QoS for coloured VoIP packets doesn't work properly
Hello everyone,
I have come across a strange problem with QoS (Class of service for VoIP packets).
Please see below all the facts:
-I have a 2M leased line (1920 Kbps)
-I have given quality to VoIP traffic with set precedence 5.
-There are matched packets to class-map PREMIUM as expected however I get a drop rate 3000 bps while IP traffic doesn't exceed on a 5 min rate 73000 bps. (Traffic should be able to scale fine up to 30% of the available BW --which is much higher than 72000 bps--).
-To make things a bit more complicated we tried exactly the same QoS on another router (same platform, same IOS) with no probs.
-There are no errors on the line, the line has no CRC nor input/output errors.
-Configuration wise there is no problem, is it some kind of an IOS bug?
Has anyone come across a similar issue; are there any ideas what might cause this QoS misbehaviour?
Could it be a hardware fault (buffers etc.)
Thanks a lot in advance.
sh policy-map int s0/0 output class PREMIUM
Serial0/0
Service-policy output: QOS-CPE-OUT
Class-map: PREMIUM (match-any)
43392 packets, 24193568 bytes
5 minute offered rate 73000 bps, drop rate 3000 bps
Match: access-group 170
20782 packets, 11659128 bytes
5 minute rate 72000 bps
Match: ip precedence 5
22610 packets, 12534440 bytes
5 minute rate 1000 bps
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 30 (%)
Bandwidth 576 (kbps) Burst 14400 (Bytes)
(pkts matched/bytes matched) 43392/24193568
(total drops/bytes drops) 91/135264
QoS Set
precedence 5
Packets marked 43392
QOS configuration:
class-map match-any GOLD
match access-group 171
match ip precedence 3
class-map match-any PREMIUM
match access-group 170
match ip precedence 5
policy-map QOS-CPE-OUT
class PREMIUM
priority percent 30
set ip precedence 5
class GOLD
bandwidth percent 30
set ip precedence 3
ping 10.167.2.153 source 10.167.32.122 rep 100 size 1500
Sending 1000, 1500-byte ICMP Echos to 10.167.2.153, timeout is 2 seconds:
Packet sent with a source address of 10.167.32.122
Success rate is 98 percent (988/1000), round-trip min/avg/max = 16/17/216 ms
1 ACCEPTED SOLUTION
Re: QoS for coloured VoIP packets doesn't work properly
in your first post you gave a picture of 100 pings with 1500 Bytes each and seeing some drops.
Now with 17 ms average roundtrip time and 1500 Byte I get around 700 kbps throughput, which is clearly above the 576 kbps configured for the voip class.
I would be surprised, if there would be NO drops in case the interface is overloaded.
I think you are somewhat tricked by your 5 MINUTES average load collection time. Sending f.e. at full line speed for 10 seconds and being idle for 4 minutes and 50 seconds would average to less than 4% usage. The policer however works normally in a 125 ms time window and would start to drop if you are above rate for even a second.
As it looks to me: get things more accurate by reducing load average to 30 seconds and get a decent traffic generator with adjustable output for reliable measurements.
Hope this helps
Martin
hi
I dont think it can be a ios bug coz the same ios u r running in 2 different devices.
I would suggest to post out the ACLs both 170 and 171 which you are using here to match the traffic.
Is ACL 170 representing ur VOIP traffic ??
regds
Hi there, thanks for your reply,
Yes, basically my ACL 170 matches my source IP (which is basically a loopback address) in order to set precedence to 5 and represends my VoIP traffic.
ACL 170:
access-list 170 deny udp host 10.167.32.122 any eq 5060
access-list 170 permit ip host 10.167.32.122 any
ACL 171 matches for class GOLD.
ACL 171:
access-list 171 permit udp host 10.167.32.122 any eq 5060
access-list 171 permit ip host 80.106.200.122 172.30.94.0 0.0.1.255
I can see matched packets but the I see drop rate even when my traffic is low.
I appreciate your help
rgds
Anthony
You have mentioned the following statement under both the ACLs 170 and 171.
ACL 170 is going to be ur premium so i would better prefer having a singel ACL entry instead of 2 .
Plz try to remove from 171 for which ur doing a gurantee of b/w instead 170 where ur giving priority for the matching traffic.
regds
Thanks for your advice,
I have removed second entries from both ACLs with unfortunatelly the same results (some packet-loss).
Serial0/0
109485 packets, 41820900 bytes
5 minute offered rate 250000 bps, drop rate 0 bps
100699 packets, 36949580 bytes
5 minute rate 249000 bps
8786 packets, 4871320 bytes
5 minute rate 2000 bps
Queueing
Strict Priority
Bandwidth 30 (%)
Bandwidth 614 (kbps) Burst 15350 (Bytes)
(pkts matched/bytes matched) 30529/36768810
(total drops/bytes drops) 408/612212
QoS Set
precedence 5
Packets marked 97468
Success rate is 99 percent (2975/3000), round-trip min/avg/max = 16/17/216 ms
I 've got no logical explanation for it, line is way below saturation and pretty clear of errors, could it be some sort of a hardware problem (hardware buffers or something like that)?
