Hi all.
I have a situation with volume calls.
1.- When the calls are originated in the PSTN to the IP Phones, the volume is ok in both sites.
2.- When the calls is originated in the IP Phones to the PSTN, the person in the PSTN listens very low.
I try to adjust the volume in the voice-port configuration, increasing the input and output db value, but not if I am doing it well or if I need adjust the configuration in other part.
The router 2801 have a CCME ver 4, this router is connected to PBX with a E1 and the PBX have the PSTN Digital trunks.
this is the voice router configuration:
voice-card 0
dsp services dspfarm
voice service voip
supplementary-service h450.12
controller E1 0/0/0
framing NO-CRC4
line-termination 75-ohm
ds0-group 0 timeslots 1-12 type e&m-immediate-start dtmf dnis
description to the PBX
voice-port 0/0/0:0
auto-cut-through
input gain 4
output attenuation 4
playout-delay nominal 200
playout-delay minimum low
bearer-cap Speech
