Community Member
PSTN based Simulator with Cisco CUCM 8.5 (MGCP)
Hi All,
I would like to know is it possible to create a PSTN simulator for CUCM 8.5. We want to test our calls in the lab enviornment rather than using the real T1/ISDN/PRI's if possible such as testing them with non-DID's rather than DID's. Our plan is to use the MGCP. We have the gateways and T1/ISDN/PRI in case you want us to use it. I have no idea at this time how to start. CUCM's are already up and running in a simulation enviornment.
Please also suggest if there is a better option then MGCP.
Zafar
814