Can you try something inline with the below mentioned config ??
Also can u increase the ping nos starting from 1000,2000 and go on and check for the drops..
ACL 170:
access-list 170 permit icmp host 10.167.32.122 any echo
access-list 170 permit icmp host 10.167.32.122 any echo-reply
ACL 171:
regds
Hi, after applying ACLs 170 amd 171 as above and trying with ICMP packets at 1000 bytes and 2000 bytes I get the following:
a) ACL 170 has got matches as expected:
sh ip access-lists 170
Extended IP access list 170
10 deny udp host 10.167.32.122 any eq 5060
20 permit icmp host 10.167.32.122 any echo (9100 matches)
30 permit icmp host 10.167.32.122 any echo-reply
b) For 1000 bytes packet size:
ping 10.167.2.153 source 10.167.32.122 rep 2000 size 1000
----!!!! omitted----
Success rate is 100 percent (2000/2000), round-trip min/avg/max = 12/12/212 ms
Serial0/0
140889 packets, 62456740 bytes
5 minute offered rate 117000 bps, drop rate 0 bps
5060 packets, 5150240 bytes
5 minute rate 116000 bps
34200 packets, 18958200 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Bandwidth 30 (%)
(pkts matched/bytes matched) 61933/57404650
QoS Set
precedence 5
Packets marked 128872
c)ping 10.167.2.153 source 10.167.32.122 rep 2000 size 2000
Success rate is 98 percent (1962/2000), round-trip min/avg/max = 20/23/224 ms
Serial0/0
144984 packets, 66586736 bytes
5 minute offered rate 182000 bps, drop rate 0 bps
9100 packets, 9246400 bytes
5 minute rate 180000 bps
34255 packets, 18992036 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Bandwidth 30 (%)
(pkts matched/bytes matched) 66028/61534646
QoS Set
precedence 5
Packets marked 132967
Sorry for the wrong outputs, I include them in order to give a better picture; seems to me that packet loss appears once packet size becomes large, ie. no drops when packet size is 1000 bytes but then we get packet drops when packet size is 2000 bytes...
I am sure that VoIP packets would be OK since are small in size however in theory should be no problem assembling/re-assembling bigger than MTU size packets and that seems to be an issue.
what do you think?
Thanks for your help
Anthony
CORRECTION:
SORRY, I meant LONG OUTPUTS not WRONG OUTPUTS.
Thnx
Anthony
In my prev mail i did mention about the ping counts not the byte size and as per the o/p pasted it sounds good w/o any drops with 1000byte size even.
I dont think any buffer error or some h/w error with the box..
regds
Hope this helps
Martin
happy holidays for everyone,
thanks for your reply, it makes sense what you are saying, I must have been tricked by the 5 min average since what you are saying is true; I have been tricked also by the fact that trying the same tests on other routers I did not get any similar drops, however on a second though I will test both routers once again with the same tests and compare results,
thanks again for your help
Hi, I have performed exact the same tests on two different routers with the same VoIP config (& obviously different IP addresses) and I get similar results, however even if I have changed the load-interval to 30 secs and my ICMP tests are far longer now (repeat 10000) I still get drops while 30secs average doesn't exceed 330Kbps.
Have you got any ideas why?
Please see below outputs from those two tests (output with echo packets display omitted, we see only results).
Router A
ping 10.167.2.153 source 10.167.32.122 rep 10000 size 1500
Success rate is 99 percent (9914/10000), round-trip min/avg/max = 16/17/244 ms
Serial0/0
305064 packets, 175407016 bytes
30 second offered rate 341000 bps, drop rate 0 bps
22200 packets, 32388800 bytes
30 second rate 339000 bps
172135 packets, 95423516 bytes
30 second rate 0 bps
Queueing
Strict Priority
Bandwidth 30 (%)
(pkts matched/bytes matched) 226108/170354926
QoS Set
precedence 5
Packets marked 293047
Router B:
ping 10.167.2.169 source 10.167.32.126 repeat 10000 size 1500
Serial0/0
634754 packets, 356868667 bytes
30 second offered rate 324000 bps, drop rate 2000 bps
15944 packets, 13846523 bytes
30 second rate 322000 bps
618810 packets, 343022144 bytes
Queueing
Strict Priority
Bandwidth 30 (%)
Bandwidth 595 (kbps) Burst 14875 (Bytes)
(pkts matched/bytes matched) 627783/356424848
(total drops/bytes drops) 61/91276
QoS Set
precedence 5
Packets marked 634754
Thanks a lot
again it looks to me like an averaging issue. Ping sends packets ... and then waits. So for the packet sent the speed would be at least twice your average, and while the reply comes in your router is idle. So 50% of time "full" speed, 50% of time no traffic - neglecting round trip time. This would assume at least 660 kbps during packet sent and zero bps while the ICMP reply is sent back.
660 kbps is above the limit (614 or 595 kbps respectively) and therefore drops are to be expected.
Hope this helps
Martin
P.S.: rate helpful posts
168
