Community Member
QoS on 3560 for Avaya phone
I have the following QoS settings on 3560 access layer switches for Avaya phones.
mls qos map policed-dscp 0 10 18 24 25 34 to 8
mls qos map cos-dscp 0 8 16 24 34 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 1 2 4
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 46
mls qos srr-queue output dscp-map queue 2 threshold 1 16 18 20 22 25 32 34 36
mls qos srr-queue output dscp-map queue 2 threshold 1 38
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 56
mls qos srr-queue output dscp-map queue 3 threshold 3 0
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 3 10 12 14
mls qos queue-set output 1 threshold 2 70 80 100 100
mls qos queue-set output 1 threshold 4 40 100 100 100
mls qos
class-map match-all VOICE
match ip dscp ef
class-map match-all ANY
match access-group name ANY
class-map match-all CALL-SIGNALING
match ip dscp cs3
policy-map QOS-3560
class VOICE
set dscp ef
police 32000 8000 exceed-action drop
class CALL-SIGNALING
set dscp cs3
police 1000000 8000 exceed-action policed-dscp-transmit
class ANY
set dscp default
police 5000000 8000 exceed-action policed-dscp-transmit
interface FastEthernet0/1
description phone port
switchport access vlan 148
switchport voice vlan 200
service-policy input QOS-3560
speed 100
duplex full
spanning-tree portfast
spanning-tree bpduguard enable
interface GigabitEthernet0/1
description uplink port
switchport mode trunk
srr-queue bandwidth share 1 70 25 5
srr-queue bandwidth shape 3 0 0 0
priority-queue out
mls qos trust cos
I got some questions.
1. Would this QoS configuration work fine?
2. There will be no voice traffic until some weeks later. Would this QoS configuration affect normal data traffic?
3. Do I need "mls qos trust cos" command on the ip phone switch port? Since it's only the pc that would connect to the switch port at the moment, if someone change the cos value of the data packet, would the switch be fooled and put it in a high priority queue? How to prevent this?
4. If I'm going to disable QoS, can I just remove "mls qos" and leave all other QoS configuration intact?
Thanks in advance.
Daniel
465
