdpEC:t38UDPRedundancy
*May 2 19:49:58.831: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 217.218.20.88:5060;branch=z9hG4bK517B199E;rport=5060
CSeq: 102 INVITE
Server: CallCenter
Content-Length: 247
v=0
o=- 4858949 4858949 IN IP4 217.218.20.86
s=Pendar Pajouh
m=image 18911 udptl t38
a=T38FaxVersion:0
Sent:
Via: SIP/2.0/UDP 217.218.20.88:5060;x-ds0num="ISDN 3/0:D 3/0:DS1 1:DS0";branch=z9hG4bK517C1628
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
04-24-2014 08:46 AM
Add the command "voice rtp send-recv" in global config.
Do you have DSP in board?
Add the "show spe" output.
BR
04-26-2014 09:55 PM
Dear Daniele,
I have configured voice rtp send-recv
--------------------------------- <<show diag >> ------------------------------------------------
Slot 0:
AS5350XM Motherboard
Manufacture Cookie Info:
Board ID : 0x4C3
Hardware Revision : 2.7
Top Assy. Part Number : 800-25671-03
Part Number : 73-9526-06
Board Revision : B0
Fab Part Number : 28-6926-03
Platform features : 30 30 30 30 30 30 30 30
Processor type : AA
Product (FRU) Number : AS535XM-AC-PWR
PCB Serial Number : JAE14520L8S
Chassis MAC Address : 0022.bddb.58dc
MAC Address block size : 2
CLEI Code : IPMG700ARB
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Version Identifier : V03
Chassis Serial Number :
EEPROM contents (hex):
0x00: 04 FF 40 04 C3 41 02 07 C0 46 03 20 00 64 47 03
0x10: 82 49 25 36 06 42 42 30 85 1C 1B 0E 03 C9 88 30
0x20: 30 30 30 30 30 30 30 09 AA CB 8E 41 53 35 33 35
0x30: 58 4D 2D 41 43 2D 50 57 52 C1 8B 4A 41 45 31 34
0x40: 35 32 30 4C 38 53 C3 06 00 22 BD DB 58 DC 43 00
0x50: 02 C6 8A 49 50 4D 47 37 30 30 41 52 42 03 00 81
0x60: 00 00 00 00 04 00 89 56 30 33 00 C2 8B FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF F8 5D
FRU NUMBER : AS5350XM
Slot 1:
DFC type is AS5350XM AS5X-FC
OIR events:
Number of insertions = 0, Number of removals = 0
DFC State is DFC_S_OPERATIONAL
Error events (Bus errors, PCI errors):
Number of errors recovered = 0
DFC Cookie Info:
Board ID : 0x4CF
Hardware Revision : 1.0
Top Assy. Part Number : 800-26758-01
Part Number : 73-9980-02
Board Revision : A0
Fab Part Number : 28-7322-02
Product (FRU) Number : AS5X-FC
PCB Serial Number : JAE14500HKN
CLEI Code : IPUCAFKBAA
RMA History : 00
Version Identifier : V01
0x00: 04 FF 40 04 CF 41 01 00 C0 46 03 20 00 68 86 01
0x10: 82 49 26 FC 02 42 41 30 85 1C 1C 9A 02 CB 87 41
0x20: 53 35 58 2D 46 43 C1 8B 4A 41 45 31 34 35 30 30
0x30: 48 4B 4E C6 8A 49 50 55 43 41 46 4B 42 41 41 D9
0x40: 02 40 C1 03 00 81 00 00 00 00 04 00 89 56 30 31
0x50: 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FRU NUMBER : AS5X-FC=
PVDM Slot 0:
64-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8541-05
Board Revision : C0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC14511FV2
RMA History : 00
Processor type : 00
Product (FRU) Number : AS5X-PVDM2-64
EEPROM format version 4
0x00: 04 FF 40 03 EC 41 04 00 82 49 21 5D 05 42 43 30
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 34 35 31
0x20: 31 46 56 32 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 8D 41 53 35 58 2D 50 56 44 4D 32 2D 36 34 89 56
0x40: 30 31 00 D9 02 40 C1 FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
PVDM Slot 1:
Board Revision : C0
Fab Version : 04
PCB Serial Number : FOC14511F5C
RMA History : 00
Processor type : 00
0x20: 31 46 35 43 03 00 81 00 00 00 00 04 00 09 00 CB
PVDM Slot 2:
Board Revision : C0
Fab Version : 04
PCB Serial Number : FOC13233AEG
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-64
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 33 32 33
0x20: 33 41 45 47 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 88 50 56 44 4D 32 2D 36 34 89 56 30 31 20 D9 02
0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Carrier Card Master PLD/FPGA Rev 0x0007
AS5X-FC FPGA Rev 0x0008
Slot 2:
DFC type is AS5350XM Empty DFC
DFC is not powered
OIR events:
Carrier Card Cookie Info:
Board ID : 0x4BE
Hardware Revision : 1.4
Part Number : 73-9527-03
Board Revision : A0
Fab Part Number : 28-6928-03
PCB Serial Number : JAE14520KXS
RMA History : 00
0x00: 04 FF 40 04 BE 41 01 04 82 49 25 37 03 42 41 30
0x10: 85 1C 1B 10 03 CB 92 00 00 00 00 00 00 00 00 00
0x20: 00 00 00 00 00 00 00 00 00 C1 8B 4A 41 45 31 34
0x30: 35 32 30 4B 58 53 03 00 81 00 00 00 00 04 00 89
0x40: 56 30 33 20 FF FF FF FF FF FF FF FF FF FF FF FF
Slot 3:
DFC type is AS5350XM E1 2 PRI DFC
OIR events:
Board ID : 0x4BE
Board Revision : A0
RMA History : 00
DFC Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x0A,
Board Hardware Version 2.7, Item Number 73-5268-03,
Board Revision A1, Serial Number JAE14470DDD,
PLD/ISP Version 3.0, Manufacture Date 19-Nov-2010.
RMA Number1 <unset>, RMA Number2 <unset>
EEPROM format version 0x1
0x00: 00 01 01 0A 02 07 00 49 00 14 94 03 41 01 4A 41
0x10: 45 31 34 34 37 30 44 44 44 00 00 00 00 00 14 0A
0x20: 0B 13 03 00 FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FRU NUMBER : AS54-DFC-2CE1=
Trunk DFC Info:
PLD Version 0x9, PLX9054 Revision 0xC,
Boot ROM Version 0x2.
----------------------------------------show spe-------------------------------------
doesn't have any message
04-27-2014 04:41 AM
In your AS are installed PVDM DSP. I've always use old NextPort DSP.
I ask you a last test.
Can you disable T.38 and make a call?
Is there bidirectional audio?
What is the IOS version used?
Can you upgrade IOS?
Can you make a wireshark trace of a call session?
Regards.
04-27-2014 11:40 PM
when I disable T.38 and make a call , the call has been received but when the send button of the fax machine is pressed the sip sdp doesn't show the fax parameteres .
yes the audio is bidirectional .
The IOS version which we use is 12.4
does it need to upgrade ?
---------------------------------------------Wireshark Trace----------------------------
all I have received in wireshark is malformed packet . you can see it in the attachment .
04-30-2014 12:20 PM
What is the exact version of IOS?
Can you add the wireshark trace?
BR
04-30-2014 10:41 PM
the Version of IOS is: 12.4(9)T7
the wireshark trace is added in the previous post as a jpg attachment
