QOS for Voice
I have access layer switch, where Cisco IP phones are directly connected.With IP phone,pc is connected. Acees layer switch(4506) is connected with 6509 core switch and 6509 is then connected to 7206 router for WAN connectivity. I want to implement QOS end-to-end. Can you please let me know the best practice and the best way to achieve quality of service starting from acess switch to core switch and on router.
Re: QOS for Voice
Your IP Phones does marks the packet with COS - 5 and DSCP EF.
on your 4500 switch port whereever you got ur ip phones connected do remember to trust the device which is ur ip phone and also trust the qos markings.
now you need to concentrate upon the queueing part which you need to configure on your switch so that the different traffic patterns have differen queues configured.
it also depends upon how total queues your 4500 can support.it comes like 1p3q etc.,
so plan your queuing technology in place.
Also in your 6500 match the dscp values being marked or being sent withe tos field of your traffic sent from 4500.
configure your 6500 accordingly to carry forward the same qos markings till to your 7200.
again in your 7200 vxr place your voip in LLQ and other traffic in CBWFQ.
you can alwasy do RTP compression also if ur P2P link is less than 1Mbps capacity,also you can try out LFI.
i hope you are well aware of configuring class-maps,policy maps to achieve the main qos config components and also about wrr or srr based on the support in ur box.
regds
Re: QOS for Voice
Thanks for your help and support. Following is the configuration which I have done in my devices. I haven't enable any qos under VLAN interface and under interface between Cores witch to WAN router.Is there any need for above? I am not much confortable with wrr/srr queuing, so is it necesaary to define?
Also let me know, if anything else I have to configure.
Router-
inteface Serial 1/0
ip address 1.1.1.1 255.255.255.252
encapsulation ppp
ip rtp header-compression
service-policy output voice-policy
no shut
class-map voice-signaling
match access-group 112
class-map match-all voice-traffic
match access-group 111
policy-map voice-policy
class voice-traffic
priority percent 75
class voice-signaling
priority 1024
class class-default
fair-queue
access-list 111 permit udp any any range 16384 32776
access-list 112 permit tcp any eq 1720 any
access-list 112 permit tcp any any eq 1720
Core switch (6509) -
interface GigabitEthernet7/1
description ### Towards access switch 4506 ###
switchport mode trunk
mls qos trust dscp
auto qos voip trust
no cdp enable
Access switch (4506) -
interface GigabitEthernet0/2
description ## Uplink towards Core switch ##
mls qos trust dscp
auto qos voip trust
no cdp enable
interface FastEthernet1/1
description ## towards IP Phone ##
switchport access vlan 147
switchport voice vlan 1147
mls qos trust cos
mls qos trust device cisco-phone
power inline auto
spanning-tree portfast
Re: QOS for Voice
hi
do revert back about the config status on ur uplink between the 6500 amd your router ethernet port ?
also any specific funda behind configuring signalling traffic ?
coz all other traffic you are just leaving like that not giving any guranteed bandwidth.
do take care of that part too.
regds
151
