06-15-2006 01:19 AM
Hi friends,
I have a link with 2 MB and I have 2 application groups. One group are application that can use all link BW (2mb) and I have other app that runn over tftp protocol; If the first app group use 1.8 MB, this ftp application can use 0.2 MB, if first group app use 1.5 MB, ftp aplication will use 0.5 MB, and if the first group app use only 0.5 MB, the FTP application can use maximum 1 MB. The purpose is that first group application can runn without BW problems. How can Implement it?
Best regards.
06-15-2006 04:15 AM
Hi Raul,
on which kind of equipment you have this 2MB link?
Ivan
06-15-2006 06:41 AM
Hi friend,
I have a central router, its a 6513, and its links with branch offices with 2811 series.
Thank you and regards
06-15-2006 04:25 AM
Hi!
I would try to implement it like this:
firstclass is first application group; secondclass is FTP application
class-map match-all firstclass
match (firstclass match)
class-map match-all secondclass
match (secondclass match)
policy-map child
class secondclass
shape peak 1000000
policy-map parent
class firstclass
priority percent 95
class secondclass
service-policy child
interface X/Y
service-policy parent
Please rate this post if you find this solution usable.
Ivan
06-15-2006 07:13 AM
Hi friend,
Thank you for information.
I have some questions..
First application group is a group with many application, I dont know which are them..telnet, http, https, SAP...
How can I implement on a class-map...by access-list???
The second-group app are FTP application, with this config, FTP app can use 1MB maximum, but only when there are BW available????
-In the config have a "priority percent 95", this say that its rserved a 95% of BW??? why???
Its applied on output??
Regards and thank you
06-15-2006 02:15 PM
I would suggest a slightly different config:
ip cef
class match-all FTP
match protocol ftp
class match-all class-default
match any
policy-map LimitFTP
class FTP
shape average 1000000
class class-default
bandwidth percent 95
interface Serial0/0
bandwidth 2048
service-policy output LimitFTP
max-reservable-bandwidth 95
The difference is that here FTP is limited to max. 1 Mbps and all other applications are guaranteed up to 95% of the interface bandwidth. FTP would then get a maximum of 5%. In case the other apps do not utilize their bandwidth FTP can use up to 1 Mbps.
Hope this helps! please rate all posts.
Regards, Martin
06-15-2006 11:39 PM
Hi friend,
I dont understand why we type "bandwidth percent 95" and "max-reservable-bandwidth 95"....
Thank you very much and regards
06-16-2006 03:19 AM
per default only 75% of the interface bandwidth can be used in a policy-map. "max-reservable-bandwidth 95" allows to use up to 95% for bandwidth guarantees in a policy-map.
"bandwidth percent 95" reserves 95% of the interface for the respective class, IF there is so much traffic. The reservation is not exclusively, i.e. any traffic will be forwarded across the interface without restriction, IF there is not other traffic. In your case FTP can utilize the bandwidth unless other traffic occurs.
Hope this helps! Please rate all posts.
Regards, Martin
06-20-2006 03:08 AM
Can I apply this config on a frame-relay interface?
Best regards
06-20-2006 03:53 AM
yes, but usually not directly. Instead use:
frame-relay traffic-shaping
interface Serial0/0.100
frame-relay interface-dlci 100
class FRclass
map-class frame-relay FRclass
Adjust DLCI and interfaces to your environment.
Regards, Martin
06-25-2006 11:55 PM
Can I also apply this to my current setup which is Frame Relay?
I have a dilemma with my VoIP setup which is connected via F/R and also with a DATA running into it. The problem is whenever there is a large chunk of data e.g. sending of email with attached file, the voice is very much affected like a garbled voice.
Can I use bandwidth percentage? Say limiting the transmit of data to only 40% of the total bandwidth.
BTW, our bandwidth is 128kbps. thank you very much and hope to hear a reply from you guys.
06-26-2006 03:12 AM
Hi!
On any link that is lower than 2 Mbps, you need also a frame interleaving which will chop longer frames into specified size. You can easily calculate it or find it on CCO.
Ivan
07-06-2006 03:40 AM
Hi friends,
I have apply the QoS config on my frame-relay network, but I have an error. The config is:
class-map match-all FTP
match protocol ftp
policy-map limitFTP
class FTP
map-class frame-relay test
service-policy output limitFTP
interface serial0/0/0
interface serial0/0/0.30
frame-relay interface DLCI XXX
class test
!!!! I HAVE AN ERROR when apply the class test: Only class-default supported over FR VC?s !!!!!!!!!!!!!
What is this??
Best regards.
