QOS on DMVPN using GRE
todd.martin
Hi all,
I have a need to apply QOS for Voip in my SOHO network. the spokes are 871's with DMVPN set up to 3845 NHS's.
we have GRE tunnels between each site and need to provide some sort of QOS to support the VOIP traffic. Most of the documentation out there discusses Pre-shared IPSec with GRE but not DMVPN.
I found this link
http://www.cisco.com/en/US/customer/products/ps6558/prod_bulletin0900aecd803f93d6.html
and the contact e-mail bounced back as undeliverable. :)
I would love to use auto qos voip trust but its not supported on GRE tunnels.
I have also looked at qos pre-classify but found the following...
In addition to the usual considerations for QoS over VoIP, these additional considerations need to be made:
1.Ensure that the packet marking for the IP packets is being copied to the GRE tunnel header.
The recommended way of configuring this is to issue the qos pre-classify command to the tunnel interface, and add the service policy to the physical interface.
2. Ensure that the public carrier is capable of providing QoS based on the packet marking you provide.
Why would the Carries need to provide QOS if the packets are encrypted and wrapped in GRE?
I am confused as to how exactly this will work.
5 Replies 5
paolo bevilacqua
the thing is that you can configure all the QoS you want inside the DMVPN / GRE, but it will have no effect unless the ISP is proving QoS too. That is, your original packet DSCP value is copied in the outer header, to allow the transport network to apply QoS.
micah.r.stanley
Hi Todd,
I work on a pretty complex DMVPN meshed network with extensive VoIP that requires QoS.
Here is a copy of our QoS statements and one of the tunnel configs.
class-map match-all SIPRVoIP
match dscp ef
match access-group name SIPRVoIP
class-map match-all TransitVoIP
match dscp ef
match access-group name TransitData
class-map match-all NIPRVoIP
match dscp ef
match access-group name NIPRVoIP
class-map match-all VoiceSig
match dscp AF12
class-map match-any NetworkControl
match access-group name IKE
match dscp AF11
class-map match-any TimeSensitive
match dscp af21 af22 af23
class-map match-all TransitData
match dscp af41
class-map match-any Collaboration
match dscp af31 af32 af33
class-map match-all NIPRData
match dscp af42
class-map match-all ALL_TRAFFIC
match any
class-map match-all TransitData-Remark
match not dscp ef
class-map match-any NetCtrl_2_LW
match dscp cs6
class-map match-all CallSig_2_LW
match dscp cs3
class-map match-all NetCtrl_2_RTR
match dscp AF11
class-map match-all CallSig_2_RTR
match dscp AF12
policy-map TransitData-Remark
class TransitData-Remark
set dscp af41
!Apply service policy input interface to tunnel package!
policy-map RTR_2_LW
class NetCtrl_2_LW
set dscp AF11
class CallSig_2_LW
set dscp AF12
!Apply service policy input FA0/0 and FA0/1!
policy-map LW_2_RTR
class NetCtrl_2_RTR
set dscp CS6
class CallSig_2_RTR
set dscp CS3
!Apply service policy output FA0/0 and FA0/1!
policy-map Aggregate
class SIPRVoIP
priority percent 35
class TransitVoIP
priority percent 6
class NIPRVoIP
priority percent 5
class VoiceSig
bandwidth percent 3
class NetworkControl
bandwidth percent 5
class TimeSensitive
bandwidth percent 20
random-detect dscp-based
class TransitData
bandwidth percent 7
Class Collaboration
bandwidth percent 10
class NIPRData
bandwidth percent 5
class class-default
fair-queue
!Nested in policy-map Linkway!
policy-map Linkway
class ALL_TRAFFIC
shape average 3077000
service-policy Aggregate
!Apply service policy output interface to LW!
crypto isakmp policy 10
encr aes 256
authentication pre-share
crypto isakmp key CR6700ik address 0.0.0.0 0.0.0.0
crypto isakmp invalid-spi-recovery
crypto ipsec transform-set aes_set esp-aes 256 esp-md5-hmac
mode transport
crypto ipsec profile XXX
interface Tunnel6773
description DMVPN Multipoint Hub to Spokes
ip address x.x.x.x x.x.x.x
no ip redirects
ip mtu 1420
ip pim sparse-mode
ip pim nbma-mode
ip nhrp authentication -------
ip nhrp map multicast dynamic
ip nhrp map multicast x.x.x.x
ip nhrp map x.x.x.x x.x.x.x
ip nhrp network-id 6773
ip nhrp holdtime 600
ip nhrp nhs x.x.x.x
ip nhrp nhs x.x.x.x
ip nhrp nhs x.x.x.x
ip ospf network broadcast
bandwidth 3072
ip ospf priority 4
ip ospf cost 1050
qos pre-classify
tunnel source FastEthernet2/0
tunnel mode gre multipoint
tunnel key XXXX
tunnel protection ipsec profile ---
ip tcp adjust-mss 1332
no ip mask-reply
no ip proxy-arp
ip route-cache flow
no shutdown
set transform-set aes_set
Hope that helps you some.
I see that you apply service policy on fastethernet, my comment would be that since it is unlikely the fastethernet provides backpressure (is never congested), no application of QoS will occur. You can verify this with show interface and service-policy.
The only effective place to configure QoS is where there is congestion, or where bandwitdh is artificially reduced.
Due to the architecture of the Network (it is a DoD network... ) The FA interface is the primary interface for traffic destined for the DoD portion of the network (180 nodes in a TDMA mesh each location having 10 - 50 VoIP phones running G711uLaw; the government did not want to spring for DSP farms at all of the CME locations though we are slowly getting to where we can use G729r8 between the locations) and the transit interface for DoD traffic destined for the commercial networks. Therefore, port utilization is high resulting in congestion which did require the use of QoS to improve call quality.
I did not include the rest of the configs that we use as they were not pertinent to this particular discussion, but had you seen them, you would see why it is aplied there.
Thank you for explaining the details of traffic amount in this network and good luck with the project!
