Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Qos Problem for G.HSDSL
Here is my running-config file. I run
"CANTAS(config-if-atm-vc)#service-policy output SES" command under PVC 0/35. After this command i dont take any error messages. But this service doesn't work.When I check running-config again i can not see this command under pvc. And i run "show policy-map interface atm 0/0.1" but see nothing. How can i start this service correctly. Thank for everthing.
1 REPLY
Re: Qos Problem for G.HSDSL
Your ATM interface doesnt have the right configuration for a service-policy
Under the PVC you need to apply L2 QoS. Specify cbr or vbr for the interface speed.
The other thing that may be stopping you is the "atm route-bridge ip". I'm not entirely sure if that makes a difference. But if it still doesn't work then you will need remove that statement and get the remote end to adjust its configuration too.
112
